Cadillac DeVille Electrical/Lighting
My 1995 Cadillac Deville with 4.9 liter engine hesitates when I accelerate. How frequent? It seems that depends on what the outside temperature is. I bought this car in 2000, and have had this problem since 2001. My mechanic feels it's a computer problem. He says my car has 3 "computers". He's not sure which one to replace, so he would replace one at a time until problem is remedied. He suggested I just drive it as it is, so that's what I've done. Anyhow, if I remember right, the computer trouble code is P041 (which has to do with the camshaft position circuit). I replaced the camshaft position sensor, and that didn't help at all. I troubleshot this circuit the best I could, and didn't find anything. This hesitation problem is annoying. I would like to get it fixed without having to replace all computers. Any suggestions? Thanks in advance.
I was able to get into the on board computer and found the stored trouble code,which was P1139.P1139 points to a oxygen sensor(HO2S)insuff.Bank 1 sensor 2.I purchased a
new sensor and installed it.Is the light and the trouble code suppose to go out after the repair is completed?
If not,how do I clear the trouble code and light?
Thanks for your reply.Would you know if Auto Zone would be able to clear the stored code,with ther scanner too.
Thanks Vic
James
gbu28@yahoo.com
to the battery and cleared the trouble code. Now after 4 months of operation and no incidents,the same code has suddenly reappeared.Now what?
Today I had a friend of mine put his code meter on and came up with the same P1139 code oxygen sensor,his meter did show another code that was not showing up on the cars computer.The code he read said #6 cylinder has miss fired.
Could this possibly be the problem,thats causing the oxygen sensor to go bad?Thanks Again!
So the short answer....I don't know for sure. This is where thorough diagnostics comes in.
The system will also stop on trouble codes that are history.
Be sure to write down the current number code,so you will be able to look it up,and find which circuit the trouble is in.Once you find the problem and repair it,you will have to clear that code,by either using a code scanner,which you probaly dont have or by disconnecting the positive lead on the battery for five minutes and then reconnecting.If the code comes back again you have not corrected the problem and if it dont come back I would consider your repair a success.You will have to reset certain settings,like the clock and radio settings.To find a list of trouble codes for your caddy,enter in keyword 1997 cadillac Deville trouble codes,ther you will find the code lists.
Steps to Reset:
Turn ignition key to on position (do not start car)
Disconnect positive battery terminal while key is in on position (instrument panel lights on only).
Wait a couple of minutes.
Turn key off.
Reconnect positive battery terminal.
*Note This Process Erases All Trouble Codes! But keep in mind they will come back if the condition is not fixed.
computer and find the trouble code,that was causing the problem,I would of been at the mercy of my Cadillac dealer and you know what that would of cost.
I have a 1997 Caddy Deville,in your last message you said you replaced the plugs and wires.I have to change mine too.
My question is,are 4 of your plugs positioned in the rear of the engine,close to the fire wall?If they are can you tell me,the best way to take them out.Thanks for your time!
P052
P065
I039
I052
Could someone give me an idea where to go from here????
Thanks in advance for any ideas.
Best
Steve
cable end...............
Much cheaper than the $pendy active GM OE struts.
Ask over at http://www.caddyinfo.com for links and
more info.................
Info. center stating if you want the horn to sound upon
locking the doors with the remote or not.
I can only assume a 04 is the same? Have you checked you
DIC options?
your posting here. My car is a 2004 Deville.
What an engaging proposition.
There is even an index in there.
I have my Seville setup to flash the lights when the doors are locked with the key fob. I usually lock the doors with the lock button on one of the doors when I leave the car rather than using the key fob. That way I know that the doors are locked.
I personally find chirps to be just as annoying as horns.
suggest you ask anyone your in touch with who they would recommend if they don't have the product themselves. Using the above approaches I think your chances of getting results are fairly good if in fact the addition is practicable and affordable. Best wishes and let us know what happens.
Sincerely
Mike
Leaking fuel pressure regulator (cold start problem).
Or.... is it the other way around?????
Wait a minute. Is this motor a Northstar? The above info is for a Northstar.
Mike
