Jeep Patriot Maintenance and Repair
Just wondering if anyone knows of custom fuel tank (BIGGER) that I can get for my Patriot. Love the vehicle otherwise but needs more range--a true off-road vehicle will consume lots of fuel when doing 4X4ing. My old Jeep Cherokee could do 550-600 km when doing a mix of hwy and 4X4ing. The Patriot will only do 300-350 km under such conditions--barely acceptable. I regularly find myself in remote areas with no gas station in sight! Even 10 l (2.5 US gal) bigger would help.
Farout
Farout
All in all Jeep isnt offering much in the way of incentives with the Patriot because it's a pretty good seller for them and most places don't have a ton in stock (compared to the GC anyway...)
Your best bet is to head to a dealer this weekend and try to work something out. It's the end of the month so you can get a good deal, plus the '08 should be out around August, so they should be more willing to move the '07s at this point.
Somewhere in my surfing around this morning I'd run across a Mopar coupon for something like $25 off a purchase of $200 or more, but now I can't seem to find it. I need a good set of floor mats, a receiver hitch, and maybe a set of molded splash guards..pretty sure most of my Christmas gifts this year are going to be Jeep-themed!!
It is bad enough to cause hearing problems for anyone who is sitting in the back seats.
Has anyone else experienced this problem?
Please contact me and I will explain further.
tidester, "Volvo XC90 SUV" #930, 3 Jan 2003 9:19 pm
Do you live in the GTA? We could go for a ride in each others vehicle to experience the problem. :lemon:
You also need to open the front door window
Licenced Interprovincial Mechanic, Class 1 DL, am the only driver,
do not ride the brakes, standard transmission, FWD only, dealer advised
nothing wrong. Anyone had the front pads checked or replaced
with very low KM?????? Please advise . Thank you.
Compared to a Wrnglr(a 10) and a TrlRtd, off-road CVTL Pat(a ?), how does a 5 spd 4X4(5X4X4) Pat measure up(a ?).
Does the 5X4X4 have the same drive wheel distribution system as the TrlRtd Pat where the wheel on the ground always gets the power?
What is the Frdm Drv 1(5X4X4) first gear ratio X final drive ratio on the ground ratio? How low is 5X4X4 low? Compared to the CVTLX4X4 low? I figure <15:1 compared to 19:1. What is possible w/that ratio?
Is there an advantage to using a CVT4X4 vrs a 5X4X4 in off-road conditions?
Does anybody have any off-road experience w/ a 5X4X4 or a CVT4X4?
Thanks, SWT
Between 60mph-70mph on a 5 speed manual transmission
my vehicle emits a high pitch noise that takes me back to my youth A friend of mine had a few mice for pets he built this elaborate maze of cages and in the middle was this giant wheel were the mices could run 360 degrees in the wheel {THATS THE SOUND} OF COURSE JEEP IS AWARE ABOUT THE PROBLEM
and eventually a fix will be in the works {tell me another story
easter bunny i sure miss those tales}AND for comfort ,they said hey at least you got 100,000 mile warranty
Wow wow wow eagerly waiting to buy my next vehicle from some other I DONT CARE car company
Plus the powertrain warranty will be one less headache.
Has anyone out there had a similar problem???
I am afraid to drive the car. I have had it 100 days! It is still under warranty, but they can't find anything wrong!
Interesting problem you got there. I've had a couple of problem where the engine would not start... but after turning key all the way off and retrying .....every thing ok.
It sounded like you had a sensor intermittent failure for sure and it had something to do with control fuel or air mixture. If you were going through a pass on a trip a barometric sensor may react that way. If it felt like you had "bad gas" I would look there. Do you remember your "check engine" light coming on at all? Good Luck
I'm 5'7" (barely); my wife is 5'0". Neither of us experience any difficulty in our 2010 Patriot. Good luck.
As for which plugs to buy, any auto parts store that's worth a darn will be able to get you the right kind you need. I wouldn't recommend anything fancy (ie: 2 or 4 post plugs) as they showed zero improvement over the factory ones in my experience with the Patriot. Plus, you'll likely be replacing them in 30,000 miles again, so the extra cost is REALLY not worth it. Save a few bucks and get yourself a set of basic, one-post plugs and you'll be fine.
Al :mad:
John Dunn
VA BEACH, VA
