Ford Windstar Electrical Problems
                    When I close the tailgate or side door the delay relay does not always work.  Sometimes the interior lights will go out and other times they will not.  Any ideas of a resolution for this?
Windstar - door ajar & interior lights problem
Thanks much, Le
Bill D
That fixed the problem.
ABS light - ON
Parking Light - ON
OD off light - flashing
Spedometer - not working
Odometer - not working displays ------
Does anybody have any ideas? As I said, all of this came on or quit working at the same time.
Let me know. Thanks.
Battery light on
ABS brake light on
Airbag light on
brake light on
radio went on & off
head lights, brake lights, signal lights went off
And the van started to hesitate as we were 1 mile from home.
Would like any information. Thanks
I took it back to garage and they gave up. They think it is a bad module but are reluctant to spend any more time or money on this repair.
Any ideas as to what is causing this erroneous reading? The compass is working fine BTW!!
I started my Ford 1995 windstar and there was a wiff of smoke coming from behind the steering wheel maybe from the starter switch assembly. I turned it off and waited for the smoke to dissipate (5 minutes). Then I started the vehicle and made it home (45 minute drive) Later the van turns over well with a healthy battery but the engine does not fire. Just like a no gas situation. The starter tries but the engine just does not run. What should I investigate?
Please also note that I had recently changed my starter solenoid after what seemed like a dead battery situation only that all the lights worked well and strong. The vehicle worked well for a week after the solenoid change before the smoking issue above.
ABS light - ON
Parking Light - ON
The 10amp fuse that controls all of this keeps blowing. I had a service tech unplug part of my wire harness under the air filter box from a square aluminum box. This fixed the problem for about 5 miles! So i left the wire unplugged from the box and took the van to another service tech that blamed a leak from the master cylinder. he fixed the leak left the wire unplugged and the fuse quit blowing and all gages started working again. the problem that remains is now because the wire is still unplugged i have no horn or cruise control and when I plug the wire back in to the box i blow the fuse again.
Good Luck.
Has it been to a Ford dealer for a diagnosis?
The interior dome lights coming on at will even when the switch is in the off position.
The “Liftgate ajar” light coming on even when the liftgate is closed.
The “right side door opening at will” or refusing to close, and having to be kept locked to keep this from occurring.
The Battery going completely dead even after brand new batteries have been put in.
We have had it into Ford so many times in the last few weeks, and had to have it towed there again this morning (fourth time in two weeks). Has anyone been able to find out what is causing their problems, that might help?
We have had it into Ford so many times in the last few weeks, and had to have it towed there again this morning (fourth time in two weeks). Did you find out anything? They told us yesterday they cannot find anything wrong, have tested all the "modules??".
My van still acts up with the internal dome lights,door ajar warning and the annoying ding ding ding as if the door was open.
I wonder why there is no class action suit against Ford for such poor vehicles. I am sure there are many more Windstar owners facing problems with the vans.
The book and the position of each fuse however did not make sense. I was really confused by the diagram and what I saw. There is no orienataion and any way I looked at it, it seemed different from the book. Good luck.
Owner of a Fix Or Repair Daily
Sorry could not help it.
Seriously, Are you in a colder region? Could temperature have something to do with it?
Can't think of anything else. Maybe standby a wooden stake, silver bullets in your gun and some holy water.
Any ideas how to turn off the theft light?
Would low battery voltage cause this and should I have new alternator checked since the dim head lights are a symptom of a bad alt.? none of these issues were present prior to new alternator.
What did u do to fix the problem? Thanks.
