.00020 MF and 58% residual.
Tradesman money factors are not subsidized.
How about the same on a Quad Cab (Express)
.00008 and 56% for 36/10
Looking for lease rates (MF and Residual) on 2500 Ram Laramie Crew Diesel. 20,000 miles per year (if they do that) or 15,000 miles per year.
The 2500s all use standard lease rates, and are very expensive to lease. I think that's because a lot of them are used for commercial purposes and not for personal transportation.
Looking for MF and residual on Laramie Limited and Sport trim with 10k miles. Crew cab in Pennsylvania.
Looking for MF and residual on 4x4 Ram 1500 Tradesman Quad cab SLT in Utah. thanks so much
sorry its just tradesman/express not SLT
Laramie: .00010 MF and 53% residual for 36mo, 10K/yr.
Sport: .00007 MF and 48% residual
Standard money factor and 48% residual for 36mo, 15K/yr.
The Tradesman doesn't have the low money factors of the other models. Is that marketed as a work truck?
No its not marketed as a work truck, its actually listed as Tradesman/Express not just tradesman. What is standard money factor? Also I would be looking at a 12k/ year if that makes any difference. thanks for your quick response
Yep, Tradesman is Ram's base trim level, aimed at commercial buyers.
I'm not sure of the exact number, but expect to be in the .0018-.0020 range.
If you are intent on leasing a Ram truck, I'd pick a different trim level.
Dealers that use the Chrysler corporate format end up with a lot of those "doubled" trim levels in their inventory. The Tradesman is a base commercial truck, while the Express is a base sport truck. You have to check with the dealer which trim the actual tuck is. They got a lot of people confused with the Dodge Dart models that way, as the inventory would say "SE/Aero", even though those are different models with different engines.
Looking for August MF and residual on Crew Cab Sport trim with 10k miles in New Jersey.
