Toyota 4Runner Recirulated Air
zaczac Member Posts: 1
edited February 2014 in Toyota
My 2003 4runner allows exhaust smells to enter the car even when the system is set on recirculated air. How do I correct this problem?
  • kyfdxkyfdx Moderator Posts: 270,275
    Exhaust odors might not be related to your HVAC system... It could be an exhaust leak, and should be inspected. Any time you smell exhaust, you could also be breathing carbon monoxide (which has no odor).
  • willk1willk1 Member Posts: 3
    I agree with kyfdx. I'd check for an exhaust leak. If you drive with the back window open, that literally pulls exhaust into the car.
