2003 Vibe Auto trans
Driving along transmission just stops working - car slows down stops - I restart goes into gear runs and shifts fine - runs for a few miles- trans stops working - is there an electric censer or relay that is casing this ? I coded it with car MD but no code found- WTF
Jim
Best Answer
Mr_Shiftright Sonoma, CaliforniaMember Posts: 64,482
There was a recall on defective ECMs which could affect shifting:
But it could also relate to a pressure regulator in the transmission ---a solenoid malfunction
A trip to the dealer or a transmission shop should clarify whether your truck's VIN is eligible for the recall, or if you have some other issue.
Some scanner won't pick up every type of code, so don't assume there isn't one--if you're using a simple hand-held device.
1
