Dust in interior. 2014 GMC Sierra.
My new 2014 Sierra has a terrible dust leak somewhere. We were driving down our rural country road the other day and all of a sudden we were completely fogged in the cab by dust, could hardly breath. A friend has a 2014 Silverado same problem. He said it was coming in front of right hand rear door. I could not tell where this was coming from. It doesn't occur all the time, and also at varying degrees. Can anyone help me with this problem. Thanks
You might test the door seals by placing a dollar bill in the door opening and shutting the door. You should not be able to extract the bill without some difficulty. If the dollar bill slips out easily, then that door needs adjustment or a new seal. This is a good way to demonstrate the problem to the dealer as well.
A more scientific method may be required if the leak only occurs while in motion, or if it's not coming from the door opening, --- and that is to use a smoke machine--that'll pick up leaks no matter where they are occurring---windshield, back glass, lower door sill, wherever.
