Mine has a couple of little issues, nothing bugging me enough yet to take it into the dealer, just passed 16k today.
Thank You!!
http://abcnews.go.com/GMA/story?id=3401052&page=1
If you've had this problem, please contact me at mvandevelde@wpxi.com
Can you describe what type of foam, where you got it, roughly what it cost, where you put it in, and why you chose to not put any around the front wheels? My Goodyear tires are almost deafening going down the road. I'd like to try adding some noise deadener to our Uplander, but don't know what to get and where to start.
Bill P.
hlfriesz@yahoo.com
Thanks!!
Do I accept this vehicle back, repaired? My fear is that it's not safe. I have had many of the issues I have read about on this site already and was hating my van already.
After seeing all the other posts from others regarding the electrical problems, please pull the rear access panel and inspect the components back there for any sign of melting, etc.
By the way, to fix sliding doors not shutting, clean the contacts on the car where the door meeets them. They have to be cleaned with a dry paper towel - do not use water!!
~A concerned mother
~A concerned mother
I noticed that when I turn the key on and wait a few seconds before starting I have no gremlins compared to when I start the car without waiting. I attribute this to letting the computers synch and boot up. Sometimes my doors won't open, cruise doesn't work, or the radio acts up or doesn't work at all. Doesn't happen when I wait 5 seconds though. Try it.
The fire was caused by a short that either didn't trip the breaker or burned out the breaker on the wire harness controlling the rear passenger sliding power door. Since I see so many complaints from people about these doors, I recommend that everyone get this wire harness checked out and insure the breaker is okay.
GM jacked me around and took a month to decide it was manufacturer's defect, then I finally got the van back 55 days later! I'm working with Krohn & Moss to sue GM under a particular lemon law that has to do with this. I have had an independent inspection of the van prior to Chevy fixing it and the inspecter agrees that GM is totally at fault. By the way, Krohn & Moss specializes in this type of law suit and I think they have offices all over the country. Mine is in Chicago. Don't let these big bullies get away with jerking thier customers around! :mad:
142geo
I sued GM through Krohn & Moss in Chicago. It took months, but I have finally settled with GM for $11,000. Unfortunately, the lawyers got $4,000, but I didn't have to do anything regardign the lawsuit, so I guess that's fair. I;m just happy to make them pay. Had I taken the time to go to court, the settlement would have been higher, but so would the legal fees. I recommend contacting a lawyer to see if they will take your case on contingency, so you don't pay anything win or lose.
Over the course of the last 3 years, I have experienced off and on problems with the side doors flying open while driving, and the side doors not latching shut completely. I have taken it into the dealer three times, and the problem has always recurred. THe last time the chiming mysteriously stopped the morning I was driivng it in there to get fixed! It worked just fine for them, so all they did was clean the tracks and the sensors and it was "fixed". (Yeah right). That was Thursday. Suddenly Friday night the doors wouldn't close again and the chimes started dinging. Sometimes it's just one door and sometimes it's both. Sometimes the bells go constantly while driving. I took a 6 hour road trip with my 5 children with the bells ringing nonstop!!!! We eventually decided that we couldn't take it anymore and I made the kids climb in and out the front doors. Imagine-- 5 kids climbing in and out of the front doors for every potty break, every food break, etc. for 6 hours!
So I'll be taking it back into the dealership on Monday.......I am very frustrated. I had NO idea this was a common problem among Uplander owners. I'm going to videotape the doors not shutting all the way and take it to the service department at the dealership so that there is proof. At this point, they think I'm just imagining it or something.
How do we get them (GM) to deal with this problem seriously? I have 55,000 miles on this thing and my warranty is expired. The fact that this problem occurred on day one of purchase proves that this isn't a wear and tear issue. I want it FIXED now, or I want a new vehicle. NOT a GM. Any ideas? Suggestions?
Our '05 Uplander has 49K miles and in the past month or so has occasionally had the situation where the door is almost closed, then bounces back. Usually the next attempt, it will close. I am sort-of interested in cars, and this a.m. I did a couple 'tricks' to ours...one, I took an eraser and 'erased' the gunk off the brass-colored contact points on the body near the front of the power door (I think there's eight little brass-colored squares that I did this too....someone told me years ago to do this every so often), and I also cut a tiny little piece of the fat rubber molding off along the bottom of the door opening, near the plastic trim on the body where the door would meet the body. I cut a tiny little piece off of the molding with a scissors, that was jutting out a bit and overlapping the rest of the molding, which made me wonder if the sensor was seeing this as an obstruction. I also cleaned with a wet paper towel, the door track and all kinds of dirt and gunk were down there, as well as a couple of coins. We'll see if this does anything!
Bill
If the door itself is improperly adjusted it may hit the body, usually at the very top at the back and until enough paint is chipped away it will sometimes cause the door to stop opening the first time you hit the swtich.
Bill
Ours was under the factory warranty which just expired. Because of these issues and the feeling I got that my local dealer no longer had competant mechanics we bought the extended warranty for a couple more years. I grew up working on computerized cars but to do so today requires a $3500 scanner and access to GM for the latest downloadable updates and such. Frustrating. I'd rather do the work myself.
James
Bill
Also on the Headlight flickering if anyone has this problem, there is a cure to this in hooking up a resistor in line with the alternator, which our dealership did approx a year ago to fix the problem. GM doesn't offer the part, so they had to purchase it from an outside vender. So, I know this can be fixed easily.... The dealer can call their GM tech support to get the information in this..
Allen
My driver's side power sliding door issue was mostly fixed, it still acts up because its out of alignment, the body and door panels don't line up anymore. About 1 in 10 times the door will give us trouble opening or closing, it's catching on the rear pillar just as it opens or closes up top. When it gets worse we've decided to take it to another dealership who hopefully has better trained mechanics.
James
James
So I took it back to the dealership, left the van running just to make sure they could witness the problem for real, brought the head service rep. out to see it, and showed him that the problem continues. He seemed just as frustrated as I am.
I've been calling GM all week now to try to get in touch with the same customer service agent (Martin Fischman) who spent so much time with me trying to get this resolved. I've left several messages and so far, no call back from him!
I am BEYOND frustrated at this point. GM needs to fix this problem permanently, or they need to replace our van. Period. I guarantee you that if one of their people had to drive around 24/7 with that dinging noise going off non stop, something would be done to fix it. This is simply unacceptable.
Not being familiar with the specifics of everyone else's issues with Uplander doors, this may or may not work for you, but so far it's worked for me.
Before you try to do any fixes yourself, be sure to talk to a reputable automotive repair professional to see if this step is even appropriate for your Uplander door problems. Maybe your local mechanic will be able to help where GM dealers aren't. Good luck!
My name is David Jones and I have the exact same problem with my sliding doors dinging all the time. Do you happen to have your GM case number still? If so, I can call GM and reference that case number and tell them I have the same problem.
Thanks so much!
