Visitor Agreement.
I got the oil pump in. I still see some fluctuation in oil pressure. At start up idle is it at 50 - middle. As we get up to speed 40-80 it gets up to like 55-60. The after the engine is warm and we come to a stop, it drops to about 40-45. The engine is running smooth again, and all is well.
And thank you (tuggajb) for the previous post letting me know to prime the pump. I flipped the pump upside down and poured oil through the pickup tube until it began to run out the top of the pump. Then I flipped the pump back over and stuck it in a clean pan of oil. I then covered one of the two holes on top of it with my thumb (you know which one because the gasket would normally cover it), and began twisting the pump shaft with my other hand. It immediately began spurting oil out the uncovered top hole. Primed and ready to go!
Good luck to all others that experience this issue...
JC
The part costs about $70.
if not disconect batt reconect after 5 min try again let know what happens
Tuggajb, after it got ruff again, I did both things you said (one at a time) and no change. Does any of this higher battery voltage mean anything? 14.7 volts sounds high enough to think the alternator is working or does it? Could the electronics be this sensitive?
I am charging again now and will leave it until tomorrow and I will try again
how old is batt?
have you checked all ground straps? one at rear of engine from head?
have you gat a nother batt that you can hookup temp? try that voltage is sentive on the jeeps
I discovered, I am measuring bat voltage immediately after coming off the charger – it settles down after 30 min or so. This is a rebuilt engine and all the ground straps are clean and tight.
Sometimes it will idle just fine, and just cut off. When it is idling fine and I barely crack open the throttle it spits and sputters? Could that be the TPS? What is the other sensor next to the TPS? Sometimes it will smooth out and I can ease it around the block a few times, but if I get on it, it bogs out and goes back to spiting and sputtering.
Thanks again
When its first started up in the morning, the oil psi is fine. The oil psi drops down to zero when accelerating and then goes back up to 40+psi when letting off the gas pedal. After its warmed up, it has excellent oil psi and never drops below 40? The motor sounds extremely healthy and never rattles or makes any wierd noises. It also has the correct amount of oil in it too. Anyone out there have this problem or know what is wrong? I am hoping its just the sending unit and not the pump? Thanks in advance!
repair manual shoes that it sends single to pcm and that then sends sig to gauges and controls ingector out put
i would get a manual gauge from pep boys autozone etc and hook it up and then get readings from there that will tell you if you want to change sending unit or if you have bad gage then you will know for sure that you have oil pressure and what it is for surecould be loose wire
So he hot-wired the cooling fan last night and it is not working. Have another one on the way. Could there be something making it "go bad?" Dh says he is going to direct wire the fan to a toggle switch, as he feels it does not run enough. Only comes on after it hits 210. ANy ideas? It's an 01 Cherokee Sport, with 129,000 on it. 40,000 when I bought it, and the overheating problems started at the end of last summer.
How much will the shop change me if i have them change it. If its a lot i'll try to do it myslef but where and how? Any help?
I am planning to buy a 2007 Grand Cherokee Laredo (3.7L engine).
Should I be concerned about the oil pressure problem?
wirked fine b4 the blowup
a garage said its my engine harness thats bad
they sais if they pull and play w/it, it will start.
i did this it still wont start,jujst cranks
its driving me nuts
please help
thanx
if have spark then check if getting gas should be able to tell by pushing in little valve that looks like tire valve aut to have pressure there.
could be crank sencer back by fly wheel on top of bell housing
To me this was alot of money for a relay switch, so I got a hold of a jeep repair manual and the repair started by stating that the bumper cover had to be removed, the grill, radiator, and head light assembly all had to be removed just to access the relay. Well I could see where the price came from. I did some checking and a friend had the same problem I had he took his jeep to the dealer, the repair man showed him to remove the passenger side head light assembly which is one torx screw and a 7mm head long bolt, the headlight comes out with a little tug and help of a med. screwdriver, the assembly pops out of several ball sockets and you rest it on the bumper, with the wires still attached. You then cut a 3" by 6" chunk of the plastic that the headlight sits on, I did mine with a cut off wheel, when I removed the chunk of plastic there was the fan relay, it was pop rivited to the inter-fender well, a quick drill of the pop rivits and a 4wire plug I had the fan relay in my hand. I paid the $75.00 bucks for the dealer part, (there is a aftermarket one) but I opted for the dealer part. The part came with 2 screws and 2 rivits I used the screws pluged it in and that was that. Replaced the headlight assembly, re-set the the check engine light and removed the high temp codes, I was done in about an hour and saved $400.00 in labor. When you cut the plastic I went right to the middle and made a hole so I could see the part and enlarged it so I could get my fingers and tools in. Jeep Part # 5017491-AB Relay PKG 8052328. I really hope this helps someone it is such a simple job, the worst part was the cutting of the plastic but start with a hole that you can see into and go to town. Bill
Don't suppose you took any photos while you were cutting that chunk of plastic?
Once the photos are in your Album, when you click on a photo, there will be a box labeled "Embed Image."
Copying/pasting that code into a message here will show the pic in your message.
Hope this makes sense - there's an alternate way set out in the Help link at the very bottom.
My girlfriend's 2001 Jeep GC actually blew a 3" long crack in the radiator side tank at the upper hose flange. Her 24 year old daughter sat in a parking spot with the AC running for 20 minutes and never looked at the pinned temp gauge!
I replaced the radiator only to diagnose the fan doesn't operate unless it's hot wired. I looked for the cooling fan relay and gave up until I found your post on a google search.
Those pics would be a Godsend!
Thanks, Mark H. Oceanport, NJ
<img src="http://www.carspace.com/billnick/Al
http://www.carspace.com/billnick/Albums/Jeep Overheat Fix Fan Relay Re- /IMG_0360.JPG/page/photo.html#pic
I :confuse: don't know what I am doing I sure hope these Pic come out, there is a total of 7
You need to use the text in the Embed Image box that's on the individual photo's page to get the photo to show up in a post. Like this one of the relay:
Nice to see your explanation. Well I could not find the part no that you mentioned.
I have a same problem.Wn I slow down on lights the temp goes high and as soon as I hit the road..its absolutely fine and sometime below the half mark...
but wn at light..the coolant water start bubbling...which makes me tensed...
There is no problem wiht the car ..it runs really smooth...
Cud you guide me..i did not understand the plastic part too..
what i understood is that wn i remove the headlight assembly..then i will see a plastiv...so i have to make a hole in plastic to remove the relay fan...
moreover could you tell me...what does a relay fana and its kit consist of...i know i have written too long...but i wanna save some money like you..please help out
thnk in advance
aff
Bill
Joy
I hope I did this right the 1999 and 2001 are much the same, this fix is for the 4.0 6 cyl not the V-8...Good luck and let me know how you make out...Bill
According to owners manual pressure should be in the middle, so i believe somenthing should be wrong.
Apologize for my english, not my natural born lenguage.
many thanks, any help would be higly appeciated.
Jorge
I put a new oil sending unit in it now and it still drops to zero (only before it warms up) and revving it or accelerating just as before. Almost like a backwards RPM gauge when cold.
I guess I KNOW it is getting excellent oil psi. The only thing I can come up with is that the computer cannot read oil psi that high and makes it drop to zero instead of maxing out on the factory gauge when the motor is cold and its being revved or accelerated? I am now just telling the wife to drive the wheels off of it and not worry about the oil gauge+check gauges light in the mornings!
i would try to run some sea foam engine additive through the engine to free up the oil pressure releaf valve
if you run too high oil pressure the gears in the oil pump ware very fast then you have to replace pump also can eroade the berring serfuses on rod and main berings then you have to replace lots parts
Will keep all posted if I get any results
The new Toyota 5.7L is a Hemi-killer. The 4Runner will be bad [non-permissible content removed] when they put that engine into it!
THANKS WILLIAM
Also I have another problem with this jeep I don't know if anyone will have help for me on this forum but I'll ask anyways. Whenever I'm completely stopped and I press the gas the jeep stalls out and then comes back and jolts off. Its gets bad at stop signs and traffic lights. Always stalling. If anyone has a solution for this it'd be great to hear from ya.
Thanks, John
