I'm having Abs/stability control/traction problems too. Plugged n My own diagnostics machine. And it came up right front speed sensor circuit malfunction. So I replaced the hub. And It did not work. Same thing I especially noticed it when I make right turns it'll come on or right When I start the car???
If you come across any answers please let me know this is really irritating
Hooked up my Diagnostics machine,
C0040- right front speed sensor circuit Malfunction.
So I changed the right Hub (did Not work) same issue Especially when I make a right turn or when I start the car It will come on. ???
Thank You.
I left a detailed comment for all interested on this subject on the new discussion page.
The fix for my 2007 Grand Prix was replacing the simple wire harnesses mentioned here.
I used GM AC Delco parts which by the way are beefier than what I took off. Thanks for the meat!
steve572
