go there and read thread, it is loaded with pics.
I just need a self-addressed/stamped envelope and the "O" rings will be on their way. After all, I saved about $1000!
Another post offered me free 0 rings from the master sargent in message 118 and he sent them in the mail so I did good. You're a great american
Thanks again 08 grand marquis
I'm not a spring chicken and it's hot down here in Texas!!!!! Any help greatly appreciated. The dealer finds no fault...Can not recreate issues with the car idling in garage...
Thoughts??????
thanks for the fast response!
My a/c blows warm, and after some research I checked that my a/c clutch is engaging and the line in the engine compartment to the (accumulator tank?) gets COLD telling me my freon is good...so I started looking into the blend motor door/actuator, since that's very common issue I understand.
Since I didn't want to remove my entire Panel and pull the dash back, etc...I pulled my Glove box, and cut a small viewing "hatch" into the plenum chamber to view the blend door operation. I can see the blend door and it operates fine. When I put the control on "Max Air" it swings one way, when I put the control on "Floor" (heat) it swings the other...indicating the door is being actuated, and is operational.
What the heck do I look at next?
I sure would like to take advantage of your selfless offer to share your "O" rings, but I dont know how to contact you. My EATC is sitting on my tool bench waiting for me to bring it back to health. May I hear from you?
uleck1@msn.com
That statement implies that you're looking at the outflow direction control vane/damper/door, not the blend door. The blend door moves in response to the system temperature setting, MAX cooling vs MAX heating.
stays loaded with vacuum, allowing for 3 or 4 cycles of various settings before the vacuum
canister is depleted. Is this something that I should be concerned about?
Other than being concerned about what else, how else, Ford might have cheapened the vehicle design. Most modern, more modern, cars use electrical servo motors that are always disabled likewise.
I'd like to check the blower resistor and/or HVAC Blower Motor Control Unit (a MOSFET), but I'm not sure if my car has one or the other, or both.
If you don't see a broken door or broken linkage, then you'll either have to sign up at www.alldatadiy.com for $26.95 for the year to get the clothesline-long set of instructions on testing for electrical shorts, or you can take a flyer and replace the EATC module which is about $90 bucks.
My unit's display is normal, self test shows 024, no ac, no heat. If I had just a blend door actuator failure, I should have normal fan, ac and heat operation- just a malfunctioning blend door or malfunctioning vacuum operation. I just ain't got nothin! Just normal display.
Ideas, please. Hate to buy a new one if the old one ain't broken......
the black to the blue and white lines. How do I get a hold of bigmerc to discuss this further with him. If he or twocassels or lilborther would contact
please about this. Ed
my 2000 merc grand marquis air conditioning blows warm.
the system is fully charged, no leaks
yet, the inside temperature is very warm, especially here in las vegas
help....
summer isnt here yet,, i need to resolve this soon
the a c lines are cold,
the heater blower motor works fine
just warm air
this car does not have the auto temp control
guessing maybe a blend door issue?
marcus.kabatsky@gmail.com
marcus
I know its been a year since you posted this, but was just wondering if you resolved this. Same exact thing happened to my friends car today.
