Jeep Wrangler Maintenance and Repair Questions (up to 1996)
12467
    ronbo2ronbo2 Member Posts: 6
    it is my understanding that there is a check valve at the back of the motor which causes the oil to blow by thus sending it thru the carb i have heard this but not seen it first hand this i a common problem with 6's
    try your spicer gears the thing that looks like a u joint put it in 4 wheel drive and in gear then reach down grab them and try to move them if they don't move they are good if there is play time for new ones it is easy but takes time 2-3 hours your should have proper tools and a garage
    very easy fix you have two mounts for the motor and two for the trany i have replaced my mounts as they were ripped out from the torq yes they have lots for a 4 banger, the trany has a stud that wears out also from torq its about 15 bucks cdn at the dealers ,need stud 4 washers and 2 rubber bushings its like a kit then you have a rubber block type mount for the trany that should be ok
    agillagill Member Posts: 19
    i had a '95 wrangler 2.5L had same sort of problems. I would check exhaust manifold for leaks, before O2 sensor. If it is TBI olr MPI the exhaust suck in air and make computer think that engine is not getting enough gas, thus "flooding" the engine. Once engine warms up the gaps in manifold expand, closing it up. I replaced mine with a Borla header and noticed a definate inprovement in performance.
    For those of you that have a K&N filter these can set off your CEL if you spray to much oil on it.
    i used to have a 2.5L go with exhaust headers, I bought a Borla. I would go with high flow cat and muffler but keep exhaust stock diameter. You can't afford to loose the low end tourque. After that go with cold air intake. The header swap can be done in t he driveway if you are mechanicaly capible, it is fairly simple swap. Other than that the 2.5L is not worth the money to upgrade. I have heard the the turbo from a dodge neon 2.4L might bolt in. Honestly you would be better off selling the whole jeep and buying one with a 4.0L
    my wrangler was 1989 2.5L 5-speed, as plain as they get. The motor mounts always needed to be changed, like every 6 months. The biggest issue i faced was the power stearing pump gets in the way of the long bolt. Remove it once and put the bolt through the other way, so the nut is on the pump side and the bolt pulls out toward the fire wall. Another thing I did was purchase the lifetime warrenty mount from Autozone (just one.) replace one at a time and use the lifetime warrenty to replace both. Just do it separate days.
    Jeep is notorious for specific parts that fail, I.E. Motor mounts, Exhaust Minfolds. This is inevitable regardless of engine(2.5 or 4.0.) M.O.R.E. makes a bombproof motor mount and i am sure you can find a tranny one, too. Jeep part is just not designed to handle off road touque situations. Be carefull buying transmission mounts i have see two style, one hase studs comeing out of mount that go through belly pan ans use a nut ans other use a bolt that screws into mount through belly . I would use the latter gives a more flush mount less to hang up on rocks. As for exhaust manifold, this can be hard to diagnose because of the heat shield. They ussualy crack near the collector, where each pipe meet as one. just remember if it ain't broke now it will be later. Don't buy OE replacement it will happen again.
    tecman101tecman101 Member Posts: 4
    Thanks for the advice Agill. It just so happens that I had a leak in the exhaust manifold. When my mechanic went to tighten it up he broke the bolt. I have since fixed it but never thought that it could still be leaking. I will check this out next. Thanks again
    On a side note. After replacing any part of that see extreme heat changes, like manifold, bolts on the block and such. It is good practace to double check retourque the bolts the expanding and contracting wwill cause the bolts to back out or loosen. just something to keep in mind. Its funny that people say that Jeeps just break down. At least the failures are predictable and usually easily fixed. I also have owned a first gen. XJ with 2.8L V6, '79 Grand Wagoneer with 360 V8, and '99 Grand 4.7L V8. I have done countless research an all bumper to bumper. Feel free to ask and I may have an answer.
    dustie1dustie1 Member Posts: 17
    For some reason I can start the jeep but when I put it in gear fuse #11 blows and Jeep dies, that fuse says in the jeep book it the Central Power Distribution coil? what is that? what would cause this? how do we fix? and What do we look for? Please if anyone knows where to start looking for a short or what ever. we can put a wire in the slot where that fuse goes start it the wire gets so hot it burns, and every time we put fuse in it blows it????? if you know what this is please respond.
    i am no expert by any means but it sounds like the CPDC might be the coil that distribute the power for spark plugs. Just follow the center wire on you distributor cap and it should lead to the passenger side fire wall. I think you local auto parts store can check it. Also on my XJ the hydraulic clutch would leak onto the fuse box under the dash and cause fuses to blow, too. That leak can be fixed with a clutch master cylender rebuild kit. OR!! It could be the Nuetral Safty Switch. I read an article in JP magazine about rebuilding it. I can't find the article right now but I will cantinue to look for it.
    This is the article www.jpmagazine.com/techarticles/drivetrain/154_0805_1987_200
    1_jeep_cherokee_neutral_safety_switch
    lilchappylilchappy Member Posts: 3
    have 93 jeep wrangler and the speedometer just stopped working. Replaced the speed censor and still have no speedometer. Does it work off of the computer or is there something else we can try.
    I will check that, great thank you.
    Yeah, when the #11 fuse blows all guages quit working too.
    This is probably one of the craziest things that ever happend to my wrangler. There is supposed to be no pressure in transfer case. Mine was building pressure and forcing the t-case fluid uo through the speedo cable and out behind dash, Crazy right!? I had to fine the breather tube on the fire wall and blow through to and the leak went away, of course I had to remove the drain prug first. Also you speedo still reads revolutions on a toothed gear inside t-case just under sensor. check that, too
    This is the article in May 2008 JP magazine. Tells you how to rebuild Neutal Safty Switch on an AS-4 automatic tranny. I hope it is the same as the link I posted earlier.
    scooter39scooter39 Member Posts: 1
    replaced engine now it want start.replaced cam,crank,dictributer,plugs,wires,coil,have power to coil and injectors but no fire to mechanics 600.00 still want start any ideas
    My Jeep would run fine, we just had engine diagnostics done and had o2 sensor replaced. what happens is you can start the jeep but the minuite you put it in gear (auto Tranny) it dies and #11 fues blows then if you try to start it wont crank over put another #11 fuse in and it blows when you try to start jeep. wait a few minuites and put another #11 fuse in and you can start engine but again you try to put in gear it #11 fuse blows and it dies. This has happend earler last month but husband put wire where #11 fuse goes and it would work as normal with #11 fuse. What would cause this? if easier reply to bethannstarkey@yahoo.com
    maaarrkmaaarrk Member Posts: 2
    I have an all stocked manuel 92 wrangler and am planning on changing out the transmission fluids. since i'm doing that is there anything else i should along with it?
    mark
    It can get pricey, being a '92 you are probably pushing 100,000+ miles, you should look into replacing diff. fluid front and rear, T-case, and breaks if you have the cash, even bleed clutch master cylinder. I would give the dealer a call to find fluid specs just to be sure you have the correct fluid. You don't want to burn the Limited slip on you rear axle. It is not that hard to do but the tranny sits up inside the 'hump' on the floor of the jeep. If you have big hands you barely have enough room to get the fill plug off. Best to buy a pump. Further more the 90w gear oil is very smelly, almost intolerable to me (almost.) Honestly I would just take it to a quick lube place and just pay to have them do it. It moves the liabilty to them and you don't have to dispose of it. It should be about 50 bucks a service. I worked at a Toyota dealership that used B/G products. the 40K is a fuel system cleaner you put in the tank and would place my kids college fund on the line. The stuff is incredibly good. They offer a full line of product to help bring you systems back to life. sorry for rambleing. Good luck.
    We just had a brand new transmission put in 4 months ago.
    My Jeep is a 1997, sorry not a 92. But any way thank you kindly for your assistance.
    quidoxquidox Member Posts: 1
    i have a 89 jeep yj with manual transmissiom. a hose has come loose on the motor side of the hose. in other words, the hose is stiil attached to transmission, but i need to know where it attaches on motor. thanks.
    i believe that there are four hoses on the back side of the t-case. this is what engages the 4x4. Two are vacuum supply, probably comes from intake manifold, they are responsible for engaging/disengaging t-case. one is like a breather hose and only functions as an air releases and should be routed to fire wall in engine compartment to keep water out. the other goes to the front axle on the passenger side to move the shift fork inside the axle tube, in other words it turns on the front wheels. All vacuum comes from the intake manifold. It hase been so long, i think the colors are red, blue yellow and green. any after market repair manual with vacuum diagrams should help, it has to say that it has vacuum diagrams though, not all books have them. I got mine on amazom for likek $5.00. I almost possative that the only hose on the tranny is just a breather tube also. on my '89 wrangler it was on the fire wall just to the right on the ingnition coil. it looked like it has a little hat on. This in just to prevent stuff from getting in and the only reason that it is on the fire wall is to keep water out of the tranny beside releaving the preasure that can build up.Hope this helps. Oh yeah bve very carefull with vacuum line, The factory ones get very brittle and break easily. I would buy some new vacuum line from parts store before even touching them just avoid having to make a trip.
    Your owners manual should recommend all the millage's you need to swap out fluids. Just remember off-road usage shortens the life of all your fluids and should be replaced more often. The differential also have breather tube that if come disconnected can allow water and dirt to get into diff housing. If you are fording waterway or submerging deep water or even blasting through little mud puddles all of this increases the possibility of water entering into places you do not want. I personally change my engine oil every 2500-3000 miles. I live in a very dry and sandy area.
    Would this cause a fuse to keep blowing? ok we will check this, thank you very much for your assistance.
    there are no electrical conections involved with the vacuum switch on the transfer case. make sure that you have the correct amp fuse installed first. an after market stereo or navigation, anything that would be spliced into the harness could be possibilities if the are tapped into that power line. Some stereo shop may take short cuts that way. Even a switch that powers any Off Road lights. anything that is not factory install and requires power source. Check that first. Back trance line from souce too. The haynesor chilton manuals have wire digram, too. they are all color coded by jeep to help find wires.
    rugbyman4rugbyman4 Member Posts: 1
    Similar problem with my 94 4cyl wrangler. It takes about 7 times to crank if it is mildly cold outside (I won't even bother if the temp is below 40), but no problem when the temp is warmer. A local repair shop ran a diagnostic and determined the problem was the PCM. And quoted a price of $700-$800 to replace mine. A quick online search showed the cost of a PCM around $250. Is this part really that difficult to replace? I would appreciate any insight. Thanks.
    What is the PMC? when this would go out would it cause the fuse to blow? before this happend we had no problem starting it. It would start fine then when you go to put it in gear the fuse would blow and engine would die all at the same time. then when you tried to start it with out putting a new fuse in would just crank over, put a fuse in it would idle the fuse would blow and so on.
    I read that you can clear pcm code by disconecting battery for five min. to reset the pcm (computer).link title, i think the pcm runs the engine F/A mixture and so on. PCM=powertrain control module, very possible reason fuse #11 blows. could be bad.
    mac24mac24 Member Posts: 3,910
    The PCM is the Powertrain Control Module. It's the Jeep's onboard computer and is just a 'black box' that can be unplugged and replaced in five minutes.
    merf410merf410 Member Posts: 1
    our 1995 jeep wrangler--4 cyl,stick quit suddenly while going down the road. There is no spark or fuel. We have replaced the pick-up in the dist. and the crank sensor--still nothing-any suggestions other than the ecm. Since all these parts I am throwing at this thing are electrical they are expensive and not returnable. thanks-Shirley
    Which is why it's never a good idea to just throw parts at a problem.......diagnose it first.
    While either CPS could have been the cause, it could also be something as simple as a high resistance connection or a broken wire.
    Sometimes it's better to pay to have it diagnosed by a specialist with the equipment to do it.
    Just a thought, but have you checked for codes yet?
    ndmanndman Member Posts: 2
    i'm looking for a simple part, a 5" circular flat plastic cover for the a/c blower motor for my 1993, the dealers say it's out of stock/no longer carried. the a/c blower motor is alligned by and pivots in the center of this plastic disk, can't use the a/c without it. it is accessible from inside the car, just under the a/c unit, on the bottom side of the a/c bloser assembly, spins right off
    anyone have a junked a/c unit with this part? any ideas where to track down a junkyard replacement part???
    Just to clarify, is it the disc that the motor is mounted on in this pic?
    If it helps, the new motor and mount are currently on eBay for just over $50 B.I.N...........click here.
    No connection etc.
    I would love to have it diagnosed but when we go to put it in gear to drive it dies. and #11 Fues blows at the same time, so we cant get it somewhere. Could you please tell us how to get the codes what do we have to do? Thanks a bunch.
    ........when we go to put it in gear to drive it dies
    Ah, so it does have a spark and fuel? :confuse:
    I'm also confused about your #11 fuse problem. According to the Factory Service Manual (FSM), location 11 contains a circuit breaker rather than a fuse (so it will reset if tripped) and that circuit is for the wipers and washers.
    As for the codes, if you don't have a code reader or scanner you can put the PCM into self diagnostic mode and it will flash any retained codes to you using the 'Check Engine Light'.
    For instructions on how to do that, and a list of all possible codes, CLICK HERE.
    scottyj08scottyj08 Member Posts: 3
    yeah..
    just the other day while i was coming home from work.
    my jeep decided it was time to call it quits for the day.
    in other words it just stalled out and i couldnt get it refired.
    so i called my stepdad so i could get it towed back to my house
    and either let him check it out. or let my friend who is a mechanic
    check it out.
    wat im wondering is what could be the problem.
    me and my friend already changed the ignition coil, checked the fuel lines and was
    about to change the distributor cap but are unsure if these will help
    now my jeep is an 89 jeep wrangler 6 cylinder 4.0L
    any ideas?
    kid2021kid2021 Member Posts: 6
    Try the crank sensor. That seems to be a common problem with jeeps. Happened to my 95 YJ about a month or so ago and did the same thing you did, replaced everything from the fuel filter all the way up to distributer, coil and all that.
    alright i ll try it out and hopefully let you know how it turns out.
    ight so i changed the power control module...and it started right up...
    :-D WOO!!!
    :shades:
    jelyjely Member Posts: 2
    After driving about 30 min or so the check engine light comes on and then the spedometer and tach meter fall to zeroe. Jeep is running fine though. Any ideas would be helpful.
    Thanks John
    Sorry its a 2000 wrangler
    crakkertrakkercrakkertrakker Member Posts: 1
    Has anyone heard and/or used this brand of locking hubs before?? :confuse: I am R&R my front hubs but Warn are like very expensive. I have Warn now but busted one :sick: so need to replace and while researching hubs, i came across this brand and seems like they are of trusted quality??...never mind that they are about 50% cheaper on average...but i have never heard of them...anyone recommend or?? My jeep is 85 cj7. I am not hard core offroader, but do enjoy taking jeep out and enjoying a good hard 4x4 experience..
    desert_angeldesert_angel Member Posts: 1
    did you ever find out what was the cause.??? i have a 1995 wrangler s and am having the same promblem. any help is welcome thank you.
    baffled4baffled4 Member Posts: 7
    Yes I did find out what it was. It was the computer. The way the mechanic explained it to me was that when I turned my key and the check engine light wasn't going on right away, the computer wasn't telling the Jeep to start. The computer silicone was dry rotted and when it was very cold and moist out, it would get wet inside... reason why it took alot longer on cold wet days. They ordered me one from Michigan and it cost me $500.00, but since I've had it fixed it turns right over every time.
    I hope this helps!
    ~Dee~ :)
    05unlimited05unlimited Member Posts: 1
    I have a 2005 Wrangler Unlimited and have just noticed when I am slowing down I hear noise coming from the front end.The noise(clicking/tapping) seems to start when my speed is between 15 to 20 mph.until I stop.My jeep is all stock and has not been abused,the vehicle has 51k. :confuse:
    mohrlingmohrling Member Posts: 9
    Repair shop informed me I need a new carburetor for my recently rebuilt '88 Jeep Wrangler 4.0. It's got the original Cater still on the engine and I think I'm fine with the same replacement. The shop wanted so much money for the job I figured that I'd just do it myself having a medium amount of automotive skill, knowledge and tools. This carb was rebuilt twice (me/facility) but I think it might be done now. Anyone have the best place to find a good replacement?
