GMC Yukon XL and Yukon XL Denali
1697072747579
    You could check what we say as another point of reference:
    Edmunds Maintenance Guide
  • rand01rand01 Member Posts: 75
    I also have my 2004 version of your Suburban entered on mygmlink.com, heavy use, and see no mention of a Drive Axle Service. Owner's manual doesn't mention anything either. Does your owner's manual say anything about the service?
    I remember my 2000 called for changing the rear differential fluid after the initial 5000 miles when equipped with the locking rear end. No mention of it with the 2004.
  • jgmilbergjgmilberg Member Posts: 872
    The reason they don't offer Quadrasteer in the 1500 is the rear spring set up. The 1500 models have coils and I think the only way they have figured out how to make work would be an all new independent rear suspension instead of the old solid axle they have now. I have heard rumor running around that GM is planning a new independent rear end for the next gen full size suv's, until then it's a 3/4 ton model option only. The leaf springs on the 2500 models offers the stability needed to handle the wheels turning w/o causing all kinds of stability and deflection issues.
    Now for the lights and wheel flares. The clearance lights are forced onto the vehicle because when the wheels turn in the rear they stick out farther than federal regulations allow, so they had to stick on the big fat flares to make them happy. When they did that it made the truck too wide to fit in the standards so the feds again jammed GM up and forced all those clearance lights on the vehicle, just like the dually pick up trucks. The engine size is limited by the 2500 series specs, and the 6.0L engine is the smallest engine available for a 2500 were all kinda stuck.
  • lkbumlkbum Member Posts: 6
    I have a 2004 Deanli and it makes the same noise. Very random, never for 10 to 15 seconds. seems to happen more often when the car is warm and once it is restarted after a moderately long drive, followed by a restart. I have tried EVERY THING to get this damn thing to repeat before taking it to the dealer. I suspect it has something to do with the ride leveling. Sometimes, it a single source "pitch", other times it is two sources of slightly different pitch. How does the load leveling system vent?
  • aa555zzaa555zz Member Posts: 55
    This is what the owner's manual has to say about the drive axle service every 7,500 miles: Check rear/front axle fluid level and add fluid as needed. Check constant velocity joints and axle seals for leaking.
    When the time came for my '01 YXL I installed Michilen LTX M/S tires. They have a slightly more aggressive tread pattern, but they are extremely quiet. They run great in the snow and rain, a whole lot better than the factory tires. They do cost more but they are worth it. The ride and wear was great. Since you have a 1500 model you can get the "C" range tires that will give the same if not better ride and wear.
    Were you towing anything when you noticed the problem? They say not to tow anything for the 1st 1500 miles because the computer is "watching" your driving style and setting the trans shift points and firmness based on the way you drive the truck. If you were not towing anything and the problem pops up again try disconnecting the battery for 10 minutes and take it easy for the first 500 miles-try not to take off hard from lights and make a lot of full throttle maneuvers, like passing on a 2 lane road after that all I can offer is the dealer. They would have to duplicate the problem while the diagnostic computer is hooked up monitoring the trans.
    Perhaps it was something a bit simpler, like accidentally engaging the tow/haul mode while cruising down the road on that 5 hour trip! I don't know if I'd classify it as shifting "jerky", but it definitely shifts more firm than when in the standard mode. Either way, it must be OK now since he hasn't posted any more about it.
    While on that subject, are all you guys that have posted about funny/unusual noises or other problems still living with them or did you finally get them fixed? How about enlightening the rest of us as to what the resolution was!
  • ostazostaz Member Posts: 80
    jgmilberg:
     No I am not towing anything, and the truck has 70,000 miles on it (2000 K2500). The problems only happens after a relatively long drive, say, 45min or more. Then when I slow down for whatever reason, the downshifting, and consequent upshifting is much harsher than normal. Once I resume normal, in-town driving (5 min or so later), the problem disappears. That's why I am thinking it's heat related. I did flush the tranny, with no effect, and also disconnected the battery to reset the computer.
  • cjamesctcjamesct Member Posts: 2
    Am shopping for Suburban/Yukon XL, but no GMC dealers near home. Will Chevy dealerships do GMC service work?
  • kiilewkiilew Member Posts: 17
    I want to revisit an old issue that has been written about before here, although I can't seem to find the information I need.
    Specifically, I need to track down a TSB concerning low speed vibration that affected some 2000 Suburbans.
    I am not sure if this is relevant to my 2000 Suburban 1500, but recently it was hit in the right rear wheel which necessated straightening the rear frame (the axle was displaced to the left about 1.5"). The work was performed by a Chevrolet dealer with a very reputable body shop using laser measuring equipment, and the rear axle was replaced along with the right rear wheel.
    Immediately upon picking up the rig, I became of aware of an unusually loud reverberation in the car interior that takes place between 33 and 50 mph. Three sets of tires and a new driveshaft later, the noise persists. The whole effect seems to be more of a sound than an actual vibration, almost like wind buffeting inside the cab (!) but it didn't do that before the accident, and my 2002 Tahoe sure doesn't have the same problem.
    It looks like that old adage about a wrecked vehicle never being the same is absolutely true. But I haven't given up quite yet. If any of you have any ideas let me know!
  • tdatda Member Posts: 1
    Wow, I had the EXACT same thing happen on my 2002 Yukon XL last week. I had exactly 37,400 miles on the vehicle - typical that it is right out of warranty. A friend that works for GMC said that this was a problem they experienced a lot - I'm looking to have the dealership goodwill the repair....cross your fingers. It isn't the first problem I've had on this car. I've had more warranty work on this vehicle than on any other new car I've owned. Maybe next time I'll go back to the Jeep Grand Cherokee....drove it 70,000 before the first incident. Love the Yukon - but sure wish it had less issues.
  • dilbertzzzdilbertzzz Member Posts: 190
    I had a TV repair guy tell me last week that the newest TVs are the worst for repair problems. He said it's because they are saving costs by out-sourcing more and more parts, and those parts they get are not always up to the specs they might specify.
    Vehicles are increasingly big electronic machines, so they might well be experiencing the same affects for the same reasons. In fact, the out-sourcing, with its inherent loss of quality control, might also be affecting the strictly mechanical parts too. Something to think about in our highly-price-competitive environment.
    It might well be that anything newer isn't going to measure up as well. When/if you return to the well-remembered as more reliable "Your favorite brand name here" world, you might find it ain't like it used to be (join geezerdom!).
    Depending on how the truck was equipped you may or may not have and external/auxiliary trans cooler. Every auto transmission vehicle has a trans cooler built into the radiator but that's not always enough cooling under a heavy/fully loaded trip. If your rig does not have an additional cooler in front of the radiator you might want to consider having one installed, they only cost about $50-$75 at the local parts shops and should be less than $100 to install it at a trans shop. This will increase the life of the trans and would keep the temp down. What does the trans temp gauge read when the problem pops up? Does the trans temp drop when the problem goes away? When it comes to transmissions the cooler the better they always say.
    Generally speaking if the truck is covered under the factory 3 yr/36,000 warranty they will not cross service. I have heard of a few people calling GMC and getting them to allow Chevy dealers to service the GMC products, but you have to be X amount of miles from a GMC dealer for them to allow this. If it's a used vehicle or out of warranty truck chevy will service GMC and vice versa no problem. Sometimes the GMC dealer might be part of a dealership group and will allow you to have the truck serviced at one of the other dealers in their group that is closer to you, but that's something that you would need to ask them about. If it's just regular routine maintainance any GM dealer would be able to perform that kind of service w/o a doubt. Rule of thumb - if you pay any dealer will service, if GM is footing the bill it has to go to GMC/Chevy depending on brand for service.
  • pegleggerpeglegger Member Posts: 40
    While outsourcing might be an easy scapegoat for quality issues, the facts don't back it up. Outsourcing to China, for example did present a significant quality challenge, but Motorola (just one of many American manufacturers) quickly implemented their 6 sigma program and achieved similar quality levels.
    I wish we could keep manufacturing domestically, but the reality and the global marketplace just don't allow it if manufacturers are going to compete.
    I'm in manufacturing and, believe me, I used to always warn our customers of going to Mexico, Brazil, China, etc., but in the end the customers for the most part was able to prove me wrong (of course there were hiccups involved, too.)
    As to American car manufacturing goes, I've been very impressed with the quality levels of all US car manufacturers over the last 10 - 15 years....Anecdotally, my US cars have definitely spent less time in the shop than my European cars.
    Just my two cents...
    I agree with peglegger about with the quality of newer American vehicles. I don't remember any of my 1980 thru early 90's era vehicles having a 3 year/36K mile warranty, but I do remember numerous petty things going wrong with them, all too often. I doubt I will ever have fond memories of any of them being more reliable than my current vehicles.
    This has not been the case with my 2000 (once they got all the first years kinks worked out of the NBS) and 2004 Suburbans. Though, being far more technically advanced, problems have been fewer and they provide more power, comfort and safety. Sure, with all the electronic gizmos controlling and featured on our newer vehicles, there is more potential for failure. Hopefully these will be the exception and not the rule (true in my situation)!
    that the newer domestic vehicles have improved quite dramatically in quality when compared to the Japanese companies' products. Of course, by Japanese I (and almost everyone) really means Honda and Toyota. I can't think of any others with markedly better reputations than those two over domestics. The European makes are worse than those two, though probably better than the other Japanese and the Korean makes.
    Even so, the newer, and especially those bigger vehicles, of both Toyota and Honda have not measured up to their own company's reputation in actual reliability. Maybe still near the top, but sliding a bit.
    I am just wondering if we have already gone passed the peak of quality and are perhaps on a downward slide again, not yet recognized by most of us.
    The TV example is of purely electronic devices. Vehicles are getting more so. If TVs are suffering in quality, perhaps the electronic portions of our vehicles will follow that same trend.
    Of course, if I turn out to be correct, I'll never let you all hear the end of it. But, if I'm wrong, I'll probably let my aging brain conveniently forget all about it. "Honestly, Senator, I simply cannot recall." ;-)
    How does one adjust the headlights on a 2000 Suburban? one side is noticeably higher than the other.
    Sam
  • lobsenzalobsenza Member Posts: 619
    I remember seing a device somewhere that will unlock all doors with one push of the keyfob on our SUVs. Now I can't find it. Anyome know where I can get a device that will do that.
    First check to make sure that the lights are installed properly and that the mounting bracket is not broken. On top of the light are 2 "L" shaped pins that position the lights. To remove them pull the "handle" part out of the holder and pull them straight up. the light will have to be wiggled around to get it out of the pocket. Check the bottom mounting holes, if they are cracked or broken then you need a new bracket, if not put the head lamp assembly back making sure to engage the lower bracket holes. The owners manual has a decent illustration of the procedure. If this doesn't fix it then aiming will be nessesary.
    There are 2 adjusting screws in the mounting pocket, they look like stars, or the head of a torx driver. You can use a 7mm or 8mm 6 sided socket if you don't want to buy the actual socket. Do not force anything, any resistance at all and you need to STOP if you force it you will break the adjuster and need to buy a replacement adjuster from the dealer to fix the problem for around $21 each. The horizontal (side to side) adjusters are in the core support in the holes right next to the hood bumpers, the vertical (up and down) adjusters are in the plastic radiator cover there are oval holes near each end of the cover. What I do is set the car/truck 20 to 25 feet from my garage door and adjust them using the panels in the door to get the alignment I want. Let us know how you made out.
    I will try tonight and post.
  • 248989048248989048 Member Posts: 1
    I own a '03 Yukon XL and since May I have a terrible odor coming from the AC vents when I first crank up the vehicle. I have had it deodorized at two different dealership for a total of 9 times but the odor is still there. Is anyone else experiencing this problem? Please let me know. GM said there is nothing they can do about it, the dealer said not to bring it back for this type of problem. I only have 15,000 miles on it. Also I have a high pitched noise coming form the dash area, that is sporadic at times.
  • terryasullivanterryasullivan Member Posts: 24
    Early Suburbans had a vibration/noise problem related to body/frame mounts/insulators?
    Maybe you got some of the original parts.
    my 1 cents worth.
    searched this forum using 'vibration and suburban'.
    Found some info in message #906.
    I've had the mildew-smelling AC problem on several cars and know of friends with it too. It seems to build up from running the recirculate too much (doesn't let the outside air whisk out all the extra moisture or something).
    Anyway, a friend with a BMW experiencing the problem some years ago found some tablets at an auto parts store that was supposed to kill the mildew. I can't remember if he had to drop them down the intake vents outside at the base of the windshield or if they went into the interior output vents....
    Personally, when running in dry air without recirculate on doesn't solve the problem, I've killed the stuff pretty effectively by spraying massive amounts of Lysol down the exterior intake vents (at the back of hood by the base of the windshield) while running the AC (recirculate off -- you might have to take the Auto climate control off, if you have it). Be sure you have the windows all down and run it long enough afterward so the Lysol fumes don't kill you off too!
    Oh yeah, you probably want to keep the Lysol off the paint as much as you can and test it on some of the plastic around the vent first to make sure it doesn't do something nasty to that either.
    Nine trips in for deodorizing and it still smells? According to the shop manual, a .125 inch hole is to be drilled in the HVAC module between the evaporator core and the blower motor. This is where they insert the extension tube for the deodorizer agent to be dispensed. After complete, it is to be filled with a sealing compound, which means you should be able to find that sealed hole if they in fact deodorized it by the book!
    Perhaps you have something besides microbial growth in that evaporator core?! I wonder if some kind of critter could get down into the HVAC module? If that noise is coming from the HVAC unit, might be a good excuse to have the dealer tear that thing apart and get to the bottom of your problem.
  • beach15beach15 Member Posts: 1,305
    Almost 3 months and 5500 miles now with the '04 Suburban and it's doing great, but there have been some issues. The loud creaking in the driver's side quarter panel area over bumps was eventually fixed by the dealer. The invoice said something about replacing and reinstalling the jack, installing a rear wheelwell insulator, and something else. So that's fixed.
    Now, a couple more issues:
    -The loud exhaust popping that I read about a couple of months ago and thought people were crazy over, we now hear and it is very annoying. Used to just do the pinging/popping when turned off and cooling down, but now you can clearly hear it when at a light or stopped and it is not faint, by any means. Anyone have this issue and get it fixed yet? Or is GM not doing anything about it?
    -When the AC is on, there's a constant "whirring" sound inside the dash. Sounds like something's wrong in the ductwork. It isn't overly loud, but it doesn't sound right and continues for about a minute after you turn everything off. Again, anyone have a similar issue or get it fixed?
    It is the muffler. The entire exhaust system has to be replaced. It will last for a while and happen again. GM offered to cover half for me the second time since i was outside the factory warranty and exhaust is not covered by the extended warranty. Half translated to $1000 and I would put in an aftermarket muffler before i paid for a fix that lasts 20k-30k miles. But, if it is under warranty, have them replace the exhaust system.
    More than likely it's the cooling fan on the back of the radio. The heat - A/C blower motor shuts down as soon as the ignition key turns off, while the radio fan will keep on going until the radio cools off. My '01 had a bad radio cooling fan they had to replace the radio head unit. It could also be the temp sensor fan you are hearing, it's the speaker looking thing above your head on the drivers side. I have heard complaint about those motors being really loud.
    Here is the TSB for that issue they have to install a kit that runs the blower motor for a few minutes after you shut the truck off to eliminate the moisture on the evap coil under the dash. If they just deodorized the truck and not the A/C system it won't do any good. This TSB only goes up to 2002 but I never renewed my info CD's so I'm sure it went to the next model year. The dealer can just punch in the numbers w/o the "A" and it will pull up the latest TSB for this issue. Good luck and make sure to let us know what happens. If the service writer refuses to deal with the issue ask for the service manager, and if that doesn't work give the GMC 800 number call and file a complaint, as a consumer it's the best way to let the dealer you mean business. Well anyways here's the TSB.
    Air Conditioning Odor (Install Kit) #99-01-39-004A
    1993-2002 Passenger Cars
    1993-2002 Light & Medium Duty Trucks
    This bulletin is being revised to update the model years, service procedure, parts information and to add the GEO and Medium Duty models. Please discard Corporate Bulletin Number 99-01-39-004 (Section 01 - HVAC).
    Condition
    Some customers may comment on odors emitted from the air conditioning system, primarily at start-up in hot humid climates.
    Cause
    This odor may be the result of microbial growth on the evaporator core. When the blower motor fan is turned on, the microbial growth may release an unpleasant, musty odor into the passenger compartment.
    There are several other possible sources of a musty odor in a vehicle. A common source is a water leak. Follow the Service Manual procedure for identifying and correcting water leaks if other odor sources are found. The procedure contained in this bulletin is only applicable if the source of the odor has already been determined to be the HVAC module.
    Correction
    To remove odors of this type, it is necessary to eliminate the microbial growth and prevent its re occurrence. To accomplish this, the following steps must be completed:
       1. Apply evaporator core Cooling Coil Coating (Aerosol 6 oz), P/N 12377951 (AC Delco® 15-102) (in Canada, use P/N 10953503) or Cooling Coil Coating Kit with Extension Nozzle, P/N 12346391 (AC Delco® 10-120). Refills are available for the Cooling Coil Coating Kit with Extension Nozzle, P/N 12346391 (AC Delco® 10-120). Refer to the chart below.
       2. Install the Electronic Evaporator Dryer, P/N 12497910 (AC Delco® 15-5876).
    Important
    The Cooling Coil Coatings listed above are the only GM approved products for the disinfection and long-term control of evaporator microbial growth.
    The Cooling Coil Coating will disinfect the evaporator core and help inhibit the growth of future mold and mildew.
    The Electronic Evaporator Dryer will activate when the ambient temperature near the module is above 16° C (60° F) when the vehicle is started up. Approximately 30 minutes after the vehicle has been turned off, the blower will activate for 10 seconds every 10 minutes for 2 hours unless the vehicle is restarted. If a restart occurs, the Electronic Evaporator Dryer module will reset automatically. This on/off blower activation will dry the evaporator core and case reducing the chance of reoccurring A/C odor. The Electronic Evaporator Dryer is self fused and has a battery rundown protection feature that inactivates the dryer if voltage drops below 12.5 volts.
    Service Procedure
       1. Visually inspect the air conditioning evaporator drain hose for obstructions and/or working condition.
       2. The cooling coil coating fluid must be applied to a dry evaporator core. Apply coil coating fluid as described in the instructions supplied with the kit. In some instances, the blower motor resistor can be removed for this spraying operation. If used, the opening can be taped over and the nozzle inserted through a hole in the tape. The kit instructions identify a drilling procedure to apply the coating fluid. When using this type of procedure, care must be taken to avoid evaporator damage and any holes must be properly sealed. Some coating fluid may overflow from the drain hose.
          Important
          When installing the Electronic Evaporator Module, you MUST use the included electrical splice connectors to ensure a proper splice.
       3. Complete detailed installation instructions and wire connectors are supplied with the Electronic Evaporator Dryer. The ground wire should be attached to a body ground source. If any other wire splicing procedures are needed, follow the wire repair procedures in the Electrical sub-section of Body & Accessories in the appropriate Service Manual. If required, the evaporator dryer can be installed underhood away from extreme heat conditions (i.e. exhaust manifolds) and/or water splash areas. In all cases, the evaporator dryer module must be secured with a Velcro® strip (not included in the kit), or you may use the integral hooks to utilize tie straps. Using a Velcro® strip is preferred as the use of the integral hooks may cause rattles.
       4. When the installation procedure is complete and power is supplied, the module will self-test. Thirty seconds after power is supplied, the high blower speed will be activated 3 times (for 2 seconds per cycle). When the test has run, install the Electronic Evaporator Dryer label on the blower motor case in a visible area.
    Parts Information
    Part Number
    Description
    12377951
    (AC Delco® 15-102)
    12346391
    (AC Delco® 10-120)
    Cooling Coil Coating Kit w/Extention Nozzle
    12346390
    (AC Delco® 10-121)
    Refill for Cooling Coil Coating Kit
    12497910
    (AC Delco® 15-5876)
    Electronic Evaporator Dryer Module Kit
    Parts are expected to be available from GMSPO, 6/4/01.
    If you drive in an environment where you need very bright lights, I found a solution that works for me.
    In the 2000+ models, you can either use the low beam or the high beam, but not both at the same time. I found this company,premiermotoring.net, which sells a setup that allows you to use both when you switch to high beam. Very bright indeed.
    They also sell a more powerful backup light bulbs. I find that the stock ones are very week. I also replaced the low beam with a PIAA Xtreem White bulbs, big difference.
    Sam
    Great info! Thanks Sam.
    I have a 2000 2500 LT. When I push the 4wd-hi, I smell burning (like oil burn). I checked both rear and front diff, no leaks, also the fluids have been changed recently (it smelled before the change).
    Any ideas?
    Sam
  • mark366160mark366160 Member Posts: 4
    I recently purchased an 04 burb LT 2wd. At the time, I thought all 04s were the "flex fuel" variant and didn't pay much attention to it. My previous truck was an 01 Tahoe LT. Both vehicles claimed 14 city/18 hwy mileage, and both vehicles deliver that (my city mileage is ~15/hwy 18 but with a nice tail wind ~20).
    Anyway, later I looked on several websites and noticed that they also have the same engine for 04 listed as "gas" which rates 15 city/20 hwy. Forget what I actually get (I know mines a flex fuel version)... Are there actually any "gas only" versions out there? Is the only difference in the engines programming? If so, is there a way to reprogram mine to be the "gas" version and give me the extra 1/2 MPG?
    Flexfuel I guess is a good PC selling point, but there ain't any flexfuel stations anywhere in the Dallas area, and even if there were, the cost would probably be higher, and from my understanding, running on E85 gets poorer gas mileage than running on straight gas.
    Anyone have any experience with any of this?
    Thanks...
  • glsable2glsable2 Member Posts: 28
    I didn't realize that the gas-only engines had a better EPA mpg rating than the flex-fuel engines.
    I did know that there are two engine types listed on the RPO codes, but all the Suburbans/ Tahoes/ Yukons that I have seen here (Virginia) have the flex fuel engine. Not sure why, since ethanol (grain) fuels are not sold here*. Perhaps GM gets a credit for selling lower emmission vehicles? Or at least vehicles that are capable of lower emissions since many of them will never see a drop of ethanol-based fuel.
    I am guessing that the lower mpg rating is due to the fuel itself (which the EPA would use as the worst case for the flexible engine). I expect the Flex Fuel engines will get the same mileage with gas as the gas-only engine. It would be interesting to know for sure.
    glsable
    * in northern Virginia we do suffer with "oxygenated-fuels" that put 10% more oxygen in (and therefore 10% less gas and mileage drops 10% (surprise!).
  • jay_24jay_24 Member Posts: 536
    From what I remember seeing was tha the two 5.3 versions (gas only and flex) get teh same MPG at 14/18. I believe the 15/20 that you see either the new Displacement on Demand one or the gas/electric hybrid version.
    The DOD is on the Trailblazer EXT and the hybrid is on limited 1500 pickups.
    Another possibility is that you saw 2wd numbers.
    --jay
    I went to the following website:
    http://www.fueleconomy.gov/feg/bymodel/2004_Chevrolet_Suburban.sh- tml
    and the information provided is as follows:
    C1500 Suburban 2wd "regular" : 15/20 (city/hwy)
    C1500 Suburban 2wd "flex/gas" : 14/18
    C1500 Suburban 2wd "flex/E85" : 10/14
    That site is actually the first place I've seen that really shows what mileage you get when you run E85. It also seems to show that the flex fuel version pollutes more when using gas then the straight gas version....
    Anyway, it sure would be nice to know if I could somehow seemlessly make mine be the normal version...
    Mark
  • looramlooram Member Posts: 17
    Greetings from Nebraska! Here you can get any 3 combinations of engines, although most dealers stock the flex fuel/E85 varieties. The E85 gas is also sold here (what with all the corn available) and is cheaper by about 7 cents per gallon. So you might be breaking even as far as cost is concerned.
  • tireguytireguy Member Posts: 200
    I used to be annoyed by people who would just jump into the tire discussion without reading the preceding posts, asking questions which had already been answered--back when I was a heavy contributer. Though after reading about 50 pages of Yukon/Sub posts, my eyes are popping out of my head. So I have become "that guy."
    I just bought my dream truck, a '04 Yukon XL, built in Janesville, WI, Onyx Black with a tan interior, 1/2 ton 4x4, pretty heavy on the options, but regrettably no Autoride. But that's okay because I drove it off the lot for $12,000 under the $50K sticker price. That included $11,000 in rebates and discounts, and $1,000 in factory certificates to "keep my business" when I started for the door. This is in Wilmington, NC.
    I'm concerned about breaking this thing in properly, since I plan on keeping it for a very long time. I have a 2000 Jetta 1.8T which has had Mobil 1 pulsing through its veins since the first oil change at 1,000 miles. Now at 80K the engine is just as smooth as day one, and she never consumes a drop between 4,000mi changes. I noticed a post way back where one knowledgeable-sounding poster recommended using dino oil for 12K miles before switching to the manmade juice to allow the oil control rings to break in properly. Is that still the way to go? Obviously excessive oil consumption is an issue with a few of these vehicles and I want to do what I can now to avoid problems later.
    I was also wondering if anyone could tell me how this differential lock works. I have an ARB air locker in my Wrangler, so I know the basics, I'm just wondering what controls engagement, when it engages it, how it engages,etc. I don't have traction control, just the locking differential that comes standard with the SLT package. The dealer told me it engages when it detects a slip. Truth or B/S?
    I was also wondering if anyone had replaced the 265/70R17s with a larger 285/70R17. Those Bridgestone street tires they call all-terrain aren't exactly my idea of a truck tire. Has anyone gone off-pavement with them? The most off-road this truck will probably see in its first five years is driving on the beach (but even that's not likely considering its stablemate). I think they're the Deuler HTs, but I could be way off. All I know is they're not Michelins or BFGs, and that's all that really matters to me.
    Oh, and what's the deal with this oil condition estimation thing. I'm thinking I'll probably still base the maintenance on mileage, but I'm curious if anyone has gone by what the truck is telling them regarding oil changes.
    I also noticed that someone mentioned premature wear on the leather seats. Should I get a seat cover now or would that just be stupid and unnecessary?
    And on the cosmetic side, I really like the look of the Denali grille. Does the factory grille fit over the plastic OE grille like the aftermarket models? I guess the punch grille is the one to go with, is that still the consensus? Is that a brand name or style? I've never purchased non-functional look-at-me accessories for a vehicle before. Will this make me a bad person?
    Thanks in advance.
    Chris
    I chabged my oil in my 01 Denali every 3K until I switched to Mobil 1 last year. I know use the factory life indicator.
    If your indicator shows the percentage of oil life remaining (the newer ones should), I recommend using the oil life indicator. It takes into account driving conditions. If you are using dino oil, I would probably use 60%-65% of the oil life for each oil change. You can go higher with full synthetic. Just my opinion, however.
    Like you, I changed to Mobile 1 after the first 1000 miles on my previous (2000) Suburban and also with my 2004 model. Never had any oil consumption problems with the 2000 and don't anticipate any with my current model. Hey, they put this stuff in the Corvettes from the factory, and apparently it's not a factor for them!
    I change my oil every 5000 miles. I'd say the majority of my driving is around town, don't have that far to commute. My oil service light normally comes on between 4K and 5K miles. If it comes on before 5K, I reset it and change the oil at 5K.
    The 285/70R17 should fit OK, about an inch taller than stock and BFG makes tires in this size. I have the Michelin Cross Terrains (305/50R20) on mine, never cared much for those Firestones or Bridgestones (I changed both while brand new). The Cross Terrains and the LTX M&S have both worked well for me in situations I've been involved in (desert terrain and muddy, hilly roads) while still working extremely well on the street.
    I had four years of use on the last Suburban seat, and no problems with wear. I personally wouldn't cover a leather seat, what is the point of having the leather if you are going to cover it?
    My 2 cents.
    that 1 inch more outside diameter on your tires will mean that you will be travelling something like 5% faster than your speedometer indicates (and 5% farther than your odometer indicates too). At 70 mph on your speedometer that means you'd actually be going 73.5 mph.
    So, here in Texas, I would need to keep it at 73.5 mph in the 70 mph highways in order to stay under the Texas-safe 7 mph over the limit speed. (In DFW, in town, during rush hours, 10 mph over is required, until two or more vehicles collide and cause a creeping parking lot to materialize. ;-))
    rand01: "what is the point of having the leather if you are going to cover it?" So that the next owner can enjoy really nice, pristine leather seats, of course! The same reason that granny put those nasty clear vinyl seat covers on her cloth Bellaire seats and the living room sofa! ;-)
    Sorry about the accidental heading post, goofed around and didn't get it edited within 10 minutes!
    Anyway, thankfully companies like Hypertec, Superchips, etc., make those power programmers so that we can fool around with our tire sizes and still keep the speedometer accurate, and even pick up a few extra ponies if desired! All that higher Texas math would fry my brain trying to maintain the legal speed limit!
    I guess if I planned on bragging about the "original" leather in my Sub 20 years down the road, then maybe the covers would make sense. Actually, I would probably just order another set of skins, pack them away, and then install them, after all that time! Fortunately my grannys didn't have the plastic covered sofas, but I remember some of their friends that did, yuck!
    Thanks guys. I don't think I'd bother recalibrating the speedo. My Jeep came with 225/75R15s, then I put 31" tires on which made it read about 5 mph slow, then a year later I swapped out the 3.07 gears with 4.10 gears which made the speedometer read about 15mph fast--but ohh what a difference! It ony gets annoying when I try to set the cruise control at speeds over 70 actual miles per hour and it won't let me because it's not operational above 85 indicated miles per hour. One of these days I need to fix that...
      But back to my original post, who can tell me how this automatic differential works? It's hard to have faith in something with no on/off switch when I have no idea how it works.
    Anyone know why I now have to enter my email address and password everytime I want to view the forums? I used to be able to stay logged on on my computer and go directly to the forums.
    A problem has popped up with the server - it should be fixed by tomorrow! I'm experiencing it too and it's a pain.
  • coach4ucoach4u Member Posts: 1
    hello..I am currently in the process of buying a suv and I am torn between 2 suv's.
    My dad is a retired gm employee so I will get a discount on a fully loaded 2004 yukon xl. I will also get an additional dealers rebate. Total discount for both about 12,000.
    My other option is a Toyota Sequoia xl basic model.
    After my discount they both come out to the same price. My problem is I love the look and the fact that the yukon is fully loaded, but I am worried about the safety and reliability of it in comparison to the Toyota. Any help would be greatly appreciated. I have to act soon though as they are running out of the 2004 models.
  • hammerheadhammerhead Member Posts: 907
    Well, if you can pull the trigger between now & close of business tomorrow, you might also be able to take advantage of the 72-month, zero-percent financing tht GM is offering on '04's.
    Might be enough to sway your decision toward the GM.
    Cheers!
    Paul
    There is no comparison in the size between that Sequoia and the Yukon XL, so if you need the extra room, the XL is a no-brainer. A fully loaded version too, for the same price as a basic Sequoia? I wouldn't hesitate. Reliability wise, I'm on my second Suburban with hardly a problem with the first, and none with my current 2004.
