So this is what happens - a car manufacturer (rightly or wrongly) uses the big tire manufacturers, e.g. Michelin, Continental, etc. The tires wear off and then comes the time for replacement. People look to save a few bucks and buy the cheaper offerings, and of course they like the new tires (as all new tires feel better). Then they deduce that the cheaper tires are better.
Not necessarily so. If they changed the old Michelins with new Michelins, the difference would have been equally dramatic, IMO.
Also, don't forget, that cheap tires tend to deteriorate faster than the more expensive ones (there are exceptions, of course). So even if initially the tires are comparable, the quality tires tend to wear out slower. In my experience, I've never had a tire stay in balance as well as most Michelins do.
P.S. This is why sites like tirerack are skewed towards cheaper tires - people mostly compare expensive worn out tires with inexpensive new tires.
The Continentals that I was refering to were only 18 months and 7000 miles "old". I don't feel that is all that old for a tire, and I also don't think that 30-35% of the tread should have been used up in that short a period of time.
Whether or not my Falkens hold up over time remains to be seen. I put them on the car late last year, put about 800-1000 miles on them, and then removed them for the winter. They went back on this spring, and now have another 2000 miles on them. All I can say is, so far, so good.
However, I have Falken ZIEX ZE-512 on my Mazda Protege with around 10K miles on them, and just bought a new Mazda 6 that came with OEM Michlin MXH4 (or V4?) tires.
The difference, even with the greater wear on the Falkens, is remarkable! The Protege is not THAT much lighter than the 6, and the contact patch (195 vs 205) is about proportional. However, the Falkens do much better in flowing heavy rain water as well as dry traction on sharp turns and on/off ramps. Both cars have the most advanced suspensions in their respective classes and feel remarkably similar (composed, confident and tossable) to drive. So when one set (Michelins, fully scrubbed in, 1000+ miles on them) slip-slide in certain situations and the Falkens keep on gripping the road (and I can tell, by now, how far from the limits I am when I drive the Falkens), then a difference in abilities becomes apparent! And being made of the hard rubber they are, the X-series Michelins don't really have a cushier or quieter feel. Yes, they'll last a lot longer, but at the cost of preogressively less Zoom_Zoom, and then where's the point of owning a Mazda?
So my perspective is perhaps not as skewed as that of many others. While comparing new tires on the SAME car would be better, as far as ratings are concerned, H through V, and profiles, respectively 55 and 50 (Michelin/Falken) - I know which tire company would get MY money when I next buy new tires!
So this is higher speed rating but the load index is lower. Can anyone say if this is a bad idea? I think 89 corresponds to 1279 lbs, and 91 to 1356 lbs.
The fact that the new tires have a higher speed rating means nothing unless they are installed on a vehicle that corresponds to their load rating.
So assuming the 60/40-weight distribution published by Nissan I get:
1,293 lbs. per front wheel and 862 lbs. per rear wheel when the car is loaded to GVWR.
So you are right I am a little short on the front side - a 89V tire will support 1,279 lbs., that is 14 lbs. short. However, if the car is loaded to the brim the weight shifts somewhat back (as you put stuff in the trunk), so even at full load I don't think I will exceed the tire load index.
What do you think?
Plus don't forget the new tire will be V-rated (unlike the old one which is H-rated). That has got to account for something.
I think that your best and safest bet is to look for a tire that gives you the exact characteristics you're looking for, plus the the correct load rating.
Here's a list of 37 tires with proper load ratings to choose from:
http://www.tirerack.com/tires/Compare1.jsp?startIndex=0&vehic- leSearch=true&width=215%2F&ratio=55&diameter=16&s- ortCode=45350&minSpeedRating=H&ratio=55&width=215%2F&- amp;diameter=16&minLoad=S&search=true&pagelen=20&- pagenum=1&pagemark=1&performance=UHP&performance=HP&a- mp;performance=GT&performance=UHPAS&performance=HPAS&- performance=GTAS&speed_rating=HR&speed_rating=VR&spee- d_rating=WR&speed_rating=YR&speed_rating=ZR
Have fun!
If you can find a comparable tire to the one you want to buy with a load rating that meets the factory spec, you'll be good to go.
What if the distribution is 65/35?
Besides, there's a lot of engineering judgement that goes into the required load capacity of the tires on a vehicle.
And it is always good engineering practice to have overcapacity (also known as reserve capacity) regardless of what component is being discussed. This is precisely the arguement that Firestone made relative to the Explorer. And they have a very valid point. If a person exceeds the load capacity of the tires, there can be potentially tragic results.
Hope this helps.
I don't know what they put in the gravel in some states but its murder on tires.
The hauler uses the east/west interstate to get from one side of the county to the other, the same road I have to use to go back and forth from work. Bottom line, three destroyed tires in the last 4-5 years.
This is why you sometimes hear me "banging the drum" for lower priced tires. Yes, I usually believe that you get what you pay for, but I can't afford to keep replacing $100-$150 tires. In fact, the last one of my tires that got cut up was a $300 GoodYear "run flat" on my Corvette. OUCH!! Good thing the Chevy dealer sold me the road hazard warranty!
The above is a link to an article titled "Goodyear struggling to avoid bankruptcy."
It is from Bloomberg News via today's Philadelphia Inquirer.
Scary news for the last major US tiremaker.
"Goodyear's stock closed yesterday at $5.18... down from more than $75 a share in 1998."
Sounds like a telcom or software company.
thanks jon
In the 31X10.50X15 size, I recommend the Dunlop Radial Rover A/T (my favorite all-around truck tire). The Tire Rack has them for $78 each.
Another great tire my friends and I have dealt with is the Yokohama Geolandar H/T for $80 a tire.
Check out www.tirerack.com for more info.
I changed from a 205/50-17 Goodyear RSA H-rated (OEM junk, IMO) to a 225/45-17 W-rated tire. Should be fun. The Tire Rack showed using a 235-45-17, but I'm not changing wheels - their recommendation was for a 7.5-9" wheel, mine are 7s.
H4
T4
S/T
Touring
Aegis
All are excellent tires. I would go for the S/T b/c it looks like it belongs on a SUV or Truck. But If mileage or noise is your concern buy the Touring. These have an 80k warranty.
Sam's Club sells a tire called the BFG Advantage Plus these seem to be great tires for my friends RAV-4. Hardly any wear after 35k miles. Cheap too. Only like $50 each if I remember correctly.
There are several lubricants available and they are all water soluable, meaning none are petroleum based. Petroleum based substances will attack rubber.
Hope this helps
And smell good, too!
I have a question, though - after running the tires for about 30 miles at highway speeds I registered a 3 PSI increase in the pressure. I remember my old worn out tires used to increase by only about 1 PSI. Is this tire brand related (i.e. Toyo vs. the new Michelins) or is it to do with the fact that the tires are new? Or could it be that the tires weren't mounted correctly and excessive heat is somehow generated? I don't lose any air - it's just the greater difference between morning pressure, and the pressure after driving at highway speeds for a while.
Any thoughts?
Also could be the other tires expanded a little more due to increased pressure, while the newer tires are more rigid in their volume so the pressure is increased by being kept in the same volume.
I just HAD to work that out for myself! It is a good approximation.
A little more road feedback, of course, that the junk OEM H-rated Goodyear RSAs, but well worth it in turn-in reponse and general road feel.
The Sandman :-)
Each tire manufacturer then does the "lowest bidder" thing, and we end up riding on junk on our new cars/trucks.
With tires, just like when I was in the military, it doesn't please me - we had a saying - "Remember, your weapon was made by the lowest bidder".
Not necessarily though. I leased a 97 M3 that came with (what I thought) pretty good (alas summer only) tires. When I was at the BMW dealer once I saw a load of M3 with Michelin Pilot Sport A/S tires. These are very sought after after-market tires.
Many high end German car manufacturers put good tires on their cars.
On a Ford F-150 or a Toyota Corolla, though, forget it.
We, in the aftermarket, can purchase whatever tires we want for cars, without having to contend with some of the other issues.
Any comments would be greatly appreciated.
Zues, Bret...any advice from the tire guru's?
As always, mucho thanks guys!
The Sandman :-)
There are plenty of tires that are as good if not better than the RE92.
Thanks as always!
The Sandman :-)
Be careful with going to a 195/65-15 - in addition to the obvious speedo error, you may have a rub problem with your strut towers (spring perch is awfully close).
Other great tires are the Yoyohama Avid H4, The Pirelli P400, the Dunlop Sport 4000 A/S, and the Continental CH95. A little more money buys you the Michelin XGT H4 and MXV4, but I'm not a convinced Michelin fan.
