Thanks in advance for any help
I hope the intake manifold replacement was courtesy of Ford as a result of their TSB recall a few years ago.
RHawker
I would think you can see the bulbs in the cornering lamps - maybe the bulbs are not there?
after all the charging system diagnosis
I replaced the 6 yr old battery
still baffled i found no excessive current draw...charging system is great
thismorning 5 am i look out the lights inside are going on and off
about 10 second intervals
even the buttons for the keyless entry are lit
as well as the 5oo bulbs lighting the interior
well I know whats killing the battery
the dealer says this car doesnt have a Lighting control module
suggests a def door jam switch ( built into the latch $60
or perhaps a button stuck down on the keypad
i think illpull most of the bulbs and put a switch on the dome light
maybe its trade in time lol
any idea where i migh look for a LCM?
Tom :lemon:
I didn't think about this testing idea when you emailed me a few days ago, just until right now did another idea hit me. While the interior lights are coming on falsely, hit the door lock button on the remote key fob and see how many times the horn chirps. It is chirps once, it is not a door ajar switch causing the problem... but... if it chirps twice, then a door ajar switch is suspect. You can try this while its not acting up to get a feel for it. Close the doors and hit the lock, the horn should chirp once. Then, leave a door open and hit the remote's lock button you should get 2 chirps. Not as good as getting to see the door ajar switches on a scan tool, but almost as good.
Sometimes it starts rough and it sometimes idles like its getting air.
After it runs for awhile, it has no problem.
A uncle of mines told me its a simple sensor problem around the carb.
i replaced dimmer switch.
CaptDan3@aol.com :mad:
from the battery. Do I have a ground problem? Please help. :confuse:
This problem shows up at odd times. Once from leaving the yard and going over a bump, once running down the freeway, once after openning the door to get in to start the car. I have disconnected the horn so that it does not embarrass the driver.
:confuse:
Could it be a faulty headlight switch since it has a time delay built in it?
Also it seems to idle pretty fast to me. Vaccum leak? :mad:
The switch also may have the feature of "delayed off" which turns them off after removing the key from the ignition.
As to the fast idle, I think it is factory set.
All fuzes and power check good even to the PCM and even the power to the ODB2, but no scanner will read and the car will not run.
Starter spins it nicely but no run.
Rich
Was driving on I 10 doing 65MPH and blam.
All fuses and power check good even to the PCM and even the power to the ODB2, but no scanner will read and the car will not run.
Had to tow it home.
Rich
Sorry about double post the page numbers run backwards to most forums, most keep the first page #1 and the older post slip lower and on to page 2 and so on.
Fred
My auto delay doesn't work but I can live without that. Also you might have a light sensor on top of dash by windshield that could be defective. Hope this helps.
Fred
That shows how your lights are wired with relays and such. I bought one off ebay for mine. I know it can get real frustrating. Hang in there. :sick:
Someone said something about an ambient light sensor in the rear view mirrror. Does my car have one of those, or anything like it? :confuse:
