Visitor Agreement.
Also, the rear wiper is not operating although the washer fluid pump for the rear window is. Again, fuse(s) are fine.
Thank you,
Lyman
Now, once again, the battery will not stay charged and a charging system check revealed that the alternator was supplying 0 charge to the battery.
Throughout our hot dry summer the van seemed to run like a charm. Windows worked, no crazy flashing of lights, AC worked. Since we have experienced rain and cold here, the problems have all started again. It must be something that is being affected by the moisture and cold.
Any suggestions any one can give would be appreciated.">link title
Parking lights, front, back, or both, sometimes stay on after engine is off and leaving car.
Blower and Inside Lights sometimes turn on by themselves.
Right, back Signal Light won't work at all even though I've tried new bulbs.
Clicking Noise left of steering wheel.
Right, Front Window Sprayer shoots too narrow a stream.
Any ideas on what I can do to repair any or all of these problems?
Thank you, Rob
Try lifting the brake pedal to see if your lights go off.
If they do you need to lubricate the pedal pivot with lithium greese.
It gets dry and doesn"t let the pedal return spring do it's job.
http://ww2.justanswer.com/uploads/tepetty3/2010-10-08_191739_tsb02-13-09.pdf
I purchased an REM from ebay that has all the same code numbers, save for the serial number so it should have the same programming as my original, I just have not tested it yet. But yes, the REM has a programmable computer that, if you did not buy one that has the same programming as your old one, may not work as expected and you will need to have its memory re-programmed by a dealer with the appropriate equipment and software/firmware version.
To make a long, sad story short, the battery discharge issue was all due to me not driving van enough. I only go about 1 mile each way to and from work, and over a period of 3 years the battery just did not get charged enough. I've only driven it 54K miles in the 12 years I've owned it, that's only 4500/year...My bad.
I am experiencing the same exact problem with my 2003 ford windstar lx
Ayoola.
Next, check for ignition spark by removing one of the spark plug wires from a convenient plug and use a neon tester. Connect the tester and crank the engine, you should see the bulb flash very briefly for each power stroke for that cylinder. If it flashes you know your ignition driver and coil is working. If you get no spark replace the coil pack module, mine was about $75 from Autozone. If you are getting a spark, the only thing left is to check the injector activation.
Have someone crank the engine for 8 seconds (no more that 10 sec or the starter can be damaged) while you take a whiff at the tail pipe. If you don't smell strong gas fumes during the first 8 sec crank, wait 30 seconds and crank it again for 8 seconds. If you don't smell anything you know the computer is not opening up the injectors and you will need to get a readout of your van's computer chip to see what's going on...CAUTION: If this gas ignites while you are checking for fumes you can be hurt, so be careful how you proceed with this check!
If you have confirmed the fuel pump is working, spark is there and the injectors are activating you will need to obtain a readout from your van's computer to assist you in troubleshooting. Most engines that have been running OK and just stop usually do so because either the fuel delivery or the ignition spark has quit working.
My radio and power windows are fed by a relay that allow them to be used for a few minutes after the ignition is shut off, perhaps there is problem with your relay, but that does not explain why your remote entry is not working.
One thing I have on my 2001 is a fuse you can pull under the dash sort of in the middle of the fuse panel. This particular fuse can be disconnected without removing the cover via a small knob that when pulled, disconnects the fuse from its socket. This will kill the radio and the remote key entry receiver.
This fuse is supposed to be pulled if you are going to be away for several weeks so your battery does not go dead. MAKE SURE this fuse is plugged back in all the way, perhaps somebody pulled it when replacing your battery and forgot to push it back in.
Other than the above I don't know what else to tell you. Hope this helps.
How can I make reset , is it programing.
I have rebuilt my van and now this is happening.
I also have both the brake warning lamps on & these also are being ignored as I have had system thoroughly checked out only to find that it is sensors @ fault & not the system. Door & window problems, first clean the door pillar contacts before tearing down the doors to replace solenoids etc.
Thanks...
2000 ford windstar cannot find where a two wire plug goes after removing the cowl. Looks like maybe for a hood switch it is a 2 wire violet with orange stripe wire and a black wire that ties into the wire bundle that goes to the wiper motor. Best that I can tell the van does not have a switch? 6-30-2000 build date. I just do not remember seeing this wire before and do not remember unplugging it from anything. Please let me know if a 6-30-2000 build date Ford Windstar would have the hood switch or not. There is not a underhood light on this van I believe the hood switch would be part of the security system maybe? Security system seems to work just fine.
