I have also driven a BMW 330i with Bridgestone Turanza's vs Michelin Pilot Sports A/S and again while probably rated a bit higher than H rated tires, the word sticky comes to mind, and a "tad" more expensive it that makes a difference.
Will more than likely go for the Conti's.
The replacement tires I got were the Pirelli P3000 Cinturato which were firmer handling and better in the rain than the Avid Touring. One trade-off was a slight increase in road noise. I'd buy the P3000's again but probably not the Avid Touring.
The Sandman :-)
I won't do 2 sets of tires and wheels, I prefer to buy sticky tires that last a year or so, and not hassle with carting another set of tires to the races every weekend.
The installer (surprise) is highly recommending I get an alignment done, however. Any thoughts?
TIA.
If he's too expensive, you can always take it to Pep Boys or Midas, provided you don't get the "mechanic" who just finished high school.
Part of why I am conflicted is I have a Corvette Z06 that can be (aligned) set up for almost any type of situation, and there is a structural situation that "the by the book specifications" will in fact cause more inner tire wear. This is ok if you know about it before hand, don't care or just want the stock 1.09 G performance, but normally folks find out when it is too far gone to do anything about. I found out quite early and basically have 4 years and 67,000 miles of wear on it. The oem tires normally give out before 25,000 I got 56,000 miles with 3/32 left(enough for peeling the track for a day!) Not a big deal for some to replace a set of 1400 dollar tires early. I am also on track at 45,000 miles on a VW Jetta TDI to do 85-95,000 miles on crappy oem tires and I have yet to align it, for the wear is very even across the tread.
You can get yourself a set of calipers (if you have them already even better) or even a three dollar WalMart tread gauge and take three measurements, outer, middle, inner. Those numbers and/or tire rotations also will tell you if the wear is even or not. Then you can decide from the evidence.
The wife and kids always seem to be hitting curbs and those few potholes we get down in South Florida, so it is well worth it to get this policy for us!
The Sandman :-)
The Sandman :-)
Although, I must admit that getting a 4 wheel balance rotation and alignment for 1.50 a pop was probably a good deal! :)Abeit: unnecessary.
Here's the complication: If you go through all the math and computer simulations, you'll find that for a given speed and a given radius turn, there is one "perfect" akerman setting. Take that setting and you can develop a "speed vs turn radius" curve that describes how the vehicle was designed. Stray too far from that curve and you could wind up with tires that wear funny and some handling issues.
As a general rule, most cars are designed for highway driving (mostly large radius curves), so most cars may problems when operated in the city, (tight corners) or when driven hard. Interestingly, these 2 conditions require the opposite "correction". Tight corners requires more akerman and aggressive, high speed driving requires less.
Hope this helps.
I was talking about the steering link that comes off the hub that is connected to the tie rod ends. Imagine a line between the 2 ball joints. If you imagine another line thru the tie rod end and thru the 1st imaginary line, parallel to the ground, then that line will determine the "akerman". If the line is pointed straight ahead, then you have "Zero Akerman", also know as parallel steer. My E-150 has that and when I turn a sharp corner, you can sometimes hear the one tire being dragged.
Hope this helps.
I30s are like that
As far as alignments go, I got a four-wheel alignment when I purchased my used 2002 Altima (former rental car). The front was barely out of whack, the rear was out very badly. Thankfully, both were adjustable. It's been about 8 months since I last had it aligned. Does Sears still do lifetime alignment warranties?
For my wife's Avalon, I am more interested in a smooth, quiet ride and decent rain and snow performance than I am in dry handling. I want all-season tires that are good at everything. She has the XLS model, which has 205-60-16 tires.
The tires I am considering are the Falken ZE-512 (about $60 per tire), Yokohama Avid H4 or T4 ($70), Kumho ECSTA HP4 ($60), and Goodyear Assurance ComforTred ($95).
Can anyone offer advice about tires for my wife's Avalon?
Bob
Bob
Anyone with more than a couple of years behind the wheel can attest to the fact that tires are one of the most maintenence intensive parts of any modern automomobile, mostly becauise they contain air under pressure.
Now comes Michelin, the inventor of the pnuematic tire with a new product the "Twheel" that functions without the need for air.
http://nytimes.com/2005/01/03/automobiles/03cars.html?hp&ex=1- 104814800&en=2a3f53c91ba4bcc3&ei=5094&partner=homepag- - - - e
How cool is that, no more flats, slow leaks, blowouts or checking
tire pressures weekly?
Sorry, couldn't resist.
Some folks are a bit resistant to proprietary run-flat tires:
Run-flat, self-sealing, PAX tires for Minivans
Some long term disadvantages vs the short "WHAT IF" 50 mile range: 1 higher cost 2. rougher ride 3 higher wear 4. less performance 5. If you run them the advertised range, the tires are shot anyway. (vs ability to repair cheaply most non run flat "flats", to be reused)
Some models of Corvette's have had so called run flats for a number of years. I think they were adopted because on the Corvette, carrying a spare was not in the cards.
I'm sure Michelin is hard at work solving the noise problem which was the only problem noted by the tester. I for one think it's high time someone transcended the necessity for each vehicle to contain five* separate vessels of compressed air and the attendant problems associated with it.
*I'm counting the spare which of course would be rendered unnecessary.
Change is good, but I don't think these alternatives are going to take over in the very near future.
Don't forget, off-road rollerbladers went back to pneumatic tires!
Use of nonpneumatic tires
I have posted a tire report on the Goodyear Assurance Triple Tred on the 2005, Subaru board, Comment #5988.
