Chrysler Sebring Audio System Problems
I am having an intermittent problem with the radio. When I first start the car in the morning the radio works fine! However once I turn the car off and restart it the radio no longer works and the lights on the radio blinks on and off. Any suggestions? It is hard to ride in a fine car without any music in the background!
please advise
getting hard to find my cassettes.
Any local car stereo shop can sell and install a unit for you. Cruchfield.com is also a good source for after market stereo/cd players.
You will not be able to buy a unit which will control your 4 CD changer. No one makes such a unit.
You can probably find a stock radio on e-bay. I spotted several but decided against installing one after seeing the number of problems people have had with the Chrysler radios
Thanks for your help
Anyway, one of the options for MyGIG is a backup rear view camera. Mine didn't come with one but I'm thinking about adding it. I've seen several color, wide angle, night vision cameras listed on eBay for under $50. The camera is very inconspicuous and attaches to the upper license plate frame. Most come with an RCA plug and 10-15 ft of cable.
Has anyone added a backup camera to their MyGIG? Is there an RCA jack on the back of it?
The factory installed camera shows the camera view on the screen automatically when you shift into reverse. I'm not sure how this would work on an aftermarket camera or if the dealership could program the MyGIG to make it do this. I know they can enable/disable the front seat DVD for certain states, so they apparently have some programming control over the setup.
If you want to learn more about MyGIG click here: http://www.chrysler.com/mygig
By the way, that info is in your manual if you have one and forget the next time we have to change our clocks.
Eli
Note: Even though it has been a great car, I have had the problem that the radio gets on and off. Did someone find out what is the problem?? That radio has been replace like three times. Thank you.
Any help is appreciated
The only options for adding music to the hard drive are via disc or USB flash drive. You don't have to copy the entire playlist from a USB device.
Copying audio files using the USB port:
1. Lift USB cover and insert the USB device. Select MY MUSIC.
2. Select IMPORT MUSIC FILES. Select FROM USB.
3. Select individual files or ALL. Select DONE to begin copying.
There's a demo of this on the Chrysler MyGIG website. Click on "Copy Audio Files" on the left side of the screen.
Also, anyone used a Data DVD for MP3s? Manual implies it will work...but also says there is a file limit of just 256 files...is this total file limit or is it per folder? I can usually get about 1,000 MP3s on a data DVD....
Anyone know of more info on this radio besides the standard car manual?
Robert
and how to fix them?
The IVA-D310 is a DVD/TV head unit and I have heard that there are issues with installing a TV head unit in the 07 & 08 Sebring... has anyone encountered any wiring problems while attempting to install a TV head unit in either of these years models? If so what was it and how did you end up solving the problem?
I will be replacing the stock speakers in the front doors and in the rear deck. 6.5" coaxial Focal's in the doors and 6"x9" Boston Acoustics in the deck. These will be driven by a Rockford Fosgate T400-4 amp. As well as 2 Boston Acoustics G2 12" dual voice coil subs in a custom designed ported box in the trunk driven by a Sony XM-SD51X running at 2 Ohm putting out 500W. I will be running the amps thru a dual 1 Farad capacitor set-up from Audiobahn. All power and ground connections will be thru 1/0 AWG and interc">link titleonnections will be 16 AWG wires... all copper is 100% pure crystal-oxygen free. When the time comes to replace the battery it will be replaced with an Optima and the alternator will be replaced with a high output model for high amp usage. Distribution block and positive battery terminal will be gold plated and digital displayed to monitor current and fuse blocks will also be gold plated.
If anyone has any input or suggestions please feel free to! I look forward to any help that anyone can give1 Thanks for taking the time to look this over ! ~Fatalii
<a href="http://www.sonicelectronix.com/item_11838_Scosche+CR1291B+-+CR1291.html
Did you find a solution to enable the DVD player in Drive position, If so can you help me to do it .
There are several aftermarket hardware devices that you can install to enable DVD in motion. The one I recommend is called ALLGIG-USB (do a Google search). I don't work for them, I just surf many MyGIG forums and the feedback I've read from ALLGIG owners is very positive. Apparently they have great customer support.
There was once a bug in one release of the MyGIG without nav (REN) where you could press a combination of buttons and get it to play a DVD while in motion. It was fixed on later releases but you might be able to find a video of how to do it if you do a Google search.
