I have an Accord 2007, with 35,000+miles. Dealer recommends replacing timing chain. Necessary?
sdhmdsdhmd Member Posts: 2
edited May 2014 in Honda
Is it necessary to replace timing chain? 35,000+ miles/7 yrs old.
Best Answer
Answers
  • That sounds pretty early to change a timing chain . Of course, if there's some kind of issue with the chain then you should, but I'd want a little more info from the dealer (than you've shared with us) about why they're recommending it.
  • kyfdxkyfdx Moderator Posts: 275,866
    Is this a 4-cylinder or 6-cylinder? If it's a 4-cylinder, timing chains are not a maintenance item. Your dealer shouldn't be suggesting a change, unless it's related to another problem.
    If it's the 6-cylinder, then it will have to be done, eventually, but the interval is somewhere around 90K miles. While some might suggest that time is a factor, in addition to mileage, I think 35K miles is ridiculous.
  • Well, Honda does say to replace timing belts at 105,000 miles or every seven years.
    If it's a four cylinder, it uses a chain and I have NEVER heard of replacing one of these.
    If it IS a four cylinder, the poster needs to find a different dealer.
    With only 35,000 miles if it were my car, I would push it another couple of years.
    But, that's me.
    The risk with the V6 and going beyond the recommended timing belt change interval is that the '03 Honda Accord V6 is an interference engine. I deliberately let my belt maintenance slide on my van and when it went out ~80,000 miles over the change interval, I got stranded and had to get a tow, but there was no engine damage.
    edited May 2014
    I don't put a lot of stock in the "years" over the "miles" equation, when it comes to timing belts. They aren't exposed to the weather, rain, salt, etc... like tires or fan belts. I certainly wouldn't be changing one at 35K miles and just 7 years old.
    But, still waiting to hear if this is 4-cylinder or 6-cylinder... If the dealer is recommending a timing chain replacement? Hoo boy..
  • sdhmdsdhmd Member Posts: 2
    My Accord is a six Cyl. Thanks for your help.
    Thanks for checking back in.. :)
