They replaced the cabin air filter...said that might work...it was dirty....we will see. Kinda getting worried the mechanic at the dealership doesn't know what he is doing & is going to run my bill up......HELP!!
I also have bits of the spongy insulation coming out of my upper vents. Related?
I had the same problem. Mine was the vent insulation stuck in the squeal cage part of the fan. I think more fell, the noise is back but not as loud. Its just time consuming and a pain in the back to get to it all.
How about this one. I never had good heat. Now I have none. The temp on the dash has always been low. I even had a shop tell me that was too low. It's been to 3 different dealers. Never said a thing to me about it. Now I want heat. I went to the local shop. Was told about $800 to fix it. I know if I tap the am/fm on the radio, It shuts off like lost power. The directional that controls the dash lights flickers when I touch it of try to turn on the interior lights. The rear defogger never worked. Is there an underlying problem I should be searching for? I will be getting a new top soon because of the seal on the rear window has now let go. Please give me some thing to look for or try. Thankx for reading most of my complaints on my 2001 LXi 2.7l
I have the same issue, so did you get it fixed??
I've got a 2009 sebring. Recently, the fan switch on the control panel(dash) stopped turning on the fan, which now makes the ac not work. The wife is not happy. When she turns the knob, nothing happens...
Curious if there is an obvious issue. Maybe the switch is broken? It is after all, plastic hahaha.
I haven't started to diagnose the issue yet. Hoping for a quick fix.
