Mazda5 Transmission Problems
I've had my Mazda5 for almost a month now. It's been a great vehicle, but I find when I'm using the manual mode of the automatic/manual trasmission I'm getting a smell of burning rubber. Living in Canada, I didn't even get my M5 before the recall was done, so I don't think that's an issue. Has anyone else smelled a weird smell after using the manual shift on the auto tranny?
The "hesitation" your experiencing isn't, it's just then engine trying to cope with all the extra fuel you're dumping into it (remember it's not a V8)
I had a Mazda3 and now a Mazda5 (both with the 2.3L and automatic) and both hesitated for just a second when I floor the throttle at speed. However, the sensation is more pronounce in the 5 than it was in the 3. I attribute that the extra weight of the 5 and the lower torque rating of the 5 vs the 3.
The dealer couldn't find anything wrong...
I also encounterd a few times with hitch.
The 1st time is when I am existing fm 401 and shift to 4th gear, but it was not the hitch when u suddenly change gear too aggresive
The 2nd time is even funny when I just start driving on a 40km/h street in gear 2 to 3
Today, it happened again that I use the gear 2 when I am accelerating after a stop sign w/o complete stop.
I do not know how to explain to dealer, and they will always deny.
What is your comment?
I brought it up with the dealer, but they just flashed the tranny rom and danced around with excuses.
I definitely won't buy it out at the end of the lease.
LuvMazda :shades:
I mean that's the first thing I noticed about this car when I test drove it... how the pedals feel so "liquidy", the gas goes up good without much pressing on the pedal but i've accidentally spun my tires quite a few times thinking it could handle a hard hit like my old Chevy haha...maybe it's just the weight of the car and the lack of horsepower for the torque..
Also, you may want to change the transmission fluid to a full synthetic (Redline, etc.), as that has really smoothed the shifting on my manual 3 (same drivetrain) in cold temps. Let us know what happens!
Scenario: coming to a red light on 3rd gear and light turns green, accelerate, 1-2 second hesitation then shifts down to 2nd.
I have taken it to the dealership and asked to check if all latest software is up to date and they have even showed me the print out stating "no other updated software found for this vehicle" from the scan tool they use to upload software. Does anyone else experience this hesitation, and if so, has it been taken care of or know what the roots of it. Thanks!
he told me they will not fix it ever as they were going to resolve it with going to the 5 speed manual.
and no they will not revert it back to the orginal programming either.
now you know how to make it happen all the 4 speed transmissions do it. I am surprised why more people do not complain about it as it happens on every 4 speed auto box.
The reason is they dumbed down the transmission and added the hesitation. they did not porperly reset the dash numbers and you can see when it should change as it is not in sinc with the actual gear.
I just picked up my MZ5 from a third dealer that I wanted a diagnosis from and they too said the same thing. "everything is working to specs, transmission is working normal"
(sigh) oh well, I guess that is the way it will have to stay and I will have to live with it until I decide to trade it in for a newer with the 5sp auto or just dish the autos all together and pick up a manual trans.
Thanks anyway.
I am debating between a great deal used 2007 and a new 2009. It's just the 5 speed automatic that attracts me to the new model.
Any one driven both?
I live in Germany and Mazda won't honour my warranty over here, so I can't go to my local dealer. German dealers are silly expensive. Which, by the way is why I won't buy another Mazda. BMW, they'll honour it, Mercedes, Yep. Audi, VW, Toyota, Hyundai, Honda and GM all honour warranties on both sides of the pond. But not Mazda. It's a shame. I like my 5GT. Too bad they don't know what service means anymore.
In summary there is nothing you can to about it because mazda said that they were not concerned about support for the 5 with the 4 speed tranny because they would be a out of warranty by the time the damage gets to the point of repairs and second they already have you money and will just put up with it like we mostly have for the unacceptable suspension issue which will eventually resolve in that the driving will eventually just get to the point of less 'tight' feel and will finally get to the point that you will notice such things as the car will feel kind of out of control when you go over a bump going around a bend. this is caused by the angle of the wheels on the suspension will change when the weight of the car is taken off for a moment when it hits the bump and then will be at the wrong angle when it then recontacts the road. again mazda will just say it is your driving and just in your mind.
This failure was the last event in a series of troubles that started with my observing that the crankcase oil level was at half mast. Here follows the best remembered sequence of events.
1. I noted that the dipstick reading was at 1/2 quart low.
3. I inadvertently over filled the crankcase by 1/2 quart of synthetic oil on a cold engine.
3. I drove the vehicle 250 feet (76 meters) to my shop where my maintenance tools reside.
4. I drained 1.75 quarts of oil from the vehicle spilling about a half cup.
5. I checked the oil level. It was below the dip stick.
6. I added 1.0 quart of oil back to the crankcase. This should have left the dipstick level at 1 quart low i.e. at the bottom of the hash marks on the dipstick. This was not the case. It was over filled.
7. I used a straw and a shop towel to blow air into the dipstick tube. I heard the air bubbling into the crankcase. The oil level was still in over fill by dipstick measurement.
8. I warmed the engine to operating temperature and shut it down. The oil level was still in overfill.
9. I repeated the bubble test with the straw. Nothing changed.
NOTE: There were no diagnostic / trouble lights on the dash. I said this was indeed weird. I placed the car into service with the understanding that the oil should be low but acceptable and that if anything was severely wrong the computer would let me know.
10. I drove the vehicle 6 miles when the engine light illuminated. One-half mile later I stopped, added a half quart of oil to the transmission. The engine light extinguished. This state of affairs persisted for the next ten or so miles at which time the vehicle was parked again at home.
11. I again checked the oil level. It was still in over fill.
At this point we packed the vehicle for a 850 mile round trip.
12. Three miles into this trip the engine light and the transmission light (AT) illuminated.
We immediately sought a rental for the trip. Failing that we drove the vehicle back home. While driving home ...
13. I noted that the transmission would work smoothly up to 3rd gear by not go into 4th. The manual mode did not work period.
14. The oil level was still in overfill when the vehicle was parked.
15. The transmission fluid level was way low (off the end of the dipstick)
We finished the trip to our daughters funeral in our 1995 Ford E-250.
My diagnosis ... "A blown gasket between the transaxle and the crankcase that emptied the transmission fluid into the crankcase."
My questions... "Does anyone here disagree with my diagnosis?"
"What-- if anything -- did I do to produce this failure?"
"Is it possible for such a failure to occur on this vehicle?"
As soon as I recover from the flu, I am going to do a full diagnostic on the vehicle via the computer port and Auto Enginuity software coupled with complete shop manuals for the vehicle. Till then ...
rodalsa
My investigations into the causes of the problem I reported were not fruitful so I took it to my mechanic.
The results of that -- The transmission oil was low. He changed it and that was that. No more over fill in the crank case. No more transmission misbehavior. No more engine lights.
Strange but true.
Rod
I've read of others having the same problem with the manual transmission - early clutch failure, one with only 75 miles on the car.
This appears to be a design or installation flaw. Those who are experiencing the hitch now would be advised to have the problem corrected by the dealer, if possible.
Here are excerpts from two letters we sent to Mazda concerning the issue.
Original letter to Mr. Jim O'Sullivan - President and CEO - Mazda North American Operations
"We bought a 2009 Mazda 5 with a manual transmission new in October 2008. We were very disappointed when the clutch started slipping with only 18,000 miles on the odometer.
We have only owned manual transmission cars for over 28 years. During this time period we have owned 6 other cars from 4 manufacturers. We have always received good life from the clutch in our cars. Until now, The shortest time that a clutch has lasted was 90,000 miles with many lasting over 120,000 miles when we got rid of the car. Our driving habits have not changed during this time period and we have maintained the car.
Based on our experience and normal usage, we consider the life of the clutch on this car to be unacceptable."
From Follow up letter to Takashi Yamanouchi - Mazda - President and CEO
"Attached is a series of correspondence with Mazda USA concerning a problem with premature Clutch replacement with our 2009 Mazda5.
We feel that the response from the Mazda USA is narrow and inadequate. It did not answer the primary question that Mazda needs to deal with: Why did the Mazda clutch fail at 18,000 miles when, with the same drivers and driving style, clutches from other manufacturers have lasted over 90,000 miles?
Note that we did not ask about the details of the warranty; we can read that ourselves. We believe it was caused by a manufacturing problem, either in the Hiroshima factory or with a supplier. It seems as if Mazda USA is trying to avoid responsibility. Quality Control is something that Japanese automakers are known for; it seems that Mazda is losing its reputation, especially with us. Regardless of the particular response of Mazda USA in this case or the costs incurred in this case, this problem needs to be dealt with, or Mazda will suffer because of inadequate quality control or management, as has lead to the fall of some of your American competitors. "
I don't know about y'all, but I'm starting to think class-action lawsuit.
