Buick LeSabre Starting/Stalling Problems
buickgrlbuickgrl Member Posts: 5
edited June 2017 in Buick
I have a 1992 buick lesabre limited and it has lately been acting up. when you press on the accelerator it surges and makes it hard to get up a hill. It also stalls when you are idling and not moving for example waiting at a traffic light. The service engine soon light is almost always on and I haven't been driving it because it isn't safe or dependable on the road. If you have any info on how I can fix it please tell me.
Thanks :confuse:
See Also
Edmunds Answers: Le Sabre Engine Issues
«134567
  • kcwolfpack59kcwolfpack59 Member Posts: 122
    I had a 92 Olds which is the same basic car as yours. Mine did the same thing and it was the coil packs. However, I urge you to take it to a garage so they can check it out. It can be about anything.
  • phull67phull67 Member Posts: 2
    I purchased a 94 with 140k on it a few months back. It's a FL car and in super shape. But it has a funny misfire, sometimes very subtle and sometimes very hard, almost a "bucking", for lack of a better term, and the engine light comes on but will go back off if I shut the car off and start it again. It's even begun stalling every now and then at a traffic light but always starts right back up like nothing happened. It happens at different times; when the engine is cold, when it's hot, when I'm cruising down the highway, when I'm driving in the city, when I accelerate, when I'm stopped at a light. I can't connect the misfire with any given driving condition.
    I've replaced the plugs and wires, air and fuel filters, changed the oil, repaired a leaking vacuum line to the fuel pressure regulator and replaced the crank sensor. I've run a bottle of dry gas through the tank, thinking that maybe some condensation built up from sitting while it was for sale. And a bottle of fuel injector cleaner as well. Nothing has seemed to make the slightest bit of difference.
    Any ideas would be greatly appreciated.
  • dshepherd3dshepherd3 Member Posts: 194
    Get a full scan done to see if the code is in memory, many issues can cause this, bad wire, plug, coil, too lean a mixture, a bad injector and others also. An intermittent or dirty maf can also cause this, again a full scan by a knowledgeable tech should show something.
    Thanks d,
    I have to apologize, I left out the part about the scan.
    A very close friend of mine owns and runs a shop where I have my work done, or do myself if the job is not too hard. The day I brought it in to replace the crank sensor, about 2 months ago, he tried to read the code and could not. I guess in 94 GM installed a newer type of connection in the car where you plug in the reader (under the dash) however the newer reader won't connect to the car. I mean it plugs in of course but the reader doesn't acknowledge the vehicle. We searched for the older style reader connection under the dash and under the hood and could not find one.
    A professional scanner will read this transitional year obd system, Snapon 2500 for one or Actron 9145, you really need the codes here.
  • sizzmansizzman Member Posts: 2
    I am working on 1995 Buick LeSabre. It will run ok for awhile, but then it stalls and is hard to start. Recent work on it was a normal tune up, Spark plugs, wires, gas filter, and air filter. I even dropped the gas tank and cleaned it out. Also, when I rev the engine, I can not get it to go over 4000 rpms. It seems like it gets too much gass or air and starts to choke out until it gets back down to 3500 rpms. I have also cleaned out the port injectors. The check engine light comes on, but Autozone states that there computer reader only does 1996 and newer vehicles. Any ideas on the problem?? Any help is appreciated!!
  • classicbuffclassicbuff Member Posts: 18
    I'm wondering if the problem isn't fuel related. I had a GM that was hard to start when hot (you had to floor the gas pedal) and it turned out to be the fuel pressure regulstor, which, I'm told, is a common GM problem. A weak fuel pump could "starve"the engine above a certain RPM. There's tests for both of them. How about posting what the answer is when you find out?
  • davidrc3davidrc3 Member Posts: 1
    i just bought a 95 lesabre and it runs great, but has one maddening problem. it won't start sometimes unl;ess it's been inused for about at least 4 hours. i mean if it's left overnight, it fires right up, after work, it fires right up, but if i go anywhere, and i'm only there for an hour or two. it may not start at all when i come back. it turns over line normal, it just won't fire up. any suggestions?
  • guestguest Member Posts: 770
    I'm not a mechanic, so take my advice with a grain of salt. When the car won't start, I would pum the gas pedal while it's cranking, to see if the problem is fuel relatd, or ignition(see above). I've heard of problems when the ignition module is hot, also. Good luck!
    You have to determine if it's fuel or spark.
    You can try listening for the fuel pump to prime for two seconds when you turn the key to on without turning it to start. You can do that three times as a way to check if the backflow valve isn't holding pressure after the engine is turned off; three times rebuilds pressure completely in the fuel line.
    You can check for spark by using a spare plug and putting the spark plug wire from the car on it and laying the plug on something solidly attached, grounded, to the motor. Have someone turn key and see if you get spark.
    Pumping the accelerator pedal doesn't do anything in this day of fuel injection. If you think the car is flooded, hold pedal to the floor while cranking, otherwise keep foot off of gas pedal. The days of carburators have different algorithms for troubleshooting.
    You would be able to smell gas at the exhaust pipe if you were flooded.
    You may have an electronic spark control part failing when warm. You may have a crankshaft position sensor or cam position sensor failing. How many miles are on the car?
    The last two guesses are from what I've reach in a Bonneville discussion of higher mileage failures that are odd in behavior, making them difficult to troubleshoot with codes.
  • wingnut691983wingnut691983 Member Posts: 3
    Hi!
    I have been looking for a place to get some help for a 'do it yourselfer' who doesnt want to pour a lot of cash into a 13 year old car. We had a really rainy day last week and one road that I go through to get home from work had a substantial amount of water over it, after going through it (i was probably going 20 or so) I went about 200 feet and the sucker stalled out. After that it would not start, i sat there for 10 minutes or so and then it would start and run fora bout 3 seconds and then stall out. It did that several times. Since the last time it did that it has not started since and will only crank.
    A buddy of mine and I looked at it today, we found that the plugs are not sparking. Took one out and cranked it and nothing. The wires and all are fine. Suspected the coil packs, took them off and took them to auto zone and they tested out fine. The guy at autozone said we might want to check the camshaft sensor which is one the side of the engine down by one of the pulley wheels, said if that gets water in it it will not work and will not spark.
    To "test" that would be 36 bucks for a new one and have never replaced that before so am not even sure I can do it myself so I would like to have some semblance of it being a good idea before I do that. Obviously it wont start so if i need to take it someplace I will have to have it towed. (I was 3 miles away from home so a friend pulled it back to my house with his truck)
    Anyone have any suggestions? Thanks! :sick:
  • msuttonmsutton Member Posts: 1
    I have a 99 lesabre with less than 80,000 miles that just stop running. It was fine when I cranked it in the morning and 2 hours later would not turn over. Could it be a starter problem or water in the crankcase? It does not sound like a starter problem to me. It seems to be based more in the engine. It also misfired before it quit cranking altogether. Help!
  • themarcianthemarcian Member Posts: 4
    When starting my buick after 5 minutes I touched the hose to the radiator from the thermostat and it don't have any pressure. Then I pushed the gas pedal and it stalled.
    How's the battery state of charge? Has battery been replaced since the car was new? You're way past due if not.
    Do the lights dim when you turn the key? Does the battery voltage drop below the orange line on the voltmeter while cranking or belw 10 volts on a digital readout?
    Have you removed and cleaned both battery cables to get off corrosion? Have you cleaned both of the positive cables that piggyback onthe post. Check between them for corrosion and get bare clean metal contact. Check the short lead that grounds on the fender next to the battery. Check the lead at starter for corrosion.
    I'd go with the easiest first. The cables and corrosion have given lots of people trouble. Your mileage is too low for crank position sensor problems and cam sensor.
    Oh wait. When you put the key in, does the security light come on for 10 seconds and then go off or does it flash? Does it go off after 3 minutes. Could be the VATS system not reading the key chip...
    What is the VATS system? The battery and cables are all good. I drove it last night a short distance and as long as you only push the gas slightly the car will keep going, but if you put any kind of pressure on the gas pedal it will stall.
    Antitheft system in the key using a resistor chip. The lock cylinder has two contacts that rub the key on the chip contacts and measure the resistance using a small circuit board in the glovebox area. If the resistance is within parameters from the original setting when the circuit was installed at the factory, the circuit sends Okay signals to the drivetrain computer telling it is okay to operate the starter and the fuel injectors.
    Otherwise the car waits three minutes for a new key to be tried and hopefully get a good reading indicating a real key for the car is inserted.
    If your car is running badly, it needs to be checked. I'm surprised the SES light isn't on. You could have low fuel pressure (fuel filter clogged?), fuel pump going out, you could be in limp mode--but it will not stall above a certain pedal amount, it just doesn't run great so you can get the car home for repair.
    Yours sounds like you need someone with a TechII that can read the codes and who knows how to diagnose the problem--not just the circuit and sensor involved and replace parts without understanding what's happening.
    Engine does turn over. It will even drive, if you push the gas ever so lightly because as soon as you push it with any pressure it stalls. And when the car is running there is no flow in the hose from the thermostat to the radiator. Is there supposed to be something moving through that hose?
    That only opens to flow when the thermostat opens and lets hot water out of the motor to go back to the radiator. That happens when the thermostat water around it gets to 190 deg. F. approx. The motor recirculates water through the heater and probably an internal bypass when the water's not going through the radiator.
    If the motor idles for 10 minutes it may start getting hot enough to send water back to the radiator--depends on outside temp.
    The touchy throttle could be a throttle position sensor on the air intake. It changes resistance as you push down on the throttle and tells the computer how much air you're giving the engine so it can adjust the gas flow. But the piece needs to be tested to see if it's not making contact at certain points along its movement before replacing. It works like a rheostat for you dimmer on a light in the house.
    :blush: Thank you very much. The throttle position sensor was the problem. Now the car runs great.
  • toddcrowthertoddcrowther Member Posts: 3
    My 1989 Buick with the 3800 is hunting for idle, and idling low it sometimes stalls when accelerating during the hunting. This only seems to happen after the car is warmed up.Error code is 34 (Check vacuum and electrics for MAF sensor). The MAF is pretty new. New plugs and wires. I have noticed when the AC is on, the engine doesn't increase the RPM slightly like it used to do before this problem. It runs nicely as long as my foot is on the gas, but won't idle properly. Is there a way to test the throttle position sensor and the idle control motor? What else could this problem be. I don't suspect fuel pressure problems because the car runs well, except at idle. I would appreciate any suggestions or ideas.
  • jyvettejyvette Member Posts: 1
    I own a 1995 Buick Lesabre which has been pretty dependable. It has been in the garage for about a week and today I was going to drive it to work but, it wouldn't start. All the panel lights came on and when I tried to start it I heard a clicking noise but the engine didn't turn over at all.
    This buick has about 160,000 miles on it. I replaced the starter about three years ago, changed the valve cover gaskets last year and had the oil pan gasket replaced about 1 month ago. Regular maintenace items also.
    What do you think I should try first, jumpstarting?
    Yep dead battery or bad battery cables.
    Clean up the cables on the battery post if you see corrosion, then jump start it but DON'T let the alternator do the work of re-charging the battery. Either take it to a station for a slow charge or better yet go buy yourself an inexpensive charger and let it trickle charge the dead battery overnight.
    Please observe safety precautions when jump starting the car.
  • d0rothyd0rothy Member Posts: 3
    I have a 94 Buick Park Ave. Tests show that I need to replace the fuel pump. In looking up replacements, there are two different types, CAC and CRC according to what is stamped on the connector. So, I'll bring in the old pump to compare. Any tips on doing this job with minimum of work. All pressure is off and both fuel lines are disconnected. Is it worth snipping a hole in the trunk floor above the pump for removal and then fabbing a simple patch panel? It just seems it might be little easier than dropping the tank. Thanks in advance.
  • persuazionpersuazion Member Posts: 4
    I have a 99 buick lesabre with 50,000 miles on it and I have noticed when Im at a red light I can feel the car starting to stall but it never does.This is bad especially at night and I can see the headlights dimming from it.It used to do it while only in drive but I have noticed it starting to happen in park too.Also the other day my car would not start at all....wouldnt even turn over.So I wiggled the red cable a little bit even though it was tight and it started right up.What could be causing this.I have some washers inbetween the post and cables to keep the cables tight.Could they be causing this.I dont see any corrosion.THe inside of the cables look kinda greyish white on the ends.I had to take the rubber connector cover off to hook up my ampwire.
    YOu should take off both the positive and negative cables. Clean them completely. The positive has a washer between the two cables that bolt to that post. Clean completely.
    You mentioned an amp. It's possible your amperage load from an amplified is loading the motor too much.
    Another possibility is coking up around the throttle butterfly valve. You can take off the rubber connector that leads the air into the throttle body. Then take of the snapring that holds the honeycomb filter in place. Carefully remove honeycomb, I used two paper clips bent as hooks, and then with a piece of wood and cloth use intake cleaner from a spray can onto the cloth to clean the black soot from around the throttle body interior and the butterfly valve itself. Mine had gotten so I could feel it let go when it would sit overnight and I'd press on the pedal slowly. It disrupts the ability of the air bleed that opens and closes to adjust the idle speed because it' calibrated for a certain air flow rate around the throttle platewhen fully closed. Gum that up and th idle control solenoid can't open up enough at times to bleed enough air
    Some people remove the whole throttle body to do the cleaning. don't use a brush, the fibers can come out because of the solvent. Be sure to get air intake that says it's safe for catalytic converters. Some carburetor type cleaners aren't.
    For others contemplating this.... It is possible to cut a hole and expose the top of the tank. However, to remove the pump, it would have to be a very long hole or the three solid lines to the pump would have to be cut and flared and joined by short pieces of high pressure line and clamps. Probably not worth the trouble. And the floor would have to be patched back up. However, the 99 Park Aves were made with an access panel and designed to be removed from the top of the trunk floor.
    A neighbor replaced his 95 MonteCarlo pump. He placed jackstands under the rear of the car. Removed the bolts on two straps holding the tank. Supported the tank with a small hydraulic jack to lower it and the 5 gallons of fuel in it. A neighbor who had done these before helped and guided. I helped with the lowering and getting the tank back up.
    The caveat is many people say to buy GM pumps only. There has been trouble with some aftermarket pumps. It's a job I'd only want to do once. The Monte had 85K mi. It had been run low on fuel all the time after the guy inherited it from his father.
  • joho4241joho4241 Member Posts: 4
    I have a 2001 Buick Lasabre that will not start.. it just makes a clicking sound when I try to start it and the panel light all come on when I turn the igition on.. I have bought a new a new battery and it still does the same.. put the old battery back in an put a charger on it.. after awhile I tried to start it with the charger in the boost position.. it started,but when I turned it off it would not start again.. It has started several times now in the boost position.. but will no start on its on..any ideas
    Could be a bad starter.
    But you need to go through the battery cables completely to be sure connections are not corroded and are tight. that includes the grounds and at the starter.
    It could be low voltage from the battery not applying the solenoid enough that engages the gear and starts the cranking.
    Park with headlights on where you can see them as in a garage. Turn key. If the click occurs and the lights don't dim as if under load, you may have bad solenoid or bad cable. If the lights are dimmed because the starter is drawing lots of amps while the key is urned to start but nothings happening may be the starter is defective, old, bad, gone.
    The fact that it starts with the charger on boost makes me suspicious of the battery having a bad cell shorting out giving low voltage without the extra power from the boost.
  • beaumontbeaumont Member Posts: 1
    This is a beautiful car and I love it. When there is mist on the windshield the silly thing won't start. It sounds like it wants to but it won't. A few hours later, when the mist is gone, the thing starts right up and runs like a champ! It seems to happen more when it is misty out than when it is straight out raining. We've even sprayed the engine with a hose (in the middle of the day) and it starts right up. I'm pulling my hair out and my wife isn't too happy about this turn of events (with the Buick). The hair loss I can handle! Any help? [please email me directly at beaumont_painter@yahoo.com if you're able to. thanks!]
  • markfainmarkfain Member Posts: 1
    This has occurred twice. Both times were after a longer drive 80+ miles on the freeway. I stopped for gas and when I tried to start again, it started and ran rough, like it was not hitting on a cyclinder or two or flooded. I held the gas petal down, but that did not help. I had it towed to the Buick dealer and they let it sit overnight. When they went to work on it, it started and ran perfectly. They tried the codes and could find nothing. The service manager told me he suspected it "Vapor Locked", but I have not heard of that in years. Last week it did the same thing, after a longer freeway run, I parked in my driveway and later it would not start, acting just like before. I let it sit overnight and the next morning, it started right up and ran perfectly and has since. I take it on shorter trips around town and nothing happens.
    Do you have any idea as to the cause??
  • blueblazblueblaz Member Posts: 1
    Hi I have a 1994 LaSabre with 148,000 miles on it. Runs like a champ, has a 3800. This has happened to me 3 times and I can't figure out what is going on.
    All three times at night and I have stopped for a light or sign and the car just quits, headlights go off, radio goes out, 12 volt power supply (radar detector) is also off, no dash lights, windows won't work. I open the door and the lights go back on as well as all the other things and I am able restart the car.
    I was thinking the issue is in the wiring harness that goes from the car into the door and it is shorting. Funny thing is all the power goes out and no fuses have blown. Any one heard of this. Don't want to start taking stuff apart unless I am on the right track.
  • albaker07albaker07 Member Posts: 1
    background: I drove 30 miles round trip today -- no trouble starting the car at either end. I parked the car and five minutes later my wife tried to start it but it would not turn over. :sick:
    The battery is fine -- 12 v and checked out fine under load at AutoZone. Connections were clean and were cleaned anyhow. 12 v is seen at the fuse box under the rear seat and under the hood. There have been no issues with the car's electrical system or performance.
    With the ignition switch off, the keyless entry works fine. There does not appear to be any change from normal operations when the key is turned to on, i.e., the radio works, wipers wipe, and driving lights turn on automatically (made in Canada). The tranny is in Park.
    What seems very strange is that when the key is turned to start the instrument panel dies and the wipers stop (if I have them turned on), BUT THE HEADLIGHTS KEEP SHINING UNDIMINISHED. When the switch is released back to the on position, the instrument panel come back to life after a second and the wipers start again. The voltage at the battery when the ignition switch is turned to start drops only to 11 v. Now why is that? And where is the problem? :confuse:
    Thanks in advance,
    Al
    P.S. -- I went outside to double check the voltages and had my son man the ignition switch. The first three or four times we still had no crank with a very slight voltage drop from OFF to ON and to START. However, much to my surprise, the next time the car promptly started as did the time after that!! I can upgrade my car from DEAD to TOTALLY UNRELIABLE but I'll admit I am clueless as to what is going on. My mechanic usually wants to see cars when they are symptomatic from an intermittent problem and not when they're working as they should, but that leaves me wondering when and where it will do this again -- hence the hope that someone knows whats wrong so I (or my mechanic) can fix it.
  • carguyroncarguyron Member Posts: 3
    CarGuyRon, has a 1993 that did the same thing two different fixes. 1st was the Mass air flow sensor. 2nd time it was the Prom Chip. However, you can buy a can of Mass Air Flow Sensor spray 1st for about $4.00 dollars and spray it into the throttle body. Your Mass Air Meter is connected to the Air Cleaner by a big hose. Remove the Hose and spray it into the screen grid portion of the Mass air meter. If its bad, it may not respond. It usually is good if the check engine light is not coming on. 2nd if the Prom chip. It's located behind the golve box, next to the Car's computer. A parts store can help ya there. Not too expensive...say $40 ish. But make sure you get the right one as they vary from year to year and even month to month within a build year.
    Finally, if all that fails, it could be a fuel pressure regulator near the fuel injectors. Hope that helps..Ron
    I have a 1993 and have been through 2 engines. Believe it or not, the 1st engine dropped an entire cylinder. It just would not fire right. It was getting fuel but without a rebuild it was toast.
    2nd engine is now doing the same thing, however, if your check engine light is coming on, it is most likely the Mass Air flow sensor. Clean it only with Mass air flow sensor spray or you will ruin it. Next, I had the prom chip go on mine and it did the same thing. That is by the computer behind the glove box. Yep, you have to pull it out. Not a big job, just a few screws but it beats the neck twisting option of trying to dig it out under the dash.
    Sounds like a bad starter wire connection to me. Sometimes if you clean all the connections and add a little grease they start better. Clean both the battery
    posts as well and add some grease there too.
    Finally, if that is not it, you could have a blown head gasket. As it heats up it expands and may be allowing coolant into a cylinder which will make it run rough or not start at all. A compression test will reveal the answer there.
  • slightlinesslightlines Member Posts: 2
    Hello. I'm Jerry and I'm a newbie here.
    I am working on a 1987, 4-door, US-made, Front-Wheel Drive, Buick LeSabre Sedan, with a 3.8 Liter, Transversely Mounted, V-6 engine.
    It has Sequential Fuel Injection and an Automatic Transaxle. The Odometer reading is 112617 miles.
    I got the car from my cousin who has records of service on it from the time he bought it new. It has been well maintained.
    While driving, it stalled at a red light. It was hard to restart, but started within thirty seconds. After driving about two miles, it stalled while I was braking for the next red light.
    The second restart was much slower and it backfired a few times before restarting. I was able to drive it for about another mile when it stalled. I coasted to a stop. It would not restart, and hasn't since. It is in my driveway, now. There was a lot of backfiring, but the starter did turn the engine over. It did seem as though there wasn't any compression, after a few tries, because it seemed to crank over too fast, and the backfiring soon stopped. Now, it justs cranks over and over, but still will not start. After changing the fuel filter, I tried again. No luck.
    Before disconnecting any battery cables or going any further, I plugged-in my SunPro code checker into the ALDL jack. It threw only a code 12 over and over and over.
    So, I checked the spark by removing the wire from the spark plugs, one at a time, on the left bank---the side of the engine closest to the firewall---and grounding-out a 12-volt, simple, probe-type test light to the engine block. Using wooden clothespins to avoid shock, I placed the needle into the end of the spark plug boot and touched the metal contact while my neice cranked on the ignition switch. No fire.
    I only checked only that one side of each coil. There are three coils plugged into the top of the ignition module. I figure that all three of the coils wouldn't go south at the same time, and that if one side was good, the other should be, as well. So I disconnected the negative battery cable and removed the coils and the ignition module. I took it to the auto parts store and had them check it. They checked it three times. They tapped it on the counter to simulate vibrations while they checked it. It checked-out fine. They can't check coils. I would like to know the resistance values for these coils, however, in case I ever need to check one. I understand that the crank position sensor could be faulty, as could the cam position sensor, and the ECM. I need instruction on how to test these, and the proper resistance values that I should obtain with a multimeter.
    I understand that the rubber part of the harmonic balancer could have deteriorated and caused damage to the crankshaft sensor, by wobbling and beating it up. I think that the harmonic balancer can be pulled through the fender well, but I'm not sure. I need as much info as possible before a further undertaking of this repair. I would like to know how to test the crank sensor.
    Haynes and Chiltons manuals do not even approach usefulness for my purposes.
    If anyone can help, or have any ideas or comments, please post them. I have no reliable transportation.
    Thank you for reading this.
    Jerry.
    Not an expert on dead motors. But I've had some experiences. Have you looked inside the valve cover through the oil filler to see if the valves are operating, i.e., is the camshaft turning. If not then the timing chain may have gone on you. The easy cranking without compression might be the clue there.
    I don't recall if the cam sensor or the crankshaft sensor is needed for the basic spark signal. But I'm guess the camshaft is not turning or is way off calibration. Mileage is low for a failure though. Maybe near 200K it might happen.
    I really appreciate that, Keith.
    I'll be sure to do that.
  • intimidatorjd3intimidatorjd3 Member Posts: 3
    I have a 1997 buick lasabre and it too will not start. On my way home from work, it was sputtering like a car that has water in the gas or kind of like the fuel injectors are blocked in some way. Either case, when i got home, I took off a fuel line and turned the key on and its getting gas, the fuel pump is working, the spark plugs are getting a spark at the coil. I am at a lost to why it will crank but not start. Any ideas?? An auto shop told me it could be the EGR valve but thats for emissions and I cant see that as a culprit to it not starting. Does anyone have any ideas that I can check. Sounds a little to me like it jumped time or the timing chain broke..Any suggestions would be helpful :confuse:
    Have you been losing coolant? Lots of vapor out the back when you first start up in the morning? Could be leaking coolant into the intake manifold>
    Or you might have low fuel pressure
    Or you might have an electonic ignition problem
    Or you might have a MAF sensor that's coated with goop giving bad readings.
    There is no water leaking anywhere in or around the engine compartment, or steam out the tail pipe.. We have had the car over a year and in teh morning, it has like vapor which is gone in a few minutes, but it losing water had started saturday and by tuesday the car wouldnt crank. I have had to add water everyday.I noticed that on one of the coils when I took the sparkplug off, it had alot more spark and I mean alot more than the other 5, does that mean anything? Can one coil overcharge or something to that nature that would cause it to not start. Plus one of my codes was random cylinder misfires, what could be the cause of that?
    Is your Buick an '87 or '97? If it's a 97 it could be an intake manifold leak around the seals at the throttle body or onto the lower metal intake portion.
    The three coils are independent. Random misfires could be water fouling the plugs.
    My car is a 97 buick lasabre and I just found out that is needs an upper intake manifold. That explains where the water is going, which was out the tail pipe and I just didnt see that. I am somewhat of a mechanic...lol....How hard is it to replace the part myself as the garage wants a 700.00 to fix it. Can someone explain the installation of that part so I can save some money
    Check to see if your UIM has the three round date stamps on top. One is the year, one is the month, and the date if I recall to see if yours is the original factory UIM.
    I can get you a description of doing it. I have helped. It is doable if you work carefully and slowly and label the small screws and things that come out so you know where they go back. Unbolting the brackets for the injectors and wiggling the to get them loosened so they pop out for you is the most tedius. The exhaust crossover pipe does not have to be removed if yours is like the 98 I helped work on.
    The throttle body is held on the end of the UIM by 3 small bolts. One is partially blocked by a small black bracke that helps lift the weight of the throttle body. That bracket can be tapped toward the front of the car out from under the small bolt and then it can be accessed straight on from the right.
    You will have to decide whether you are going to redo the gaskets between the lower metal intake and the block/heads. If so it becomes a bigger job with more tedious pieces. The car I worked on did not change them.
    The Dorman UIM sold by Advance Auto and others has replacement EGR pipes that come up out of the Lower Intake Manifold and carry the hot gases through part of the Plastic UIM. These are smaller than the originals and leave more room around the outside for intake air coming into the manifold to cool the pipe and the plastic. I'd recommend that kit. The little pipe is a press fit into the aluminum LIM plate.
    Be sure to drain the oil out as soon as possible. If coolant gets into the oil rather than burning away completely it is ruinous to the bearings. Do not continue to drive the car.
    Drain the oil even if you're not ready to work on it and put in a few quarts of cheap oil to flush out any coolant.
    Expect the spark plugs to need replacing also. They can be salvaged by cleaning while they're out. But if you're due for plugs, just change them.
    Occasionally people complain that oxygen sensors are damaged by coolant going out the exhaust. Dn't change it unless there are symptoms afterwards.
  • folderqueenfolderqueen Member Posts: 7
    I have a 2000 Buick Lesabre. The check engine light has been on for a while and I was going to take it into the shop this week. Last week, the car wouldn't start. I jiggled the ignition switch and it started. It worked fine for 4 days. Then one day it wouldn't start again. It will not take a jump. I jiggled the ignition switch and nothing. I took it to the shop and they said the neutral safety switch needed replacing, but they didn't work on transmissions, so I needed to take it to a transmission shop. They have run all kinds of tests on it, and don't know why it won't start. It is acting like it did one time when I accidentally put the spare key in it that doesn't have the computer chip in it. You just turn the key and it does nothing except make a faint clicking noise. The transmission shop is taking it to the dealership tomorrow. Does anybody have any idea of what might be wrong?
    I know when funny things start happening it can be a weak battery or poor connections at the ground under the rear seat next to the battery. The cables at the battery should be checked. The battery itself should be checked. If it's the original you have an 8-year old battery. It may be newer if it's been replaced.
    From what I've read from other H-body cars including Bonnevilles and LeSabres, strange things happening means look first to the battery and connections to be sure a low or erratic voltage there isn't hurting the systems. The starter not working one day and then working again could be that.
    Well, after having my car in the 3rd shop to try and figure out why it won't start, I was told today that it was the security module that is bad. I guess it was disabling the car and not allowing it to start. I am glad that they finally found out what was wrong with it, and hopefully they will be able to get it fixed tomorrow!!
    Was there a difference in skill level or effort or anything about the third shop that made them capable of finding the problem that wasn't there in the first shops? Was the third shop a dealership which usually has more knowledge about quirks that develop in cars via their companywide information sharing?
