Volkswagen Jetta Audio/Entertainment Questions
in Volkswagen
This car is my second VW. VW's are known for their radios. This Jetta 2.5 has by far the worst FM reception of any car I have ever experienced. I have contacted VW, and the dealer has looked at it twice and tells me it is functioning fine. I am extremely disappointed with VW's response thus far, as they don't seem to have a solution for me. I am told it is not possible to put an external antenna on the car, and according to the dealer they can't or won't put a different radio in unless it was ordered from the factory. I feel that the Radio and/or the window antenna are poorly designed. I feel VW who markets the car as having an outstanding stereo should be more responsive to this problem. Are others having problems with their radios?
I've done a bunch of research, and definitely found that there are probably several options that would hook into the place in the back of my wagon that is reserved for a CD changer. The problems I see are that I'd either have to leave the iPod in the little compartment back there, or have a long cable somehow snaked up to the front of the car.
Has anyone here found a solution they could recommend, hopefully including a website link or something? I would very much appreciate it!!
John
http://stores.ebay.com/Risefull-Direct
My XM would always go “out” when I passed into my garage only when I passed the metal frame for the garage door then it would reconnect once in the garage.
Not much info on the web; the only thing I can think of in my case is when I put the package in the trunk and slamed the trunk shut maybe the wiring to the tuner came loose?
Does anyone know where the tuner is in the trunk? I have not explored yet, and also have not tried the radio yet after the car has been off all nite, will find out shortly.
I think you get a different message if the radio is not picking up the sat, but maybe I am wrong this is brand new to me......anyone have any ideas? Going to call the dealer today and see what they have to say about it.
Mike in TX
Strange. I found the tuner in the trunk and no wires seemed to be loose or anything. I need to call my salesperson anyway so I will see if the dealership knows anything about this issue. Anyone else with the "no sat radio" message? Please post and let me know......
People have similar problems with other satellite based systems such as GPS - although GPS has become much more reliable over the years due to improvements in the satellite coverage.
It may also have something to do with location as I live in Texas. Perhaps Sirius coverage is better on the east and west coasts?
It would be unrealistic to assume Sirius or XM has "perfect signal coverage" and immediately blame the car.
Hope that helps!
At any rate, do you know if this message means there is no or weak signal or does it mean there is a problem with the connection from the tuner in the trunk up to the radio?
I was thinking that if the radio was not getting a signal it would say something like "no signal" rather than the one I am getting?
Like you say, if it is just sporatic I can live with it but I want to make sure there is no issue with the hardware.....
Thanks again
Mike
My question is: can I get a satellite radio for my car (the same or similar to the factory one)? I do not want to buy another receiver to plug into my CD dash, I want to keep my car as original as possible.
Also, how difficult is to install the ipod adapter? I can get one but they want to charge me up to 100 usd for the installation.
Jay
Probably cancel mine soon as well.
Ben
Although I know that its a feature in the car but I want to know if there is a way to turn it off. I called the dealer to see if he could tell me but he really wasnt that much help. So if there is someone who knows some kind of way to turn it off or control it please let me know.
Kiyah
As for most of the "complaints" in these forums... the answer is READ YOUR OWNERS MANUAL FROM COVER TO COVER. I am certain you will learn a lot about your new car that you did not even know existed.
Thank you !
The details on how to unlock the radio from "safe mode" are spelled out in the owners manual.
There is a unique "code" for your vehicle that has to be entered.... lets hope you have not lost your radio code.
Your only recourse may be to take it to dealership to have radio unlocked. Dont forget to INSIST that they give you the radio code when they are done.
======SAFE MODE INSTRUCTIONS============================
* Turn on radio -- the word "SAFE" will be displayed.
* First press the MODE button and then press the SCAN button and hold them down simultaneously until "1000" appears in the frequency display. Release the buttons. Do not, under any circumstance, continue holding the buttons down or press them once again. This would cause the radio to take the number "1000" as the code number.
* Using the first four radio station buttons, enter the code number found on your Radio Card. Use button 1 to set the first digit of the four digit code, button 2 to set the second digit, etc. The first digit of a four digit code must be "1". If your code number has three digits, the first digit on display must be set blank.
* Once the code is shown on the display, press and hold the MODE button and SCAN button simultaneously until the word "SAFE" appears in the frequency display. Release the buttons. A radio station frequency will automatically be displayed. The radio will now play once again.
If, when cancelling the electronic lock-up, a wrong code number is entered by mistake, the word "SAFE" will appear in the frequency display first blinking, and then continuous.
You can now repeat the entire cancelling procedure but only once. The number of attempts will be shown in display.
If the wrong code number should be entered again, your radio will be locked up for approximately one hour. The radio will not play. Leave the radio switched on. After an hour, you can cancel the electronic lock-up as previously described.
This cycle, two attemps - one hour lock-up continues again.
Too bad an "ipod" does not really play "mp3" files... an "ipod" only plays only the special propriatory files which Apple has licence for. (quicktime files)
Now on to your original question:
If the owners manual for your car audio system does not mention the ability to play/control a music device, then it most likely does not have that ability built-into it.
If your current car radio does NOT have this built-into it... There are several "options" for folks that wish to listen to the music from their iPods on a VW.
In order of cost; (also better fidelity as you move up)
1) FM transmitter.
2) Basic "cut in" to the antenna wire.
3) Possible conneciton (replacement) to the trunk-mounted CD player/music-stroage device.
The #3 above has the ability to CONTROL an iPod which can be hidden away in the glovebox. You would have access to the playists and some other features of the iPod right from the radio controls. (The radio "thinks" it is controling a trunk-mounted CD player)
Here is how I would approach it.
1) Go back to that salesman and insist that they show you how to use the "bill of goods" they sold you.
2) Read your cars owners manual from cover-to-cover at least twice. (There are features that you dont even know about!!)
3) Spend some time in a "Best Buy" or "Circuit City" in the car-audio section. They are TRAINED to sell you somthing that works. (and install it too)
...but beware - in the end they are SALES people and I often catch them trying to give me a line of crap. Given I am trained in electronics and computers - I can tell when they are feeding me BS. (Apparently, you may not fare as well)
to get some sort of response pretty quickly. Thank you.
I have never experianced that issue but occasionaly when I start my car, it reverts back to the preview channel. Not sure if we have the same radio but I have a 2005 2.5 "NEW" Jetta radio without NAV.
What are you talking about? Obviously you have never looked at the tech specs for them -- let alone use one. So all the MP3 files....yes, MP3....I have on my current iPod aren't there? They don't exist? I'm not talking about what I've purchased from iTunes. These are the MP3s I've ripped from ~100 CDs.
Apparently you are not trained in all electronics. Please do some research.
FYI, here's what the iPod does play:
AAC (16 to 320 Kbps), Protected AAC (from iTunes Store), MP3 (16 to 320 Kbps), MP3 VBR, Audible (formats 2, 3 and 4), Apple Lossless, AIFF and WAV
BTW WRT my Jetta Stereo... It was just a fuse in the dash behind the deck. The dealership just pulled the deck out of the dash and replaced the fuse for me today. No charge!
Your files are NOT "mp3" format when stored in the Ipod unit. Interanlly to the Ipod unit, all files are stored as Apple propriatory files. The Ipod software converts them all before storage into the unit. (HINT: The instructions say you must not just copy files to the unit... only use special software to "synchronize" your music to the unit.)
It is also unkind (and closed-minded) of you to question over 25 years of circuit design and software development. Believe me, I KNOW how binary files are stored, retrieved and processed. I have to think in binary every day I go to work.
If you TRULY care to learn, here is a website which describes what MP3 means. http://www.mp3-tech.org/
I guess if you want to call an iPod an "MP3 Player" ... that is OK.... but PLEASE dont question the technical folks that actually know how it is designed and behaves internally. We will go on and continue to design technical marvels for the masses irreguardless if you have no clue how they really work.
While you are trying to teach us about technoligies - Would you care to describe to us the differences between flatpanel display technologies? I would love to hear you describe the difference between;
*)Liquid Crystal Display (LCD)
*)Plasma
*)Digital Light Processing (DLP)
OMG!
You are as mistaken as you can be! Talk about being "receptive of technical truths"! I can show you all the music files on my iPod (even though Apple does put them in a hidden folder; is that what's confusing you possibly?); they are most definitely MP3 files, pure and simple.
Are you possibly confused by the fact that iTunes installs itself with the default conversion preference set to Apple's proprietary 'AAC' format? That's all I can imagine... My preferences are set to encode 192kbps VBR MP3s, just as anyone else can do as well, and that is *exactly* what it does.
With all due respect, and I am in no way questioning your knowledge or abilities in any other area, but you are most definitely misinformed (or, dare I say it, closed-minded?) about iPods and how many different formats in which they can store files. And pardon me, but describing "what MP3 means" really doesn't have a thing to do with whether or not an iPod can store files in that format, does it? You may be an expert in circuit design and software development, with an impressive ability to "think in binary every day", but that does not automatically bestow upon you an innate understanding of the iPod!!
I'm sorry, but I've never heard a more outrageous claim about iPods, though I've heard lots of stories Do yourself a favor, bpeebles, and call an Apple repair shop and ask a tech, and they'll set you straight.
Sincerely,
John
http://pag.csail.mit.edu/~adonovan/hacks/ipod.html
iTunes is not needed (thereby voiding your conversion claim) and the unit plays MP3 files just fine.
Your 25 years of circuit design and software development were never in question -- Simply your knowledge of iPods.
What do different display technologies have to do with the discussion at hand? Shall I ask you to describe A man-in-the-middle attack, Cross-site-scripting, or a buffer overflow? No, because it's irrelevant.
The only thing I can think of that comes remotely close to accurate in regards to your iPod knowledge is how it handles songs purchased from the iTunes store. YES, those are protected and proprietary and NO, they are not MP3s. I never disputed that as everyone is well aware of that fact. The files you rip from your own CDs or Podcasts downloaded from the web remain in MP3 format (or WAV or AAC, or whichever other audio format you choose to encode with that the iPod recognizes).
Being the technical-type, I felt obliged to check in to what you were suggesting. I have done some research and apparently the current generation of Ipod does INDEED store and play MP3 files.
I was more familiar with older generations of iPod and was not aware that apple must have obtained licensing for their newest generation of products.
It is unfortunate that as the iPod product line has gained capabilitues.... it has also lost some too. The battery is no longer a user-replacable item and the unit must be returned to Apple for battery replacment. (This is according to Apple.)
You don't have to go to Apple to replace your battery. There are and have been plenty of 3rd parties selling them:
http://www.pdasmart.com/ipodpartscenter5g.htm
http://eshop.macsales.com/shop/ipod/batteryreplacement/
http://www.ipodjuice.com/
thx
fromda314
Home of the World Champion St louis Cardinals
I just changed the tape player for my 1999 (newer model) for cd player. It was easy after i got online instructions.
Also, I have never heard of Bose and VW parterning up.... Are you certain yours is not a "MONSOON" radio.
You can try this... but some VW radios are different.
*)Hold down MODE and SCAN together ‘til 0000 appears
*)Use preset buttons 1-4 to enter code (Use button #1 to enter first digit, button #2 to enter 2nd, etc.)
*)Hold MODE and SCAN together again until the radio turns back on
*)Enjoy the ride filled with music!
i bought the car used and i don't have the owners manual. thanks
