Ford Focus: Problems & Solutions
In the future, it would be most appreciated if you did not use all capital letters. It is difficult to read and is interpreted as SHOUTING.
Thanks for your cooperation!
Second: Would I buy another Focus?? IN A HEARTBEAT!!!!
My little Zippy (04 ZX3) has 49000 miles on her and has been the MOST reliable car I've ever owned. I bought her new with 52 miles on her July 21, 2004, I commute 164 miles/day even at 56 below zero, Zippy has NEVER failed to start. She is truely a GREAT car!!!
I would go for it, the Focus is a wonderful, fun to drive car.
THANK YOU AGAIN FOR TAKING THE TIME TO CONTIBUTE TO SOMETHING THAT WILL BE IMPORTANT TO ME
THANKS - TALK TO YOU SOON
http://possumblog.blogspot.com/2004/09/special-possumblog-weekend-edition.html
Good luck!
I wouldn't worry about it. Plus you get a 100k mile powertrain warranty.
I took the car to the dealership on Monday. They did not even look at it until Wednesday. I picked it up Wednesday and was told it was fixed, the tumbler was causing a circuit, they replaced the tumbler. I had the car for an hour, before the same syptoms started right up again. I took it back to the dealer the same day. The dealer apparently drove it around for two days (when I told them it is not a driving problem--they put 70 miles on my car). Said there was nothing wrong with it, so I picked it up again last night. I drove home, parked it in the drive way and several hours later went out side to find the interier dome light on and the oil light blinking. I haven't called the dealer back yet. I want to find out if any one has been having these problems with the 2005 focus. :sick:
Another website said that this problem affects 2003 and earlier models. The dealership said that they're using an updated part so this will never happen again. It better not, next time it fails it likely won't be under warranty.
Other messages in this forum suggest going to a locksmith (where they'll replace with tumblers that won't have a defect) instead of a Ford dealership (where they'll use a Ford part).
various consumer articles I've read, Ford has gotten
the bugs out of this car. Remember, the Focus first
came out in Y2000, and many of the problems/recalls
were in the first few years.
Not that I'm promoting it, but if you buy the Focus, you might
consider buying the ESP plan for extra piece of mind. With
the ESP plan, you can take your Focus to any Ford dealer
for breakdown repairs.
Thanks a bunch!!!
Personally I would buy the extended warranty, I did for Zippy even though she's never really been a problem. I paid $1350 for a 4 year/100k premium plus extended warranty.
if yo do not need the OEM part.. look around the internet.. there is plenty of differnet models.. but I do not know which ones would fit in Focus
But it seems that the car has enough prblems to justify a trade in... (I personally, if I were in your situation and had sufficient meas would go buy something different - it is ver ywell prossible the problem is hte particular car, not Focus design though so I wouldn't want you to turn back on Focus just because you possibly got ripped off on a problmmeatic car.
I hope this helps.
Igor
Thanks for the tip, reuel3, and thanks for all responses.
DP
of course, i don't see as well at night as i used to.
They appear to be stripped or something as I when I turn the bolt; it just keeps spinning. A big problem is that it really isn't a nut attached to the other side but rather a crazy fastener thing that is perfectly round; hence I can't get a grip on it to try and break it free.
I've tried the LiquidWrench/WD40/PBLaster route and still no luck.
Anyone else have this trouble and how did you correct it?
I've got an idea but it's really my last resort.
Thanks...
so i tried to trouble shoot the problem my self and found that there is a diode in the main fuse box ( engine compartment ) it looks just like a fuse but its black and has a marking like this on it -/<-- there are two one for the engine elecrical and one for the fans. you can just switch them to see if this works if it works go buy the one thats blown and replace with corect one. i dont think they ere the same resistance. hope this helps
everything with the left tail light works, except the running light when the headlights are on.
the bulbs are fine. tried a million. even switched the socket assemblies for the left and right side, still, the left side wont go on with the headlights.
anyone have any idea how to fix this?
thnx
I'm just wondering if I can put my 20lb dog in the front seat and him not get an airbag in his face..
start fine, like when you first start up.
After the car is warmed up the starter motor opens up and will
not crank. Its happened to me
called the dealer and he says that the alarm is part of the car computer and cannot be disarmed. The company that makes
this alarm is by AUTO MATE.
After moving from CA to GA, I had them checked and I needed news brakes and rotors at only 25,000 miles. Then I repeatedly went back to the same shop to have them looked at because of the squealing and softness of the brakes. Finally, I called the shop back and the manager admitted to me that Ford Focus has a huge TSB list due to faulty brakes on Fords behalf. They replaced them with ceramic brakes to stop the noise and after returning again, they replaced the rear brake shoes.
Things were great for at least 2 weeks until I past my 36,000 mile warranty mark and the brakes would hit the floor literally!!. I returned to the shop they said they saw no problems and checked everything. I drove right out of there and had the same problem. I went to another shop and they saw no problems. I returned to the same shop and explained that something is wrong and they bled the brakes again. They test drove it and everything. Said it should be good. It was not. Then today (11/27/05) I took it to another shop and they experienced what I was trying to prove to everyone all along and said the last shop did not bleed them correctly. I had confidence that it was fixed then because they test drove it and said it hit the floor. But low and behold, when I got into that car on my way out of the shop, I again would not stop and and dragged along. I am so disgusted and frustrated. I now know that many others have faced this issue and I am prepared to do whatever it takes to get my money back. These cars are lemons in my opinoin from all the the astronimical similiar stories in this forum alone. Ford needs to repay any individual that has owned and suffered from Ford Focus defaults. Any suggestions? :mad:
