Pontiac G6 Brake Problems
in Pontiac
Hi I lease a Pontiac G6 2005 with 5200 miles on was brand new when I leased it back in Sept 05, jan 06 the ABS module got way to hot melted and caught on fire, apprently for no reason at all, I thought ABS was for saftey, thank god no one in my family was hurt and that my 16 year old wasnt the one driving. So I have been in a rental car since. The dealer ship is replaceing the parts, and they say they can get the brunt wire smell out of it, I doubt it, I am not accepting the car back until they do. Well they recieved all the parts put the car back together again, and are now telling me that one of those parts was defective from the factory, I dont buy it, Gm will not extend the warrenty even though they admit that it is a manufactures defect. HELP I dont know what else to do.
I am so angry this was my favorite car i love it do death.
:confuse:
:confuse:
Meybe i don't understand you. Do you mean to say your warranty did not cover the ABS system? That seems odd to me but if thats the case then you have a point.
How could the ABS catch on fire? That technology has been around for so long...
MY WEBSITE DEDICATED TO PONTIAC AND THE G6 ROTORS!
I had to have my back rotors refinished/cut between 8,000/9,000 miles. I was stunned. After owning cars for 40 years, I know that rotors should last longer.
Thanks for the tip!
My dealer did not replace the pads either. I guess they are waiting until the warranty is out.
Now, my front brakes are acting up. Back to the dealer..this time I will ask, "How can rotors be warped and not affect the pads? Should the pads be replaced along with the rotor cut?" Is that the proper procedure?
PS. my delaer told me the rotors were rusted. This I have never heard in all my 40 years of driving. I know rotors get rusted...but not so soon. Perhaps the metal quality of the rotors is poor? :sick: :confuse:
I have 19K miles on the car. This is the first brake issue I have had. Is this common? Reading these posts has me concerned.
Any advice?
Do you have any idea what is covered, rotors, pads, etc and what isn't?
I have a smart buy and I don't think it is up until next year so I am stuck I suppose. Previously I had a grand am and had no issues with it at all.
Chances are, if someone has already traded in their 2006 G6, it's probably *because* it has rotor problems, so not much chance of me buying one and randomly getting off the hook. Does replacing the stock pads with ceramic help? And how much does that cost? Maybe I can talk the dealer into doing that before I buy (or at least giving a discount on it), or else just walk out. If the problem is really as bad and unfixable as it sounds from this thread, then I'll probably have to stick with a 4cyl, since the G6 seems to be about the only V6 available about 2-4 yrs. old that's in my price range. Everything else about this car is pretty much just what I want...
Front brakes are great, back at 70%. With these types of brakes compound forms and you will hear that noise until it wears off.
Sorry I know there is a better technical description but I have no more brake noise, perhaps it could be grime that built up.
I do recommend the car actually, I love mine..its roomy, good pep and decent gas mileage. I am sure as with any car the wear and tear affects the performance.
After being told that it was due to improper wheel lug-nut torque, I purchased a quality Torque Wrench. To this day,immediately after getting a new car home, I loosen the lug-nuts and then re-torque them to specifications in the owner's manual.
I have owned Chrysler, BMW, Toyota, Nissan, VW and Mini Cooper vehicles as well, and NEVER, EVER had rotor warpage on anthing other than GM vehicles, so I would hazard a guess that it isn't my driving style or environment causing problems.
So, I shared your pain on this issue. However, it could be much worse...Check out the 08 Saturn Sky Red Line model's brake problems, here on the Edmunds forums...you might be glad that rotor warpage is the only problem you are having!
While I never invested in aftermarket rotors on any of my GM products, the simple fact is that I never had these issues on any non-GM automobiles, so I know that rotors can be made that will not warp under normal circumstances.
I am sure that you can find suitable aftermarket rotors at a reasonable price, but I would double-check the warranty covering warpage. Also, seeing as how you have been abandoned by GM, I think I would let a different service provider do the work.
Try www.brakeplanet.com for a start. There are many others you can find on Google, not to mention local brake/mufflerrepair shops in your area..
Good Luck!
As far as the ABS, I do not believe it was a standard option at least on my 2006. Mine does not have it, and I can't say I miss it.
I love my G6!!! I hope I am done with brake problems. Brake Team gave me a 3 yr 36000 warranty. Re-checks every 12000 miles, free replacement if any issues (NO TURNING)
If you haven't done so already, I would suggest you make a report of this incident using the NHTSA web-site.
Who can I hire to blow the car up? (kidding) I love my G6 but investing more $ into something that can't seem to be fixed is a waste. I will never buy a Pontiac again and can't wait to find a way to trade it in, no matter how in debt I wind up being.
Would love any advice if you folks have any! Please!
I was also told to only purchase a dealer gas cap - not from an auto store. They reset the engine light and I went on my way. I know this isn't the end of it.....
My G6 has 12,000 miles and will replace a set of rotors soon.
You say, "THREE SETS OF ROTORS IN 33,000 MILES!" Wow.
I guess that means GM ROTORS for the G6 are only meant to last for about 11,000 - 12,000 miles!
My G6 Rotors are always in a state of "rust." Always cutting them.
Rotors should last for 50,000-70,000 miles so I am told!
If Your Dealer reports to Pontiac Headquarters that the rotors were defective - then the perhaps the rotors can be replaced at Pontiac's cost.
However,, the new rotors will also only last about 12,000 miles.
This is outrageous! Whatever can the consumer do?
With GM cutting back on production and jobs this past month - I don't expect them to admit that there is a problem and will not recall the rotors.
It is up to each individual to fight.
I already talked to Pontiac Headquarters.
Now, I am going to find my State Consumer Protection Agency and see about a LEMON law thing. Then an Attorney for the aggravation and dollars lost on a brand new car. Let GM pay the attorney.
I wonder how many people are out there who have been buffaloed by the dealerships into thinking replacing the rotors at 12,000 miles is a "normal" part of maintaining a car? :mad:
Anyway, would be interested in knowing how the Power Slot Cyro-treated(part#8278ct) for the front rotors at $230 set work?
Please update. :lemon:
Yes. I had my car towed for a non-start. When the car arrived the Delearship called me and said I needed a whole new transmission line because the fluid leaked out all over the garage floor at the dealership.
I did not notice any leaking. I suspect that because the car is built so very close to the ground that the transmission line is suspectible to damage. (I don't know, just guessing.)
I have the same problem last week Aug 16. Dealer claimed the same thing to have fixed it. I just left the dealer about 3 blocks, the brake light was on again all the times. I had to bring the car back for them to fix. After the 2nd time , it still happened even they claimed they changed the brake light switch and reprogrammed it. Now my car is still being at the dealer. Does anyone have that same problem and dealer successfully fix it? I will follow your advice to keep all records of fixes and call NHTSA and GM too.
