Visitor Agreement.
Drain Plug - Fram Sure Drain system (SD-4). I'll let you know how that works. If it weren't for the black plastic shield along the front, you could probably drain the oil without lifting the vehicle.
Filter wrench - Rite Fit A258 - 74 mm/15 flutes (purchased at Pep Boys). Perfect fit for the canister. Almost too perfect as I needed a screwdriver to pry it off the canister. AmPro 74/76 mm/15 flutes or Oil wrench "A" (forget the brand name but sold at AutoZone) will work as well as long as the canister was not overtightened like mine was.
Oil filter - Purolator 8765. Fram sells this filter for $9 while everyone else is $5 or less (purolator, AC Delco).
Engine Oil - I used Walmart oil for High Mileage vehicle hoping the thicker oil will help with the "burning". Also did the engine flush prior to changing. Figured no harm and it only cost $3.50 for the bottle.
Overall very easy. Will be even easier the next time now that I have all the tools and no where everything is.
So, here's the deal: I have a dog who sheds a lot and various bugs have died in the back window of my Intrigue (these two things ARE related...). Over the past few yrs, dog hair and bug parts (gross) have accumulated in the rear shelf IN FRONT of the rear brake light. Now, I am talking inside the car...rear window. So if you look in my car's rear window, you can see dog hair and...those nasty bug parts.
I finally decided to use a damp rag, unfolded, and run it flat against the window in front of the brake light and try to pick up some of the crud by moving the rag from side to side.
Are you still with me here? Ok. Well, it didn't work, but I DID succeed in loosening the felt-like fabric from around the brake light. So now it looks worse. How the heck do you clean that w/o dismantling the whole back shelf/seat???
I know this is boring compared to the good stuff like trouble codes, bad trannies, etc, but are there any takers on this one??
My old 'Trig had the factory spoiler, so no window-mounted stop light on mine - but those LEDs were expensive!
Deke
Di
Almost all Accords and Camrys have both - seems like the spoilers were not offered as factory-installed pieces.
Deke
Kept taking it back to the dealer to have them document and check the oil until the extended warranty ran out (75K). The mechanics always gave me a funny look, as if to say, yeah, it's crazy, but that's the way it is and we can't say anymore. The dealership people just said that's normal for the engine. What they didn't say was what I recently read on this forum...something about the fact that the aluminum engine is the cause (don't know if this is the only reason, but it did make sense).
The bad part of the oil consumption problem was that I had no idea I needed to check the oil on my relatively new, low mileage vehicle between oil changes (more than just once!!)... could have caused huge damage...I learned to pay attention to all those warning lights!!!
The OEM blades are the typical black-metal frame style. They worked OK except that sometimes at highway speeds they seemed to lift occasionally and were an absolute disaster in winter. The frames froze with ice and that meant the blades wouldn't flex, which in turn meant that they didn't contact the windshield. Not good.
Last year I replaced the OEMs with a set of aftermarket Canadian Tire "Aerofoil" blades. These looked like a wing and instead of the multi-piece metal frame they had the blade mounted to a continuous length of springlike metal. These did well in winter, but the blades themselves were absolute crap and were useless after about 9 months.
Yesterday I went back to my dealer and found a sympathetic parts guy. I asked him if the new OEM style blades GM is now using on the W-body would work on my Intrigue. He didn't know, but went out back and came back with the 3 choices he had to offer: the original Intrigue OEM metal frame type, the new GM OEM type as used on the LaCrosse and Impala, among others, and an AC=Delco replacement type, which I immediately dismissed as ugly and clunky.
The new GM OEM blade looks something like the Aerofoil blades I had, except the exterior is all rubber, almost like a winter blade, but with a raised lip on the trailing edge. A very clean look. He let me open one up and try it for fit, and it fit perfectly, so I bought a pair. They look and work great. Different part #s for either side: 10350075 and 15146561. Paid $17.96 Cdn each.
Hope this helps someone.
They are a little more than other brands (I think I paid about what you paid ~C$18), but it's worth it.
DL
I started to buy the oil and filter to take to the store for a change, but now I'm feeling ripped of, for I get a discount of a measly couple of bucks, if any.
I'm just back from one such place, where I was returned a car with oily palm prints everywhere. :mad:
Changing the oil myself is getting more and more tempting, but the space under the car is quite restrict. How do those who change it themselves do? Any tips?
TIA
Make sure the oil is somewhat hot so that it drains well. My 2001 is a 6.5 quart fill. I added 6 qts, and then topped off to fill it up.
My previous car was a 1997 Dodge Intrepid 3.3L V6, and its filter was accessible from above the engine under the hood, and I could reach the drain plug without jacking up the car. That was an easy change.
How do you collect the oil, what kind of recipient do you use? How about its disposal?
TIA
How long do you turn the engine on for to get the oil warm enough to drain easily yet without burning your hand?
TIA
The only "danger" is forgetting to add it on long trips, etc. or presuming that consumption rates are going to be the same in summer, winter, going to the mountains, in hot climates, etc.
For a car like yours, I'd certainly check the oil every second fill up.
Interesting thing is my old commute was 45 miles (each way), 95% interstate highway. I woudl average 26-27 mpg. Of course i was traveling about 70-80 mph. My current commute is 35 miles each way and I travel two lane roads the entire way, averaging 45-60 mph. I get better slightly better gas mileage. I also noticed the rpms are down around 1500-1700 instead of 2200. I guess excessive speed does hurt gas mileage.
dieselissy's guide is here:
http://www.carspace.com/guides/
Visiting Host
2000 up ---it is on top of the gas tank.
I think the engine type dictates location
It's a simple and cheap ($3.50 for the can of grease).
:shades:
www.ngk.com , www.autopartswarehouse.com , www.autopartsgiant.com , match prices & then order from parts giant or warehouse at least price, w/free shipping and price match!!!! thats how i got my deal.... :shades:
