Car Forums / Volvo / Volvo C70
Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
Judie
Secondly, my windscreen has had the little plastic bushing fall out from one of the hinges which causes it to rattle pretty bad. Any thoughts/advice? Are parts available?
Jeff
I found the problem hopefully this will help others. For some reason the parking brake light want coming on when I applied the P brake, it would come on intermittently. When the car ignition was on with the motor off all the lights were on so the top worked. I just took out the P brake handle cover and played with the switch and now it works fine. Almost went to the dealer.. that would have been a waste of $125 at the least.
Rgds
Henri
JNM2
jnm2
What else can I try, Anybody Help Please
It happened this morning. I tried to close the top. It stopped during the closing process... the topswitch's light is of now and seems to be dead, since no reactions occur. The lid for the roof is stuck in upward position!!!!... and I cant find a possible way to close it. Because of the upward lid i have no access to the trunk either...
I dont know what the problem is, since it used to work fine, so i thouht its the topswitch. i pulled it out and put it apart. Everything seems right to me ( I'm no electritian
SO do you guys think its a problem of the switch or something else. Besides is there any way I can put the stck lid down so I can at least drive?
PLS....HELP!!! I'm grateful for any answer....
This is a 2007 C70.
:confuse:
Whatever the issue is with your car, the dealer should be able to make it right.
It was enough to activate the stowage cover to come down when i pushed the button on the dash . The Micro Switches that control these functions are located on the rightside or passenger side of the top near the front . while the front of the top has just separated from the windshield. stop the operation . just lift up on the top and you should see two micro switches . one towards the front detects the front of the top is locked down and activate the stowage cover . the rear switch activates the motors to take the top down..my rear switch is going out. Also, I ve learned that these tops needs servicing frequently. When it rains i have to keep the front of the top lubricated. shortly after a rains it squeals terribley when i bring the top down .
I hope this helps someone. Even a dealer.
I know you dealt with this awhile ago. We just had the window cave in on the convertible top. Many are saying we need a whole new top? What did you do? Is there a way to seal or go to an Upholstery shop?
Can anyone help?
cheers
thanks, scott
