Ford Mustang Electrical Problems
                    I started the car yesterday and the radio was turning on and off (by it self) and the electric windows would not work.The mirrors still work and all guages work. It sounds like a relay is turning off and on,any one seen this before.Thanks for any help.
DW
                        DW
Daniel
http://www.alldata.com/tsb/Ford/index-issue.html
The stereo (shaker 500) suddenly becomes sluggish (it takes 30+ seconds to change volume am/fm or turn off. If turned off while in this state it will not come back on. Let it set for a few hours and all is fine.
Occasionally, after driving the car will not start while hot.
Occasionally, while driving the transmission makes poor shift decisions and either doesn't downshift when accelerating (even at WOT) or just downshifts to remind me it is there while in cruise on a flat surface.
Occasionally, after driving a short distance and coming to a stop when starting to accelerate the car stumbles (hard almost stalling) then after a few seconds, takes off.
These are the frustrating problems not including the list of things that the dealer can fix:
Left speaker has a harmonic vibration.
Right door rattles.
Weather-strip doesn't seal against the convertible top.
Convertible top has a listing that causes a rattle at highway speeds(front listing).
CD Player skips unless the disc is new and 100% dust free.
Oy!
:sick:
Your stumbling has been noticed by others. There is a tsb for the fuel system. It also could be due to the drive by wire throttle.
There are many sites that list the tsb's. do a search.
I havent had any transmission issues. But many mod their mustang to override the computer to get rid of throttle lag, shift points, etc.
My current car (not a Mustang) exhibited the exact SAME symptoms shortly after initial purchase (nearly stalling out when trying to accelerate; essentially just falling on it's face when I gave it gas and then suddenly going). Dealer's thought it was bad gas/wrong gas yada yada yada.
Finally they replaced the O2 sensor (essentially the same as your Mass Air Flow Sensor). The car IMMEDIATELY ran much much better and hasn't done the stalling thing again. And it's been 5-years and over a 100k miles since that O2 sensor was replaced.
Try to have a little faith.
A car with bad MAS typically runs really badly. I personally have never seen bad O2 sensors make a car run badly. (A bad O2 sensor will light the "check enging" light and can cause other problems like high emissions and cataltic converter damage, but the computers in the newer cars seem to keep the engine running smoothly via an "open loop" mode.)
In Aug of 05, with 5700 miles, brakes squealing. All 4 brake calipers had corrosion on them.
Feb of 06, 9062 miles. Several problems. Car is getting worse. Transmission slips when starting from a complete stop. Dealer couldn't find anything wrong. Replaced a few parts. Interior trunk lock and linkage had to be replaced. Right front dashboard rattled and was very noisy. Dealer re adjusted dash. Rattle came back. The tires began to loose 5 to 10 lbs of air per week. Dealer said the inside of rims were oxidized and they cleaned them. That didn't last long.
April of 06, 10,315 miles. Had to have car put on flat bed and towed into dealer. Electrical system went haywire. Couldn't start car but all lights on dash were blinking.
Had to have new battery??? Also had same issues as in Feb of 06. All tires loosing air, rattle in dash getting worse, transmission still lurching from a stop. Dealer said all was fixed when i picked up car. Yeah right!!!
August of 06, 12,413 miles. Same issues as before, trans slipping, tires loosing air, rattle in dash constant and the big one, engine grinds when starting. That one they had to replace the timing chain. At this time, dealer assured me that all other problems were fixed 100%.
As of today, the rattle in the dash is the worse it has ever been. All tires are still loosing air, have to keep a tire gauge with me at all times, and the trans still slips. I call customer service, that was a joke.
I also have the gas shut off problem which i will address when i take my car in on monday.
My car is going back to the shop on Monday. Anyone have any problems like this.
Mark
Mark.
Also, the car has a battery saver that prevents the lights from discharging the battery, you can put the bulbs back.
Mark
PCV valve gone bad?
Air filter?
Fuel filter?
Spark plugs/wires/distributor?
Injectors?
Cylinder compression leak?
WHY--NOBODY KNOWS-NO EXCESSIVE PARASTIC DRAIN EITHER ???
I had to give the dealer a chance to prove me wrong before I contacted Ford. I am up to a "customer service laison". He seems to be willing to help and said that they will put their advanced testing methods to work but at the same time, the dealer calls and tells me that they put another new battery in it and I can come get my car! Check out this site http://www.moddedmustangs.com/forums/viewtopic.php?p=159130#159130
Just a heads-up. -Ed
1) Did it ever work (for you)?
2) if yes, When and in what circumstance did it stop working?
3) Did you check the fuses?
-Special Ed
mark
and yeah theyre all good
Things to look for after it rains:
Pull back the carpet from under the kick panel on the passenger side (and this might seem funny) and sniff. (Do this on the drivers side too as I have heard of this area leaking as well as the passenger side. You might smell a moldy smell.
If you do smell something, look up over the large black box and the wiring harness above it. Check the entire wiring harness. You might even see water dripping from the harness. (My leak resulted in ice cicles hanging from the wiring harness.)
Check the padding under the carpet for dampness and squeeze it. If you have a leak you will notice it then. It's really hard to miss. (My carpet was a little harder to lift up, it was frozen to the floor.)
If you can't find the leak. Open the hood. Look along the top of the fender. Fairly close to the windshield you will find a hole. Place a hose near that hole and let the water run into it. Look inside the car along the floor pan where you have the carpet pulled back. If you have a leak, you will DEFINITELY find it then.
FORD WILL NOT HELP YOU WITH THIS PROBLEM. They will do everything in their power to lie to you about it. There have been MANY documented and unfortunately undocumented cases of leaks on the Mustang. Ford continues to lie about the Mustang ever leaking. It's just proof that you can put crap in a shiny box, but it's still just crap.
Mark
