Toyota 4Runner Vibrations
I have a 2002 4Runner that has recently developed a vibration at freeway speeds. I purchased new tires about two months before the vibration started. I have been back to the place where I bought my tires and the assure me that they are balanced.
I have been dealing with this problem for the past couple of months and have been getting nowhere. When I took my 4Runner into the dealership to get the lower ball joint replaced I spoke with the service folks about the vibration problem and all I got in response was "we've never heard of that before".
I guess that I'm looking for any ideas or experiences as to what the problem might be.
It could be a number of things but since you say it happens at "highway speeds", it sounds like it could be a driveshaft issue.
Is there any noise (i.e. clunk, squeaking, etc.) on turns?
It also might be a motor/trans mount.
Check the front driveshafts and CV joints, rear driveshaft and u-joints and mounts.
It's rather difficult to diagnose over the net but these are a few things to look at.
Good luck!
Anyway, thanks for the help. I managed to wrangle a friend of mine thats a mechanic for a Toyota dealership to take it for a spin and see what he thinks as well. But I will definitely bring up the items that you suggested.
You would feel badly balanced front tires through the steering wheel, and badly balanced rear wheels as a kind of distant vibration/shimmy in the rear end. And both would be most noticeable at highway speeds.
A bad driveshaft feels more like a kind of drumming under your seat, and can get pretty alarming at 60-70 mph if the U-joints are shot.
I too have (had) the tracking issue. Crosswinds don't help any either. Not being able to steer a straight line has driven me nuts since after I made my purchase, mostly because my two prior Chevrolet's did the same thing and I thought this wouldn't be an issue with a Toyota. I didn't notice it during the test drive. For whatever reason, as I've put more miles on the vehicle, the tracking is better, but not perfect. Mine isn't bad enough to have an issue with Toyota. I guess GM products have me brainwashed.
I got the same problem with 06 sport. Went to the delaer 4 times and nothing happened. I called corporate office and i got nothing from them too. I think the problem is the tires. I am trying to get new tires M/S only, donloop AT sucks !!!!
http://us.lexusownersclub.com/forums/index.php?showtopic=7269&
Service manager told me that all SUV's have vibrations. Because 4 runner is a TRUE truck so it has vibrations. I even wonder how Edmunds actually rate this junk among best suv's.
I am beginning to regret my 34K purchase here.
SH
I am pretty much going to go to the Sales Manager and Service Manager and advise them that here in Cali.. there are a million Lawyers who would love to work for me to get me out of the 4runner under Cali Lemon Law, plus added punitive damages. I will bring in the 4 runner every day to have the vibration issue looked at. I will have it tested at an independant garage as well. For my 34K I am willing to take the time and energy to get this resolved.
SH
Honestly I did not read the 4runner problems etc... on this forum before I purchased the 4runner, as I was too busy focusing on getting the best deal. However like those before me, I am upset at the what I now believe is a "snow job" by Toyota.
One of the reasons I got a 4runner was for safety. This is now in question, especially if we do not know if this vibration can or has caused accidents in the past.
Has anyone tried the Lexus GX470 TSB that i have seen thrown around in the forums?
SH
I really think this vibration issue is realated to a drivetrain problem; driveshaft, trans, motor/trans mounts, differential, axles, etc.
Toyota (dealers) should put the vehicles in question on a 4 wheel dyno. :confuse:
That would narrow the cause down.
THIS IS HOW SPORTS EDITION 4 RUNNER RUNS.ALSO BECAUSE THAT IS HOW THE TIRES ARE.
A NEW DRIVING ADVENTURE............VIBRATIONS. PLEASE ENJOY THE RIDE.
ALSO TIRES DO NOT COME WITH ANY WARRANTY.BOTTOM LINE IS
I AM HAVING NIGHTMARES WITH THIS VEHICLE. :mad:
I just took delivery of my 4wd v8 2006 4runner on Friday November 7. On my first joyride, I noticed a vibration in the steering wheel and also in the gas pedal. I took the car into the dealer ship and we test drove another 4runner that also had the vibration issue. Then the mechanic blew me off saying that all toyotas behave that way. The 4runner I test drove on a previous occasion didn't have vibrations in the steering wheel.
I took my car to another dealership that ended up balancing the wheels. Now it doesn't vibrate as much when it is coasting at 30 but it still vibrates at highway speeds or when you press on the gas pedal.
I contacted toyota and now I have a case number.
I read all the posts in this forum about owners that experienced the same issues with vibrations that I have with my car. What has been the resolution for you? Did toyota eventually fix your cars or did you get them declared lemons? Are the 4runners supposed to vibrate? Do I have to live with a vibrating car?
Help?
1. The same thing happened to us: your problem is one of the rear tires being unbalanced by factory defect. When it is put on the front, the front shock absorbers transmit the vibration to the steering wheel. On the rear, you don't feel it as much because the vibration is not reaching the front suspension/ steering column. -May I suggest to switch the tires to the rear and if you are satisfied, drive them for an other xyz miles before buying the Michelins. Would you consideer the smoother running Michelin XLT tires?
2. While working on the tires, you may also want to have the safe wheel lugs installed (anty-theft lugs). Thieves can steel your wheels fast - it just happened to a friend. Think about it! Have a nice weekend: Andrew
