Jeep Cherokee Grand Cherokee Engine and Performance Problems
 jmousseau44
                    Member Posts: 3
jmousseau44
                    Member Posts: 3
                                  in Jeep
                    Hi, I'm new here and looking for some advice on my Jeep Cherokee Sport. I'm not very mechanically inclined so please try and bear with me.
I recently took my jeep in because the engine began vibrating really bad during cold starts (in the morning) and after hot starts (?) after it had been running for over a half an hour, turned off then started again within say 15 minutes. When it would begin to vibrate the jeep would almost appear to be on the verge of stalling but never did. I ended up taking it in to a dealer and after looking at it determined it was the timing belt (mechanic told me it was set ten degrees ahead) and reset it. At first everything seemed fine but after 3 weeks now the vibrating seems to be returning (but no way near as bad as it was before). I'm also noticing that fan seems to be always running (though the heat gauge never goes over half) and what sounds like a pump (water pump maybe?) constantly working. I'm looking for some opinions on what could be going on before I take it back in again. My jeep has about 115,000 miles on it and I've been good about the maintenance. Like I said earlier I'm not really mechanically inclined so I apologize in advance if this seems to not make sense. Any advice is greatly appreciated.
-Jason
-Jason
The ECM will be a black box approximately 6" tall by 8" long and will have a large wiring harness connected to it. The harness should be fairly easy to trace. I don't know how you can check yours without having another Jeep you could try it on.
You should be able to go to ebay and find some. Be sure to check with a professional first, but I'm thinking you can use any year ECM from '92 to '95, just so long as the engine and transmission are correct.
link title
I'm not telling you to buy this one. I only provided this link as an example of what you might look for.
Jeremy
I noticed the temp. gauge was in the red and the overflow bottle was filling up.I checked all the fuses and they are good. I turned the heat on to get rid of the prob.; but I noticed that the radiator fan is not coming on at all. What should I check for or do ???
located under the front bumper cover on the passenger side,
or it is the cooling fan itself. both parts are known problems.
In my opinion as a jeep owner, a 1 owner none the less where is this problem coming from. i have around 135k mi and have done all the basic maintenance required.
Did this raditor shop put in a raidiator for a v6? i never had problems like this before that factory radiator went out, or is it a Bad Jeep design flaw because that grill shure is small to house any type of air flow for a v8 comapred to a like a v8 housing on a truck? hmmm Hopefully we will all find the answer to our needs? (should i install an electric fan) PLEASE HELP US!
link title
Did you put this radiator in during cooler season months and then later when warmer weather came along with it came overheating problems?
If this is correct' than radiator installed may not be
correct radiator for v8 needs to keep car cool.
Recheck radiator size or radiator part number to see if this is the correct radiator. Also if it is' then completely flush cooling system so it,s cleaned out. Could be a flow restriction somewhere. All I could think of.
I have started having this same problem . I re-did my entire cooling system and my Jeep still gets hot 210 so far. I am going to run without a thermostat , flush the system again , and try some " Royal Purple " and wait and see what happens .
I had this problem once before with a Thunderbird in the early 80's . This problem seems to occur after 100k .
I never could solve the problem on the Tbird , it just kept getting worse . PS both vehicles were purchased new and were well maintained .
If any body has a solution P L E A S E let me know .
I've never heard this. However, when a water pump goes out, many times it will start leaking coolant and will cause the light to come on. Just because the light comes on, doesn't mean the pump is bad. You could have a leak elsewhere. Have your mechanic pressure test the cooling system. If the leak isn't obvious and the pressure gauge is going down, then check the heater core and engine oil. If it's the heater core, you'll smell the anti-freeze inside the Jeep. If it's the head gasket, then coolant will leak into the engine oil and will turn it into a sludge resembling chocolate milk.
How many miles are on this Jeep? Three water pumps sounds like too many.
Nine months later, the oil pressure gauge drops to zero when the engine gets hot and the RPM goes low when pulling up to a stop sign. Comes back to normal at highway speeds. Now the dealer is saying the "pig-tail" connecting the sending unit to the gauge is leaking and causing erroneous readings.
Lossing coolant, funny smell, running rough, how much is a heater core?
Regards
Desmond
I am experiencing the same problem on a 2000 GCL. Have you gotten any results to fixing your problem?
Doug
Charley
And it is a 2000 Cherokee Sport 4D/4WD 6cyl.
So far it's been running ok but with winter coming I'm a little concerned. I keep up the maintenance on it but you never know.
Jason
Checking the timing again would be my next move. If it's off, retime the engine and put some Lock Tite on that bolt.
A repair manual should give the acceptable range of resistance for an operable TPS. Using a Ohm meter, test the sensor to see if it's bad.
How does the exhaust smell at idle? Does it smell like it's running lean or rich?
