Visitor Agreement.
Bruce
Mark.
Bruce
This one of the things I hate about Ford making certain pissanti items optional.
I once discovered at delivery that the XLT Explorer I was delivering was corrently built with fog lights but had the headlamp switch from the XLS Explorer which has no fog lights. Accordingly, the fog lights could not be turned on.
If the car is misbuilt. You have a claim against your dealer if compass is listed on the window sticker.
Mark.
Bruce
Ford Escape
It has Leather seats and I would agree that they are miserable. Hard as a rock with little lumbar support. The Leather seats in our 87 Taurus were better.
I drive a 1994 Dodge Grand Caravan with low back leather buckets that are very comfortable. I get better mileage from the GC than the Escape both in the city and on the highway and would dread taking the Escape on a long trip. The gas pedal angle is all wrong for me and I find myself using the cruse control a lot in the city. Don't have to do that in the Dodge. The GC also has a much better steering column. I don't know why Ford bothers to put a tilt feature on the Escape as it has limited movement and is a pain to adjust.
The Ford is OK for short trips in the city and the all wheel drive should be handy in the winter. The wife loves it so if she's happy, I guess I'm happy. Just my $0.02.
FredB
Chevy is going to make a sporty 263hp V6 Equniox with a six speed trans.
http://www.edmunds.com/insideline/do/News/articleId=118840
What does Ford do for 2008? They restyle the interior and exterior and leave the same old drive train options ( including rear drum brakes ). When will Ford catch a clue and put the new 250hp 3.5L V6 and 6 speed trans into their Escape and make a sporty edition???
I would like to see some more recreational type features on the Escape so that it moves more toward the Xterra, FJ Cruiser, Element, kind of vehicle.
Mark.
Full Test: 2008 Ford Escape Limited AWD
What is up with Ford and it's brakes? Both the new Edge and Escape/Mariner seem to have some significant braking issues. 10-15ft might not seem like a big deal, but it is rather significant if the car in front of you can do a panic stop in 10-15ft less that your vehicle...
Ford is going to lose a lot of sales over these braking issues. Any informed customer would have to be more than a little concerned about it...
BTW, GM uses rear drums on its full size trucks and supposedly, they can tow 10,500 pounds...I'd be scared though.
I am sure that brake shoe material also has a lot to do with whether drum brakes fade.
Mark.
I would say that a 60-0 that takes 161 feet is also a technical mistake. Everyone has talked about the rear drums, but what the heck did they do to the Front Discs???
The 2007 and earlier Escapes ( even the years with the rear drums ) stopped in around 130ft....
What changed? Did they add a bunch of weight?
Other Escape trims offer roof-mounted map-lights and electric rearview mirror options. I wonder if the wiring for them is standard on all models and is right there on my 2002, unde the roof trim, unused...
I plan to install a GPS by the rearview mirror and could use a 12v outlet in the roof to reduce cable clutter..
I have had auto dimming mirrors installed for customers and it is a huge project at my dealership only the Master Tech will do this type of install and it takes him 2 hours.
Apparently a "hot wire" has to be run up to the headliner and lord knows where you get it from in the wiring harness.
Mark.
Overall I've done basic maintenance (oil changes-myself), replaced tire(s) twice, changed spark plugs once (mechanic), changed alternator (mechanic), performed recall-repair(s) as notified, changed IAC 4-times (myself), changed PCV once (myself), professionally flushed major fluids 3-times, changed belts once, changed brake booster once (mechanic), changed shifter actuator-cable (mechanic), Changed struts and shocks (mechanic and myself), changed brakes three (3) times (mechanic)
I expect to keep the Escape another couple of years so I will probably be doing some pre-emptive maintenance: change Water-Pump, T-Stat, Starter, change Spark Plugs again, replace control arms, etc..
The Escape has not been perfect, but certainly not any more problematic for me than some other vehicles (including Asian-brands). It has been comfortable so far, but I can tell the body is looser and more clackity than in years past. Overall still a nice ride, other than mileage, which is not good by any stretch.
But unexpectedly I think its making me carsick! Its higher off the ground than I'm used to and there is a subtle but constant movement underneath me. I think its a combination of the tall center of gravity, the fairly short wheelbase and the tall tires that causes this. After I've driven a little bit at 40 or more mph I start to get slightly carsick. Anybody else feel this way? Or am I just getting the flu?!
don4341, "Chevy Tahoe" #1499, 15 Oct 2001 6:48 pm
Best try another for a few hours just to make sure!
Also, this is my wife's car and I don't think she has had much in the way of service beyond the customary oil change. What do you recommend at this point to keep the car in good running order. I figure if I'm going to lay down money to fix the transmission I shoudl forestall any other catastrophes.
but I have experienced a pitch and bobbing effect on non
smooth roads.It is the nature of tall wagons and soft
springs.I used to have a Kia Sorento and did not notice it.
Must be something to do with weight. My other car is a new
Civic coupe and I don't experience that feeling. The only problem with it is very low and a struggle for an old man to
enter and exit.When I rented an escape years ago I thought
it was noisy,thirsty,and the automatic transmission never seem to be in the right gear.I think the 3.0 produces it's torque at high rpm so to make it peppy you have to use D2
which kills your MPG.I was driving a mountain road then.
The stiffer the platform the car is built from, the better the suspension tuning can be.
Bendyflexy cars tend to have softer suspensions to get the same feel as a stiff car with a hard suspension.
Mark
I have poor balance from an inner ear condition and I've noticed our new Mariner has a "jouncy" ride on pavement that isn't perfectly smooth. Our previous Saturn Vue didn't have it and neither does my much smaller Suzuki Aerio.
I'm sensitive to "bounce" and if our Mariner is typical, you're right; there is a constant movement. It's my wife's car and she drives it 90% of the time, so I can live with the bounce.
Taken to Ford dealers and am told it is a 'characteristic' of the vehicle.
Initially had a vibration at idle which was taken care of with 2 replaced engine mounts after great difficulty with the dealer.
Now whenever the car is trying to go to the lower gear and is between 1200-1400 RPM the car has a grinding thru the steering annoying vibration. It goes away once the overdrive function kicks in. Comes back everytime in that REV range.
Has anyone else expreience such an issue?
Please someone HELP!
No more F O R D for me (even if this is a Mazda Tribute/Escape). Its the after sales which suck!
noticed after I started it that the Rear Defroster was still on. It also does not auto shut off after a short time of being off. The button must be manually pushed to shut it off so it does not come on after starting again. Is this normal? I have seen other posts with this problem. This morning I looked at the manual and it did say that it should not come on after restarting, however it does.
Also the light is out on the gear indicator, Anyone change the bulb or whatever it
needs to fix it. It looks like an LCD display as it also houses the odometer.
It wouldn't hurt to check the transmission mounts too as well as the exhaust system hangers (they can vibrate and rattle too).
PLEASE I JUST WANT TO KNOW IF ANY ONE HAVE EXPERIENCED .
Put it in neutral at the light. Keeps the tranny cooler over the long haul and will get rid of your vibrating wheel.
Did you test drive the vehicle or have it inspected before your purchase?
when at a corner or a stop, with no other notable signs of trouble. Yesterday
the dealer was able to determine that the torque converter was "toast". Car was
new when purchased as it was the last on the lot for that model year, with little
dealer miles.
