All the best,
Sarah
GM Customer Service
All the best,
Sarah
GM Customer Service
MODERATOR /ADMINISTRATOR
Review your vehicle
Sarah...any ideas here?
Any code would cause it, make Pressure Control Sensor {PCS} go to full pressure. IAT sensor bad, would.
Needs to be scanned.
Sarah
GM Customer Service
Here are the comments on our receipt:
Remove Trans Ubit (?). Replace complete valve body and necessary gaskets. Flush cooler lines, perform alignment then reinstall transmission.
Parts included: Housing, Band ASM, Valve Sol, Trans Kit, Plate ASM, Harness, Gasket and Fluid.
Our extended warranty covered everything including a rental car for 2 days.
If we can check into information on any existing warranties you may still have on your vehicle, please send us your inquiry, contact information, and the last 8 digits of your VIN to socialmedia@gm.com.
Sarah, GM Customer Service
We hope you get some helpful technical insights from other members of the forum soon (we cannot, unfortunately, provide much technical troubleshooting over the internet). If you want for us to check into any warranty or recall information on your vehicle, please email us the last 8 digits of your VIN and contact information at socialmedia@gm.com
If you had wanted for us to check into your warranty information and potentially help you find a dealership in your area, please send us the following information via email at socialmedia@gm.com: your name and contact information (especially your ZIP code), and the last 8 digits of your VIN.
All the best,
Sarah
GM Customer Service
I have been having the same problems and apparently I took it to the dealer and he said that its one of the spark plugs in the cylinder 1. So, my question is how do I trust its the cylinder. Generally if one of the plugs are bad they have to set a code and somehow there has been no error code set. My warranty ends June 2013 and I dont want the trans to break down after the warranty. Any more updates on this issue as to what is wrong.
Jan
If you had wanted for us to check into this further with you and your dealership, please email us at socialmedia@gm.com (include your name and contact information, a summary of the situation, the last 8 digits of your VIN and mileage, and the name of your dealership).
If you would like for us to check into this further with your involved dealership, please send us an email at socialmedia@gm.com with more details (include your name and contact information, the last 8 digits of your VIN, and a brief summary of the situation so far).
Sarah
GM Customer Service
Bought the car in 2007, with about 30k miles on it. In 2009, while on vacation in South Missouri, the clutch burned out on a super hot summer day. After an excruciating 1.5 hour ride with a tow truck driver, 2 6 hour trips to get it, a big search for parts, nearly 2 weeks of rides from others, and almost 2k, I got my car back along with a lecture on how to drive a stick. (I grew up on a farm, and don't need lessons).
Well, 2011, on another hot summer day, clutch #2 bites the big one. So, another 2k, 2 weeks without a car, and another lecture about how this little girl can't driver her car. To prove them wrong, I took them on a little ride. They could hardly drive my car, I had no issues and they conceded that I can, indeed, drive the car. I would've gotten rid of the car then, but my Dad really really really loved this car. The mechanic this time and the time before thought that a defect in the slave unit that caused it to leak and emit fluid to ruin the clutch.
Well today, its dead cold in Missouri. My trusty G6 started like a dream and I drove about 80 miles. Then I drive through some pretty heavy traffic, and tried to parallel park. When it came to making the final pull forward, it was a no go. Clutch to the floor, car won't go in gear, out of gear, won't do anything. Completely different from the other 2 times. No instant clutch smell. Because I was far from home and had other plans, I left the car where it was, and went about my day. Figured I'll wait to call a tow truck and plan a long ride home until I absolutely have to do so. I contacted a couple of my car buddies, who said to give it some time and see if maybe it just got too hot (the high today was 19). When I returned to my car, I was able to raise the clutch pedal, and it engaged like nothing ever happened. I talked with my buddies who said if it appeared to be driving normal and there was nothing leaking or smelling, to put it in gear and drive home. Thats what I did and she ran like a dream ... until I came to a full stop and attempted to shift to first. No go. Spongy clutch to the floor. Turned the car off, picked up the clutch pedal, turned the car back on, and I can shift gears, though the clutch is very soft. Still no clutch smell at all. So she's parked in a lot, awaiting what looks like a tow ... again.
The consensus among my friends and family is that I have air or a leak in the clutch assembly/slave unit. We'll likely try to bleed the system, but thats an undertaking in itself when the highs this week are in the teens. Plus, from what I understand I may not be able to access the bleeder valve without taking out the engine? Sounds to me like its another garage, and another dumb female driver lecture for me. If anyone thinks otherwise, please let me know.
I know this is a long message, but my Dad passed away suddenly in August, and we spent alot of time on this car together. Rotors, alternator, oil changes, and lots of memories in this old car. Yes, it has 130K miles, but less than 25k on this clutch. And when it runs ... it RUNS. I work with law enforcement and they all love the way this car runs. Hate to see it go, but at this point, I can't really see sinking cash into this car, when I can use that money as a down payment for a new vehicle ... certainly NOT a GM product (though that really hurts to say).
Any advice would be appreciated.
Was the most recent clutch replacement done with one of our dealerships?
Annie
Glad to hear that you were in a controllable situation when the gears failed to engage. Are you planning on working with your GM dealership to get this addressed? Let us know if we can look into anything. We can be reached via email at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
So far my 09 G6 2.4 has had no major problems at 47K miles.
We're sorry that you've encountered so many issues with your G6. Keep us posted on how the transmission replacement goes! If we can look into anything for you, please don't hesitate to contact us at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
Strange the dealer did not know that.
In fact my catalytic converter is warrantied for 150K miles or 15 years.
I also own 09 G6 with 48K miles.
I did take it into my local dealership back in 10/12 and then said they could not find any issues and cant look at it unless they could re-produce the problem.
It does only seem to happen after and extended drive and it now seems to be doing it more often.
Any help, suggestions would be appreciated.
My 2006 G6 's clutch burnt out with over 50 K a few years ago. I was more aggressive than usual but not hot rodding Having driven primarily manual transmission for 40 years I have NEVER burnt a clutch. Last week, while away on vacation my kids used my G6 and they have driven it before. Once again my clutch is shot with 96K miles. I expected my clutch to last a lifetime of the car, as is my previous experiences. With a 3.9 L engine, the clutch should be robust enough to handle the power. I believe Tranny is made in Hungary.
Love the car but not the transmission.
I have a 2007 G6 hardtop convertible at 69,000 miles the transmission went out, had it repaired at the dealer under warranty, and just this past week at 139,000 miles it went out again. Put it in drive and nothing, like others, was able to limp it home in the manual shift mode. Going to cost close to $3000.00 to have it repaired. I love this car, and didn't expect to have the transmission fail twice.
I believe the transmission is too weak for the V6 engine.
Go here, all you need to know.http://www.g6ownersclub.com/forum/showthread.php?t=12532
