Can a scanner or code reader be used on an engine that won't start? 2002 Mercury Cougar.
My 2002 Cougar 2.5 wont start.Its getting fuel and spark. Ive changed the crank and cam
sensors. A new fuel filter and checked fuses and wiring. To check if its jumped time,Is
there a diagnostic test performed on a car that wont start. Does a scanner work without the engine running?
Answers
Depends on the scanner; some work with just the ignition on. Others require you to start the engine and let it idle.
Sure. But to pull data you'll have to at least key the vehicle ON.
If you're getting fuel (at the right pressure) and spark, then you either have a compression/timing belt issue, (if you have the 4 cylinder) or your injectors are not opening. The injectors can be tested with a NOID light and the timing belt (if 4 cylinder) by observing that the engine cranks much faster than usual, or by removing the timing case cover.
