Ford Focus: Problems & Solutions
Nevertheless, I bought the ZX5. The mechanic at my BC ford dealership told my sales agent that he's never tried modifying the turn signal to decrease the volume, and wouldn't really know how.
I intend to investigate further. I've sent an e-mail to Ford and will post their reply here when it comes in about 3 days from now.
Does anyone know how the turn signal can be modified?
I can't stand this loud turn signal and refuse to live with it. I find myself avoiding using the turn signal whenever possible. Not even the radio drowns out the sound.
I wish FORD would offer its customers the choice of taking their vehicle in to have this loud and irritating tick-tock turn signal modified AT NO CHARGE. IT'S WAY TOOOOOOOO LOUD!!!!!
The Service Dept. at my dealership explained that the loudness is caused by the RELAY. They had tried changing the relay in a Ford truck of a customer who had also complained about the loud turn signal, but it met with no improvement.
The dealership offered to try changing my relay at no cost to me...'cause they'll do it under warranty. But they're pretty sure it won't make a difference.
Apparently the NA customers which were used to the loud turn signals in their previous cars started to complain. FoMoCo's responded by adding a little "speaker" to the turn signal unit.
It's called a solid state switch I think.
There are no mechanicals relays in there.
Search focaljet.com
There were some good instructions posted a while ago on how to silence that speaker.
I tried searching focaljet.com, but unfortunately couldn't find any instructions there.
I sent an e-mail to the service dept. at my dealership to ask them to look into it. I told them of the possibility of a speaker, and also asked if they could install a 2000 model unit.
My service representative is taking my issue seriously, even going so far as to sit in four Focus's to hear how they sounded. They were all loud. He's having a mechanic look into the situation for me, though it is merely a design feature of the newer focus'. My 2000 turn signal was just purrrrfect, and I would be willing to pay up to $200 to have it switched/installed.
Will post the reply when I get it. It may take a couple of weeks because my service representative is off getting married and honeymooning.
p.s. It's not just the loudness of it...The turn signal also has a TICK-TOCK, TICK-TOCK! It hurt my ears the first 3 days; it doesn't hurt anymore...i've gotten somewhat used to it...but I'd still much rather have the 2000 model unit.
Dealer fixed by removing windshield cover (passenger side) and sealed so water can not enter into heater box and then to passenger floor. Took all of 1/2 hour. Dealer stated that would replace carpet and underlay if smell should develop. Shop vac and air dry should do the trick. Hopefully, no other further problem. What happens in 7 years with some dampness on the interior. Time will tell. I've got 23k mile on it right now.
I've read the posts about the fuel pump. Is it in the tank? Does anyone have some suggestions besides the obvious, of take it back to the dealer. I've got 25K on it right now.
Jack
It isn't a toggle switch though, meaning I couldn't have shut it off by accident when sucking up all that water on the passenger floor board.
Has anyone else had such a failure?
Jack
Dede
Why so much of drama?
What were you driving before?
Just in case you didn't know, the front brake pads IS a wear item. They DO need to be replaced on the regulare basis.
Some people are very hard on their brakes. I know several that wore down their brakes during a single day while autocrossing.
Some are much easier and get more than 50,000 miles out of their FACTORY Focus pads.
19,000 miles for the OEM front pads is a reasonable period.
Uneven pad wear is a legitimate problem though.
Oh really, well hear this. I just bought my Ford Focus ZX3 2003 in June and had to bring it back 3 weeks later because the brakes were bad. Well, they are still not fixed and I just had to bring the car back again, the dealership has it now. But there is an even bigger issue going on. There is a wierd loud clunking noise coming from the right front underneath. They say they are investigating and they have no idea what the sound could be. But it's very obvious and does not sound good, it sounds like when you are going up in a roller coaster that clunking noise. The sound mainly happens when you let up off of the gas then you hear clunk clunk clunk.
Everyone says I should tell them I want another brand new Ford Focus because this one is not even 2 months old and look at the problems, Lemon Law may apply here, but I'm not sure what to do. This is twice on the brakes and now the clunking noise that they do not know what it is. Brakes may wear out but not that early, impossible. I had not even 1,000 miles on my car and very loud brake noises started immediatly after I bought it. When I push the brake pedal in, I am not always able to stop, the car slows down, but it does not stop.
Dede
I'm hoping that its just something trapped underneath the car, and not a poor repair job done by Koons garage. Especially as I really don't want to take it back until it reaches its 30,000 mile service.
If what you're saying is true then you'll have NO problem getting your money back or a replacement car through your state "lemon law".
The "bad brakes" that can not be fixed by the dealer is considered to be a serious safety problem.
Talking of which, it looks like I'm going to have to replace the tires again. The car dealer told me that the tires Ford uses are pretty soft, and hence switching to a different compound might get some longer wear out of them.
driving larger cars or SUVs, despite whether you traded from big to small or if you still have the larger vehicle. He's especially looking for drivers of the Mini Cooper, Honda Civic, Ford Focus, Dodge Neon, Hyundai Tiburon and Mazda Protege. Please respond to jfallon@edmunds.com by Tuesday, October 28, 2003 with your daytime contact info and the type of vehicles you had and have.
MODERATOR /ADMINISTRATOR
Review your vehicle
Stalling at a variety of speeds and conditions. Most likely to happen with less than a quarter tank of gas (mine at a half tank), sharp right turns such as entering a highway from a cloverleaf.
Ford has extended the warranty to 10 yrs. with no mileage limit but is not having a recall because this is not a safety problem. NHTSA disagrees and so do I.
I have had the fuel filter replaced that helped a little, had the pump checked and it was fine. But I have been the passenger in the car when the car hesitated while passing a car on a two lane highway and seeing the on coming traffic closing the distance a little too fast for comfort. Trying to merge in traffic gets to be scary. You do not know if and when the car is just going to start acting like it is out of gas. I have had to pull over to the side of the road and hope my car will start back up and then try to move into 65 mph traffic from a dead stop and in a car that may or may not go.
FORD do not tell me this is not a safety issue. Are you waiting for someone to be killed in the car first? I have made up my mind that because of your attitude toward this issue I will never buy another FORD.
Service Campaigns are voluntary programs in which the manufacturer agrees to replace or repair a defect beyond the terms of the express warranty and may provide for reimbursement for prior repairs.
Unlike a safety recall, the program may be limited in time beyond which the consumer receives no assistance.
Sometimes the NHTSA accepts a Service Campaign in lieu of a safety recalls which means manufacturers and/or dealers are not subject to the enforcement provisions of the National Traffic and Motor Vehicle Safety Act.
When NHTSA accepts a Service Campaign in lieu of the more consumer protective Safety Recall, NHTSA lists the Campaign on its website.
The notice said they had to re-design the fuel pump and it will start to be available to dealers in mid January. It also mentioned compensation for customers who have already had their fuel pumps replaced, but I didn't read that part too closely.
I haven't had any problems with mine as of yet. Actually, mine's been very trouble free so far(knock on wood).
-Scott
I noticed all the problems that people are having with their Ford focus. I bought a used ZX3 in November and it has been in the shop four times now for engine stalling and cutting out and flickering lights. My car is actually in the shop now and they can't seem to find the problem. I was wondering redfive2112 if the 10yr warranty applies to used cars?
Barb
We have a 2001 ZX3 with approx. 40,000 miles on it. We had a snowy winter last year in the Maryland area with lots of resulting potholes. I hit one fairly hard and thought nothing about it. Noticed a slow leak in front wheel, finally pulled it off to look for the "nail" and discovered the rim was almost cracked through. We probably drove on this for a month and so I feel pretty lucky that nothing horrible happened. We bought a new tire and rim from Ford for a mere $500. I've had alloy wheels on previous cars and never had this happen but thought maybe I hit this pothole "just right".
Now that we are starting to see the emergence of many potholes again this winter, I've been more careful to avoid them but tonight, coming off the beltway, I hit another one. So we pulled the wheel off right away after getting home, and lo and behold, the rim is slightly bent on one edge. I'm certainly very suspicious now. Are these rims just really soft and has anyone else run into problems such as these?
They sell sets of 4 NEW wheels with tires for $399 per set OR just wheels for $199 plus shipping (see the last page)
http://65.109.103.142/files/focus.pdf
The cigarette lighter has no power probably because of the blown fuse or dirty contacts.
Flickering lights at idle for short periods of time (1-3 sec)while changing electrical load (applying brakes, turning a/c on/off) is another Focus "feature"
My first thought on the lighter was a blown fuse. I went to check it the other day, but Ford didn't think of embedding a handy little plastic fuse puller in the cover like their brothers at Mazda did, so I could't pull it. It will have to wait until the weekend.
Reminds me of the time my fuse kept blowing on my old GTI cigar lighter. Put in fuse, immediately blows. Went through 3 NEW fuses before I found a PENNY in the socket!
Did you lose control and damage the tires and suspension? Do you have cupping on the inner edges, squeaks or bouncing (struts)? The dealer fix sounds drastic. Check into Aquatreds or a similar tire designed to avoid hydroplaning. Do your homework and don't blindly trust the dealer.
The brakes are noisy even when they're not worn out, but they are known to wear fast and are easy to check. Don't set yourself up for rotor replacement because you're thinking "I shouldn't have to be getting this done." When you do replace them, get the newer style metallic pads - MUCH less dust and noise.
Good luck!
There's a company called BAT INC ( http://www.batinc.net/ ) that (I don't know if they still have the kit) but had a EBC rotor kit with Mintex pads that were real nice. Great braking feel, wear much better as well.
*just looked it up. They still have the kit. Their part number is H420SF and it is $109 for the kit for the front (includes for both left and right sides). It doesn't say EBC rotors for that kit, but it was when I received it. Easy to do.
Yesterday, the check engine light came on when leaving the grocery store. It stayed on steady. The car "lurched" or "missed" when I attempted to drive down the road. It felt like bad gas. I was at half a tank.
I refilled at Chevron to full and securely tightened the gas cap. It only helped some. I went to an auto shop guy who could not pull up any codes, so we assumed bad gas. I chanced going home and it was better for the hour drive back, but then 10 miles out, it started doing it again.
I was afraid I wouldn't make it. It got real bad just as I made it home on a prayer. That "pulling" or "lurching" feeling in the engine has me real freaked out. I am so far from any dealership (2001 Zx3 45,000 under warranty)and I have no cell phone out here should I get stranded.
Should I tow it? What could it be? Any clues?
Thanks, HJ
Anyway, my first guess would be the fuel pump.
This year, I had problems stalling whenever coming to a stop (clutch pushed in, no check engine light). The original dealer said I'd have to replace the head AGAIN, at my cost. A second dealer replaced the fuel pump under an extended warrranty program (I did pay to have the jets cleaned). He said that water/crud in the gas tank exacerbates the pump failure. The first dealer says the pump fails electrically. I'm not sure who to believe, I just think dealers are taking advantage of customers as Ford tries to hide their mistakes on these early Foci.
If you received a letter from Ford, it mentions specific conditions when the pump might act up. In my opinion, this information is more confusing than helpful. Have the dealer check what version of the head and fuel pump you have (They should be able to do that over the phone).
I never got stranded, but you'd be wise to have a cell phone or companion car if you take it in.
Turns out, I had a recalled part for which I never received a letter from Ford. Thankfully, I made it all the way to a Vegas dealer with a neighbor following me the whole way.
The DPFE sensor (recall 02M01) that is part of the emissions system is faulty. They replaced it under extended warranty. I still don't feel confident though. I still feel like I can feel fine "pulling" in the engine. Something is not right. I'm going to Ridgecrest Wednesday and I think I will take it to another dealer just for a look. I think there is more to this fuel pump thing. Incidentally, what is a head?
I'm getting AAA, a cell phone, and I think in the near future, a Toyota. I am just losing my confidence in Ford altogether.
Thanks for your help. Check for that recalled part too.
It should cure that lurching feeling according to the people who already done that.
And it's free too.
