Found out that they also control your spending speed in another way. I decided to throw five thousand dollars in my GM credit card account.
I thought this would quickly pay my bill and allow my spending limit to return to the maximum credit. This prepayment resulted in the freezing of my account. Several companies received a DENIED notice upon attempting to charge my account. GM`s explanation = we have to wait about 6 days for your check to clear. That is exactly why I sent the check in 10 days BEFORE I accrued charges against this check.This is WEIRD! Even though a second before they posted my $5,000 prepayment, I had over $6,000 shown as "available credit". Again it is another form of credit that you can not use.My last several Card notices have shown "0" amount due due to my heavy purchases but larger $ amounts in prepayments. They sure slowed my purchases up by freezing my account until the prepayment check clears - I have never exceeded my available credit limit. Intend to ask my states attorney if this action is illegal. Will also look into the false or misleading advertisement area.
Will observe GM`s advertisement regarding the holding of price for year 2003 SUVs. If they remove items such as ABS from the same 2002 SUVs they sure as hell have NOT held the same price. THIS IS AN INSULT TO THE BUYING PUBLIC. Do they think you are that stupid!
Another note:
The 6-20-02 MAXIMUM ALLOTMENT amounts that you can use for the purchase of a 2003 SUV are:
For Tahoe or Yukon = $1,500.00
For Suburban or Yukon XL = $1,750.00
You can earn more but can`t use them all at once for the above purchases. Just wanted to see if you think that this is false advertising or simply misleading, or O.K.
Has this happened to anyone? Could this be the crank sensor? Yukon was built April 02.
Warranty question Can I bring it to a Chevy dealer who does not sell GMC?
The new card does not limit what you can accumulate per year, but limits ythe amount you can apply to a given vehicle.
Have had fun with trying to squeeze the absolute maximum amount of earnings per month out of GM. Prepayments worked for a while, until they started freezing my card for 6 days at a time. It is interesting that when I want to throw GM $6,000.00 or $8,000.00 - before I make my next group of purchases - they have the need to freeze my account for about 6 days at a time. This is even when I don`t owe them one cent at that time. Seems like most credit card companies would love customers who pay BEFORE they incur a debt.
Have fun with life gang. I do.
Steve
'03 surburban w/ the 8.1L engine shipped to California vs. another state. I had a '99 w/ the 7.4L that I bought in Florida, it did not have a smog pump or any other california emission equipment. Looked at a '02 surburban the other day, in CA, and it appeared to have a smog pump, want to know if there is anything else, fuel mapping? cam? help!
MODERATOR /ADMINISTRATOR
Review your vehicle
Waiting for them to brainstrom. Day three without my beast.
How long do I give them to figure this out?
Has anyone got a Demo to drive or a better vehicle than a Ford escort? that's what they gave me
there is a slight moisture buildup (slight dampness) under the 3rd row floor mats. the mats have no moisture on top, it is only underneath them. any thoughts on why this is occuring?
Anyone with the problem please contact me.
jimbrown@remax.net
Do any of you know WHEN the 03 Subs and XLs will be available to spec and order??
Thanx in advance.
http://media.gm.com/division/2003 prodinfo/index.html
Seems to give a lot of info on most 2003 units.
Don`t quite understand this computer stuff.
For some reason the site here did NOT include all of the information I typed.
I also noticed that there seemed to be one space in Cliff`s site.
That space was between 2003 and prodinfo.
Can`t list his site here - against our site users agreement. Maybe someone with more knowledge can straighten out this sites address.
Would it make any difference if there was a back slash after "html" ?
I will delete after three days just to stop nice foke from trying to reach a site with improper info.
Steve
1. While on that other site if I click on the high lighted URL I get the good info at GM.
2. Typing the same information into makeashorter link does not take me to the same spot and can see no link to get the info.
3. If I start with a fresh browser screen and type the same info that is on C.W`s site I can NOT get to the correct GM site.
I give up since I also tried another URL that was listed on his site:
http://www.gm-trucks.com/ART 2003 prodinfo/index.html
On the other site the above two lines was all on one line and all was high lighted. On this URL there was one space before and after 2003.
After reading this feel free to remove my posts both here and on Tahoe. Don`t want others to waste time trying to reach GM thru my bad info. Can`t make this work.
tidester
SUVs; Aftermarket & Accessories
Steve
http://media.gm.com/division/chevrolet/
then select Trucks then Suburban.
2003 will then come up.
With LOTS of info.
Enjoy
on my wife's LT.. the front tires were wearing and slightly cupping on the extreme inside tread both sides.. Truck tracked true and straight.. no problems pulling or drifting to either side.. dealer svc said all was ok.. that 4wd's needed extra care and tires should be rotated every second oil change to keep them correct...hmmmmmm????
on my Z71.. extreme front tire wear and cupping similiar to my wife's Subn but more so..truck tracked true and straight.. no pulling or drifting... I had them look at it the same day as the other one.. told me the same story.. all 4wd Subn's can go out of alignment so tires should be rotated every 2nd oil change.. yet they said both trucks didn't need an alignment . another strange hmmm...???......they rotated the tires on both trucks..
having had a number of 4wd trucks in the past including Explorers, Expeditions, and most recently a '99 Subn and having 'messed around' a bit with cars all my life , I've never run into this kind of b.s......
a few weeks ago after the above, I take a trip up north from NC to NY putting about 2000 miles on the newly rotated tires on my Z71... uh-oh.. the front tire wear is starting again... seems like Chevy has dropped the ball..
I just now returned from my local Front End alignment shop (not Chevy).. the tech said that the Subn front end is weaker and has smaller sized steering arms than previous models...that it had to be checked a couple of times a year... he adjusted the front end to toe-out from a toe-in situation that caused the wear..... gave me a computer digital sketch/printout of specs before/after.. also said there is no way that a vehicle like mine should be out of alignment and wear the tires the way it did in 16K miles...
I checked for service bulletins re: this problem.. couldn't find any... if anyone has experienced this problem or knows of a Chevy-service bulletin or has any other ideas, please advise..
thanx
the Chevy dealer svc mgr said..' it's those big 4x4's that you have to rotate the tires every 6K miles'... I say hogwash.. Chevy must have a problem or they wouldn't be telling their dealer svc techs to be saying that..
and since yours is a 2wd.. hmmm?? I would say their problem is widespread...
as far as Chevy-Ford.. they are the same to me ( yipes.. did I say that) ... my wife and I usually go with the one that gives us the best deal when we are ready to get a new one..this last time we wound up with 2 'burbans..got them at invoice + $98 minus the $1K loyalty rebate minus the $1K dealer cash incentive.... leased both ..
both Chevy-Ford have their bad and good points.. they seem to even out though for us..the only Ford truck I've had problems with was to the front end of an old 2wd Explorer a number of years ago...they couldn't get it to align correctly after 12 tries... but Ford made good on it with a $4K credit toward any new Ford product... I was happy after driving it for two years of a three year lease.....and since all I really wanted was at the time a new set of tires to get me thru the rest of the lease....
sounds like I'm going to have to contact Chevy directly to go thru that b.s... it should be interesting to say the least..
http://www.metropark.com/safewaytire/tireware.html
Out of curiosity, what tires are on the two vehicles? I used to live in Britain and since moving to the US I have noticed that wheel balancing here does not seem to be done very well. Perhaps it is because of the lower speed expectations. The cupping problem you mention could be due to a balance problem.
Although I have no experience on truck tires, the balance problem seems worse on cheap brands of tire rather than premium brands such as Michelin. In my experience this is especially evident as the tire wears after a balance is performed.
my Z71 has the factory 'stock' tires.. Goodyear AT/S 265/70R 17" tires on it... my wife's LT subn has 265/70R 16" Firestones... I seemed to have 'caught' hers with less wear than on mine.. basically same situation.. same wear on the inside
the tires are NOT out of balance.. the truck runs 'true' with no drifting of any kind.. no shake or shimmy at any speed all the way up to 70+ mph cruise on the interstates.. I've had the tires checked..
the way I noticed it was a louder than normal noise .. these Goodyear All Terrain 'stock' tires are noisy to begin with ( knobby tread) compared to my wife's Firestone's
there's no doubt in my mind that Chevy/GM has a problem that they'll probably acknowledge in the future way beyond my getting rid of both trucks after our leases are up...
the way the svc mgr was talking ... all 4x4's need constant care .. not so in my experience.. no more than any other truck/ car with so-called normal everyday regular usage..we don't go off-roading or such nor do we tow at all.. I can guarantee that most of the suburbans out there are doing the same thing.. people just don't notice it..
butt I'll just 'bug' Chevy about it just 'because'.. have to be a thorn in their backside after this..
like I said in the previous post.. seems like my Z71 showed a lot more wear faster than my wife's LT 'burban did albeit the same type of wear on the inside.. .. maybe because of the 17" wheels and different suspension setup ..??? hmmm??
according to the tech at the Alignment shop, it'll have to be watched pretty closely .. and that to me is 'nutz'.. Chevy messed up and we're paying for it..
