Thank You,
GOOD LUCK
P.S. I WILL BE CHECKING THE FORUM FOR YOUR COMMENTS AND HOPEFUL SOLUTIONS TO THESE PROBLEMS.
I contacted GM customer service as I am SICK of spending money on this problem!!! Their answer was, "SORRY, THERE IS NO RECALL ON THIS RPOBLEM FOR ANY OF THESE CARS, BUT, WE WILL HELP YOU SET UP A TIME FOR YOU TO TAKE IT INTO A DEALER AND HAVE DIAGNOSTICS RUN WHICH WILL COST YOU $105.00!) They would not even pay to have the diagnostic test run. So, do not rely on GM Customer Service to help you and they WILL NOT pay for anything as they said there are no recalls for this reoccurring problem!
PS, my ABS light is STILL ON! I will never buy another GM product.
After doing all that, my friend and I bought a new right front sensor wire harness on Amazon for $29.00! We changed out the harness last night (took about 45 minutes) and the light is off! After inspecting the old harness once we removed it, we found that the wires had cracked or broke apart about 4 inches from the sensor connector that connects to the hub sensor. After replacing this harness, the light immediately went off and has stayed off. Take off the wheel, unhook the sensor connection, follow the wire harness to the chassiss just under the radiator. You will see where it splices into the main harness. Cut the old one out and splice the new one in! That simple! You can email me at lancerecruit2002@yahoo.com if you have any questions.
ps anyone have a problem with movement in steering, maybe worn. Just had it greased, problem remains. 10/10/10.
I would recommend taking your vehicle into your dealer of choice to have it checked out. Please keep me updated.
Christina
GM Customer Service
I'm seeing here on the forum that people have had to have this work done a couple of times on their cars. I just have a problem accepting that its not a recall issue with these parts.
Any comments on this, maybe Christine from GM can help us out here.
i have a solution for you that others have pointed out and that works...i had the same problem. the butterfly valve in the throttle body gets dirty and sticks.
this causes the starting problem. all you need to do is take off the hose going from the air filter to the throttle body and look inside the throttle body you will see the butterfly valve right there. all you need to do then is spray some carb/throttle body cleaner right on the butterfly valve and the walls around it and then wipe it off with a rag. this will fix your problem i promise. the ABS/ Traction problem i just started experiencing so i am lost with that and need help also
The stalling only happens when i use command start, and my ABS doesnt come up on the dash behind the steering wheel, it come up on the communication panel, the one above the stereo, not sure if every grand prix has that, and when it comes up there it doesnt stay on long. when it comes up it just states " service abs system"
Im bringing my car to the GM dealer ship as i put extended warrenty on the car and these to problems excisted before, i guess i will see what they say... :lemon: LOL
How did things go at the dealer? Has your issue been addressed?
Christina
GM Customer Service
To start, I'm unsure who you spoke with before but my name is Christina. I apologize you have not received any acknowledgement from GM. I understand that you are not taking your vehicle to the dealer. I understand that seems like a small difference to you; however, in order for GM to look into this and try to assist you, you would need to take your vehicle to the dealer. If you would like to do so, please feel free to email me with your contact information including a good number to reach you, VIN, and current mileage.
Christina
GM Customer Service
There are many qualified mechanics certified on GM at other places than the dealership. It ridiculous to say the dealer is the only one who can diagonose this problem. Why doesn't GM step up like it should? We all know the answer to that one - MONEY out of THEIR pockets isn't something they want to do but its okay for us to spend money out of OUR pockets.
I apologize for you your experience. I will say that GM needs to hear the customers to know there is a problem occurring. I understand you have spoke of your problems on here, but until recently, GM wouldn't be aware of this. I am proof that GM cares to hear their customers. They have put many of us out on forums to help customers like you get to someone who could be of assistance. My name is Christina and I work with customers here on Edmunds. Recalls are formed partly by customer complaints to GM Customer Assistance (the telephone number is in the owners manual). Anyone that is experiencing concerns that are unresolved at the dealer, are encouraged to contact myself via email or GM Customer Assistance via the 800 number in your owners manual. I understand that there are many mechanics that are certified; however, GM only accepts the diagnosis of a GM dealer. This could be for many different reasons; however, most companies do the same thing. GM dealers have a contract with GM, unlike independent mechanics. If you would like please email me with your VIN, current mileage, and concerns. I will do my best to assist you and your situation.
Christina
GM Customer Service
If you would like to send me your VIN I can look to see if there is open recalls for you.
Christina
GM Customer Service
I would hope as a GM customer service rep that you could pass on the stress we all feel over our problems...not that I expect you can do much. GM is about money, otherwise they would have already fixed this!
Christina I sent a separate email regarding the problem. I hope you can respond and assist
Tricia, GM Customer Service.
Been there on "Steering Shafts" commonly known as the ISS, 3 in 30k miles, however @55k it seems to be working..3 batteries in 30k miles, and seems to be okay..Service uses the "first in-first out theory..2006 Pontiac Grand Prix GT
Been thru 53 autos in my life, all Big3 except 2 Porsches..Current GM car is a 2006 Pontiac GT, purchased used at local Caddy dealer w/4300 miles..Traded in a 2002 Olds Intrigue w/120k mi., purchased new, and also had 2 other Intrigues, 1998 and 1999..The 99 and 02 were great little cars, the 98 was repurchased by GM after 26k miles due to steering and brakes issues.
I would not expect too much help from any GM dealer on the extinct Pontiac line, except high money grab..I was using the local dealer, however after 8k miles on Hankook tires purchased and balanced by the GM dealer the rear tires flat spotted due to alignment problems which the dealer had checked previously as OK..Dealers are too lazy to reslot the struts, however I have found that Chevy dealers are trustworthy..had the same problem with the 02 Intrigue and the Chevy dealer after 70k miles reslotted all 4 struts and after another 50k miles all was still in alignment..so I was shafted twice by the Olds/Caddy on prior aligments..
I am not a stop-light jockey, however I do travel fast on the interstates and demand "no shake", so balance+alignment are vital..and at rotation time if the car is smooth, I never rebalance..If shake develops then we check for a missinng weight for they are marked when installed..
In reviewing the recent problems owners are having on this forum, I will chuck the car immediately for it is not worth pumping any amount of money into a dead model..I got this car for 1/2 of original MSRP in June 2007..Pretty car with sunroof, leather, chrome wheels, and Monsoon..black w/tan interior..Only real concern with the car is a front end creak when acceleratoring from a stop..which disappears after a few miles..I live in Venice, Fla and the car never been exposed to snow or pot-holed roads..
Let's face it, the GPGT is a warmed over Chevy Impala with maybe a better suspension, and the supercharged V-6 is fun at the higher speeds and gets the triple-digit test on every interstate venture..comes alive after 60 mph..
My other car is a 2010 Mustang GT w/track pkg...bought used w/1365 miles..
The best Grand Prixs were back in the mid-70s, had a 74, 76, and a 77. LJ coupes with big-block V-8s..great road beasts..
No problem, I would just like to assist you in getting this resolved. I do understand that they want you to have a GM dealer look at the vehicle. This is just a standard operating procedures so we can get technical information and try to resolve your concerns and find a resolution for this. I understand you would prefer a independent mechanic; however, it has to be a GM dealer due to the fact they are contracted with us. There are many different reasons for this. I apologize for any inconvenience. But these cases with Customer Assistance are monitored. The more people that have a case for a particular issue the more attention the issue will get.
Christina
GM Customer Service
I apologize you did not get the resolution you wanted. Every case is handled on a case by case basis. I recommend anyone who is experiencing concerns contact, myself or GM Customer Assistance. This way we can look into your specific situation and address your concerns.
Christina
GM Customer Service
