Nissan Maxima rough idle
I have a rough idle when in park and when I put it in gear it gets worse I changed my spark plugs I replaced a broken ignition coil and checked my maf. what could it be?
Your idle speed can actually be adjusted on this car.
Also the Idle Air Control Valve is suspect, as is the EGR system
Perhaps a computer scan (onboard diagnostic test) would give you some hints as to where to look next.
