Details of GM's 3800 Model Engine Recall
Next problem is my gas gauge. I did Notice today that when i put gas in it (20 bucks for 6 gallons). It kinda worked as in it was floating around 3/4 marker. which i know is not right because my gas light came on. I did learn when my gas light comes on i have 4 gallons of gas left in my car. I know this from when keeping gas in my an keeping track of the gallons used an also running out of gas a few times. This promblem needs to be fixed asap an i do not know where to start? Do i start with the gas sensor or is it my Speed gauge Unit? I dont know much about cars for wiring part at least. Any Help would be awesome.
For those of you that have problems with your blinker. My car does the same thing they go out when they want to. All i can say that i have been told by many people is that it is a bad Ground. If my blinkers do not work i repeatedly keep pushing my hazard lights till it stop buzzing an they work just fine.
If someone one has an answer to the two problems above if you would so kindly send me an email at ( tallie942@gmail.com ) to let me know with the tittle Monte Carlo solutions.
I would greatly appreciate it.
thank you
Trave
Have you tried pulling the blinker handle towards you or pushed it towards the dash?
Let me know if i was able to help you.
