Mine just came on AGAIN. I've had it fixed 4 times now. I think the repairs have only lasted a year or less.
I paid $1200 the first time and lucked into the shop fixing it under warranty the last 3 times. They did tell me though that if it happened again they would not repair it for free again. They have seen and repaired many of these. I really think it is a flaw in the design somewhere.
I just paid my 2006 off (dealer driven and bought in 2007) so I'm going to keep it hopefully another year or so. I feel like if I sell it now I won't be able to get what it should be worth so I'm waiting so I can at least not loose money.
Good luck. If you get it fixed keep track of your warranty and stay on top of the issue.
What were the previous "fixes"? Did any of them involve the Electronic Brake Control Module, Steering Wheel Position Sensor or Vehicle Yaw and Vehicle Lateral Sensors?
The diagnosis was a bad electronic brake control module, with a cost of $1200 at the dealer. I took it to a repair shop who made the same diagnosis and they replaced it for $400. Next day the light was on and it remains on now.
As I explained to the dealer and the repair shop, the ABS light never came on. The EBCM and wheel sensors are common to both systems, so logically that was not the problem.
If it's just the traction/stability control light then it's likely the yaw and lateral sensor (or something else). I've heard of electrical problems with these vehicles that come from water intrusion. I've had constant problems with rain leaking into the vehicle since purchase.
BTW for anyone who's interested, I've complained about a check engine light since the car was new and suspected contamination of the fuel system. Today (five years later) I got a recall letter for a possible crack in the fuel pump. Only way Chevrolet does anything is to be forced to by the government.
On a positive note, I'm picking up my new Explorer tomorrow. Considered a Traverse but with all the problems I've had with this one never a GM product again. Their loss.
Hey All,
Just thought I would toss my two cents in here on all the Uplander issues. We have owned an Uplander since 2009, and for the first 100,000 kms of ownership it was not a bad van. Other than a rear wiper motor needing replacement, all was well. The van only had 90,000 kms on it when we bought it for just under $12,000 Canadian. However, when the van reached 200,000 kms, everything seemed to go down hill fast. Every sensor in the front end of the vehicle has needed replacement. Left wheel sensor, right wheel sensor, master electrical sensor, wiring harness, and the ABS/Traction Control/Stability Control lights still appear after nearly $3000 worth of repairs. The van also eats brake rotors like nothing, and is rusting in many places even after extensive painting and rust proofing. After the van decided to blow a front stability rod, and the ABS has proceeded to come on repeatedly in DRY road conditions with minimal, there is little chance of us keeping it. And then, last week, the van began to experience worrying transmission slip problems. Now, at 238,000 kms, the van is no longer safe. After having several GM vehicles that have done 300,000+ kms without issue, this van has been a massive let down. It will be sold for scrap this month, and a lovely, well equipped RELIABLE Honda CRV is being purchased. GM really dropped the ball on this one, very disappointed. This will be the last GM product we purchase. Terrible service, vehicles with appalling quality control, and ridiculous sticker prices. No wonder GM went bankrupt. They should have stayed that way.
I'll continue this thread. I have a 2005 Terraza and have many of the same issues that have been outlined here. I went to the dealer until the dealer's work didn't fix the problem. GM dropped the ball on what could have really been a great van. Ours has run well but these error codes for the ABS, TC, and Anti lock are un acceptable. Here are things I have done (myself) that have helped to problem at different points in time.
Oh and the rotor issue is related to hand torquing the tires. If they are put on with an air gun and a torque stick you'll have warped rotors in a few days of driving. I put mine on with an air rachet to 40 ft/lbs then I hand torque to 70, 80, then 90 foot/lbs in a star pattern you'll be OK. Also, when you stop at a light, stop about 10 feet early and slowly roll forward. That will keep brake pad debris from building on your rotors.
Van has great specs and GM dropped the ball. I'd like to buy American but it is unAmerican to buy an inferior product that a company doesn't stand behind. See ya GM, we now have a ford that works well.
