One of the big strengths of the LandCruiser is its offroad prowess. If you don't need that capability, you might consider a car-based SUV or minivan instead. You'll get better mileage, better ride, and less chance of a rollover.
One other issue, the volvo SUV has a rollover protection system that uses differential braking to reduce the chance of a rollover. The 2003 Land Cruiser doesn't have that.
Thanks - new to this group - love my car and can't wait til the '08!
This is one reason, why I would prefer not to have the NAV optoin in my new TLC as I plan to keep it as long as I can. I wonder if I can special order one from the dealer without the NAV and the fancy suspension package. It the NAV and the suspension fail, it will probably cost crazy amounts of money to fix these things.
The NAV is useful, but I probably use it only a couple of times a year and will be more than happy with an external unit.
To those ends, we will be shutting down the general make/model discussions and work exclusively with specific issues. This requires us to populate the make/model subsections with relevant, interesting and timely topics. Rather than having the hosts simply create boilerplate topics for each make/model, we feel that you, the owner, the make/model enthusiast and the prospective buyer can best judge what those topics should be.
You can help by adding a discussion (it's easy!) or suggesting one here.
To add a discussion, click on the last link in the "You are here" line at the top of this page. That will take you to the topic page for this make/model. Review the list of topics and click on the "Add discussion" link when you've decided what topic you'd like to add. Follow the directions and you're done! Feel free to add more than one. Just avoid duplicating existing topics and try not to make it TOO specific!
Your help and continued participation in the Forums is greatly appreciated! Thanks.
This link should take you to it.
http://www.iihs.org/ratings/default.aspx
So, my question is this: When I go to the dealer and have them flush and replace fluids, which ones should I ask them to do? Engine oil is a given (and the one I have been taking care of religiously), but what about transmission, brake fluid, etc.? Which parts should I have lubed? I'm not much of a DIY'er (in case you haven't noticed), so what would be recommended by those of you who pamper your LCs? Should I insist on Mobil1 for engine and transmission? Is the dealer the best place to do this, or is a Midas or an indie shop just fine for this type of work? How different is the LC from other vehicles in this regard?
Any advice is much appreciated.
Toyota Land Cruiser
According to the Carfax report, it's just come off a 5-year lease and has been maintained well. From what I understand about the Toyota certification program, I think the vehicle's probably been screened fairly well.
Any comments on whether we should jump on this deal? We would definitely use all the TLC's capabilities driving in the mountains & desert, and are looking for this sort of vehicle, having just lost a '94 Grand Cherokee to a sleeping driver - of a peewee Honda Civic :P . Any thoughts would be appreciated - this forum's already been a tremendous help in my thought process.
Rick
Here is a link that should help with the safety questions - it shows results for the LX470 and the TLC.
http://www.iihs.org/brochures/ictl/ictl_4wd_lux_suvs.html
Good luck
Also, any instructions on how to do it? (I assume it is like my previous 4R where motor is accessed through wheel liner)
I read on the Tundra forum and may try it just to get old mast out and inspect. I only think this will work if you broke the mast outside the housing, not if teeth are broken down in motor.
REPLACEMENT
1. Auto Antenna Models:
REMOVE ANTENNA ROD
HINT:
Do this operation with the battery negative (-) cable connected
to the battery terminal.
(a) Turn the ignition switch to ”LOCK” position.
(b) Remove the antenna nut.
(c) Press the ”AM, FM” buttons on the radio receiver, and simultaneously
turn the ignition switch to ”ACC” position.
HINT:
 The rod will extend fully and be released form the motor
antenna.
 After removing the antenna rod, leave the ignition switch
as ”ACC”.
NOTICE:
To prevent body damage when the antenna rod is released,
hold the rod while it comes out.
2. Auto Antenna Models:
INSTALL ANTENNA ROD
(a) Insert the cable of the rod until it reaches the bottom.
HINT:
 When inserting the cable, the teeth on the cable must face
toward the rear of the vehicle.
 Insert the antenna approx. 300 mm (11.8 in.).
(b) Wind the cable to retract the rod by turning the ignition
HINT:
 If the ignition switch is already in ”LOCK” position, do step
1 (c) first, then turn the ignition switch to ”ACC” position.
 Even if the rod has not retracted fully, install the antenna
nut and inspect the antenna rod operation. It will finally retract
fully.
(c) Inspect the antenna rod operation by pushing the radio
wave band select buttons.
I hope it is only the mast!
Thanks in advance for responding to my post.
David
HTH
My 01 LC loses it's memory to some electrical functions when the ignition is turned to "acc" or "lock". When the key is turned back to "on" everything works fine but doesn't retain the memory from the last setting. The clock resets to 1:00 whenever the key is turned to "on". The automatic climate control defaults to "off" and resets to 75 degrees. The trip meters reset to zero (but the odometer remembers the mileage...darn). The dome light doesn't come on when a door is opened unless the key is turn to "on". The headlights turn off immediately when the key is turned to "acc" and "off" rather than wait until the door is opened. The power door locks doesn't operate unless the key is turned to "on". The key fob doesn't work at all. I started having these problems after the JBL amplifier was replaced. Someone else had a similar if not the identical problem in post #298 but no one responded with a fix and I don't know how to contact him (Frank Willis) to ask if or how he got it fixed.
This problem doesn't affect the navigation system and radio as they still retain the memory from the last settings.
I've checked all the fuses under the hood and under the driver's side dash and they are all good. I don't know if there are fuses anywhere else to check.
Appreciate anyone who can help troubleshoot the problem.
If anyone else has had this problem what was it?
Starter relay, ignition key, security system, starter solenoid, ???
:sick:
If you are really interested in a full account go to Forums Software! Your Questions Answered... and browse back to the same time period.
Also, the rooftop weather strip on one side is loose - can this just be glued down?
