Taurus/Sable Transmission Problems
in Ford
My transmission is making a whining noise when switching gears right after the car is started first thing. Any suggestions on what that might be?
2. Brake pedal effort is what I would consider "high" in this vehicle. You have to keep pushing on the pedal to keep it stopped at an intersection, etc. The pedal doesn't keep going down, but it is considerably harder to push than any other vehicle I've ever had (including my 2004 Freestar). The engine Rpm reads approx 800, and doesn't change when shifting from Park to Drive, etc. It's like the brake booster just doesn't give enough boost. The ABS seems to work fine but you can bottom the pedal during really hard braking before the ABS starts to work. Is there a way to increase the braking effectiveness and/or decrease pedal effort?
Thanks everyone!
Brian Reed
You may be able to mess with the ABS by tapping into the computer, but it would be rather challenging for most people. It might also be possible to adjust the brake pedal, but it too would be very complicated.
1. When I turn my steering wheel to the right or put the vehicle in reverse the radio goes off and it may come back on or it might not.
2. We are in SW MO and during the ice storm we had a little over a week ago I went out to my car and started it to come home from work. The car started fine but when I went to shift the gear shift it was very difficult to shift (automatic transmission). When it did go into gear it would not leave low gear. Now it will not shift out of low gear if I start out in OD.
(1) My panel on my car as well as my headlights flicker and my battery light flickers too. When the battery light isn't flickering and its on, my panel and highlights come on strong.
(2) When I go up hills, my car doesn't want to switch into gears, I really have to put my foot on the gas inorder for it to give me any pull (on hills it drops from 30mph to 20mph). And when I go down a hill my car kinda "kicks" or "slips" aggressively into the next gear of RPM'S
Once the fluid goes brown, it loses all lubricity, meaning you might as well have water in there. The tranny fails FAST after that.
Check the fluid often (with each fillup) and make sure it is a bright neon red color and at the right level (read owner's manul instructions on how to check the level). Generally it should be changed every 40,000 miles or so, more often if you tow.
For your car, it is probably too late. Most people never change the tranny fluids in these things, with predictable results....
Have no fear, there is a simple solution to your problems. I currently drive a 1997 Ford Taurus GL, and just this week my car exhibited the same problems that you described. My mechanic told me that I needed a Neutral Safety Switch. He changed the switch, and the power steering, the power windows, and the radio are now back to normal. So, you may try changing this switch. Best of luck.
The fluid is full. What may be the problem?
Mark
i'M TAKING IT TO A TRANNY SHOP TO SEE WHATS WRONG WITH IT!
DID U FIND OUT WHATS WRONG WITH YOURS?
PLEASE KEEP ME INFORMED
i HEARD IT WAS THE BAND ON THE CAR!
here's the bad news...
the forward piston in your transmission cracked..it's very common for this car...i've spoken to ALOT, and i do mean alot of transmission guys on this because i didn't want to get really ripped off...mine is currently being rebuilt, electrical replacement etc. $1100, was referred by someone. General cost is $1400. Good news, yes, there's good news,lol..the 3.0 engine in that car is supposed to be one of the best out there right now, as far as used cars goes. mine runs really well, so it's worth it for me to get it fixed, and the body is in good shape.
the really bad news is that $1100 or $1400 is the going rate for a car like that. yah, you can find it for more at the dealer or less for a beat up on the street. so basically, it's up to you. if your car is in fairly good condition and you plan to drive it for a while than it's worth fixing. if not, then get rid of it..
good luck..
write back if you any more info..
ps. i'm in northern illinois if you want my trans guy...
later
Mark.
