It would seem to make even more sense now to rotate the spare since it would become useless after six years of just sitting in the trunk!
Never saw advertisements for doughnut spares. Even on Tire Rack. Are they available, for example at Firestone, and how much would they cost?
After all, that is all the emergency use that you can get from run-flats, once they lose pressure.
For winter tires, Bridgestone Blizzaks are available, and are probably your best bet for the price. I'd check with tirerack.com in early fall, they'll help you to pick out a good set of winter tires for your truck.
Also, I've driven both 2WD and 4WD pickups in the winter (I like in upstate NY, a definite snow belt area!), winter tires will help, but you should also buy a few sandbags (about 200-300 lbs. worth) and throw them in the bed, directly above the rear axle. The added weight will help traction in back immensely!
Good luck!
Just remember that any loose object will become a projectile in the event of an accident. Prudence suggests netting or otherwise securing the sandbags if you go that route.
Driftracer if you are hanging around what kind of wheel would you recommend for me on this one. I still don't want chrome and I want spokes that are easy to clean brake dust off on a routine basis.
It's working great for me.
They're all Radial and the same size, but my issue is with the thread pattern on the one I just bought. It looks different than my others despite they're mixed-and-matched. I think the one I just bought is not all-season or something - the thread pattern looks similiar to this: http://www.michelinman.com/catalog/tires/MichelinLatitudeXIce.html?tiretype=5&tire=13
Does that big part in the middle mean it's a Winter Tire automatically? The tire in question has one as well.
While my others have a thread pattern resembling this: http://www.michelinman.com/catalog/tires/MichelinLTXAT.html?tiretype=5&tire=2
regards,
kyfdx
What is the only thing that matters?
Also - why will I have trouble later in nasty weather? I guess for $35 bucks, I can live with driving it until the weather gets bad anyway. Thanks partner.
Oh yeah and just a correction to my prior post: I believe it's called tread - not thread.
Nick
If you have three different brands or models of tires on, then tread pattern isn't all that important.. just that they all be M+S tires, so that they react somewhat the same when conditions change..
Personally, I like to have the best tires in the rear, as that contributes to more stable handling..
regards,
kyfdx
you are referring to the tread pattern and that center groove....dont know the answer to that...generally you should have the same size and same type of tire on the same axle...
the other issue you might want to be concerned about is if the firestones on the front were part of the recall of tires a few years back...dont recall the style of Firestones...ATX.s maybe...they were the OEM tires....that caused all the lawsuits over tire failure.....best bet....replace them all!
weather. For example if you are forced to brake hard during a downpour you might have unequal braking and trigger a skid, not a good thing with a vehicle as top-heavy as your Explorer.
While inspecting the tires for the M&S; I noticed one of the sidewalls on the other off-brand one is cracking.
Do you buy used tires? Is this a good idea? I am not buying that I need to pay top dollar for a Michelin, because it's Michelin.
Nick
You certainly don't need to buy Michelins just to get the Michelin brand, lots of perfectly good tires come from companies like Toyo, Kumho, Yokohama and Cooper that don't cost what Michelins do. Check the Tire Rack and the specials in your local newspaper.
An Explorer - known for its tendancy to rollover - on 3 different types of tires and one of them is a USED tire - that you don't know where it has been or what abuse its been subjected to?
Friend, buy new tires - all the same size and design. Your chances of surviving the ownership of this vehicle will be greatly improved.
The recall expired at Ford, but Firestone is still taking them back. I said what the heck and told them to replace the other mismatched ones too - so I'll get 4 new ones, but only pay for 2. Thanks all.
Nick
Haven't heard much about this tire yet.
Second, I have heard that some tire places are beginning to use Nitrogen to fill tires. Is this correct and what benefits does this bring?
Thx.
For future reference, find the best tire and alignment place in town and use their services. When problems like this arise, the national chains and mass marketers do not hire the best technicians available. You need someone with skill and experience to find out what the problem is. It's prolly the tires but who knows?
Finally, decide what you want and focus on getting that. Do you want the tires replaced? Do you want to get rid of them? Do you want a different Goodyear model? Be specific and you'll have a better chance of getting what you want.
Good luck and keep us posted.
1) Rule of thumb: For every 10 degrees F change in outside temperature, the tire pressure will follow - 1 psi.
2) Because tires generate heat when operating, the inflation pressure will rise.
3) Tires absorb energy from the sun.
When to check? When the tires have been idle for at least an hour and 1/2. Mornings are good.
Nitrogen? It has some real benefits (reduced oxidation, more stable pressure build up), but for street usage it just doesn't make sense - unless they are doing it for free.
Hope this helps.
A lot is made of checking the TP when it is cold. (many definitions and snap shots of what that means) .
So if you need to fill it when it is hot, hot adds app 4-6 psi.
So for example on a 44 psi max sidewall tire,(GIVEN THE SAME AMBIENT TEMPERATURE) , and you take a "hot" reading of say 30 psi., chances are you are really at between 24-26 psi "cold".
So if you want or need to fill it while it is "hot" or at operating temperature then add 4-6#'s for 34-36 psi and check and adjust if necessary when "cold" Given the 4-6 psi operating temperature increase, it should be pretty close to your ideal of 30 psi (in this example).
Another for example, to add to Carpiracers post. On a cross country trip, I have operated in ambient temperatures of 20 degrees to 104 degrees: range of 84 degrees.To give one a feel, Rocky Mountains when cold (20 degrees) in summer?? and at ALTITUDE to -282 feet (Death Valley in summer with a mild 104 degrees)
I have now owned a set of Goodyear Comfortred tires for three months, and they are the worst tires I've ever had. I researched extensively before deciding to spring for these "premium" tires for my '04 Pontiac Vibe. The tires are the correct size for my vehicle. As soon as the speedometer hits 60 + , these tires start to shimmy and shake so badly that I can barely hold the wheel. I've been back to the installing dealer (WalMart) and have also seen a Goodyear Gemini dealer in hopes of resolving the issue. Despite paying for balancing and an alignment, which I suspect I didn't need, the tires are as bad as they were from day one. I contacted Goodyear, but they provided no help at all. Looks like I'm stuck with an expensive set of tires that perform horribly. With all the positive reviews I've seen on these tires, I'm perplexed as to why this is happening. Bear in mind the shaking is not just an annoyance, it is downright hazardous, not to mention the source of much driver fatigue on the highway. Does anyone have any suggestions? I'm longing for the cheap OEM tires that were on my vehicle when new.
I beg to disagree. While Goodyear has some tires that perform better/worse than others, or are better/worse value, they still remain one of the world's best manufacturers and don't make truely horrible tires. The ComforTred is supposed to be pretty good.
I think the problem may be bad balancing at Walmart. I have not had good balancing from them. Try a shop that has the Hunter GSP 9700 "Road Force" balancing machine and get them to rebalance for you. If it solves the problem, talk to customer service at Walmart. While their auto department service is mediocre (not really bad, just not good), their customer service is usually very responsive.
While I appreciate your response, how can you "disagree" with my experience? I'm not imagining the extreme shaking on the steering wheel at speeds over 60. I wondered if the problem might be on WalMart's end, so I did take the car to an authorized Goodyear dealer (reread my original post) and they could find nothing wrong.
Bottom line: I'm still stuck with four expensive tires that suck!
WWUSD
Unless you're hearing thumping sounds at lower speeds, it seems more like a bad balance job than bad tires. Wal-Mart does have more than adequate equipment to properly balance your tires. It's just a question of who is operating it. Take your car back in one more time, not to the same store, but to the next closest Wal-Mart. Go M-F from 10am-4pm, when the "A Team" is working, not an evening or weekend when the part-timers are working, and see if they can correct the balance problem. You might want to pull the weights off with a Channel-Lock pliers beforehand to make sure they actually re-balance them and not just check them out. Don't mention that you did this of course, and act surprised when they tell you there weren't even any weights on the wheels. Rival stores love to laugh at how incompetent the crew across town is.
If it still shakes, after the re-balance, take it back to the original Wal-Mart and raise hell. It's entirely possible that you got some bad Goodyears, as their quality is not what you would expect from such a revered brand. I'm a die-hard "buy American" kind of guy, but I would never waste my hard-earned money on a Goodyear tire. But that's just me. There is little love in my heart for the French, but they make a damn good tire, and when it comes to the safety of my family and performance of my vehicles, that's all I really care about.
If they're still unwilling to replace your tires, take down the names of the team leader and general manager and inform them that you are going to contact the home office in Bentonville, Arkansas, to voice your dissatisfaction. You'll be surprised how quickly their attitude changes.
Hope this helps.
Chris
It is amazing how many hoops some of these big box store managers will suddenly jump through when you threaten to call the corporate office. As a matter of fact, one of my buddies that was in management for one of these big box stores (won't mention which one) said that it was his company's policy that they would not offer any promotion to any manager that had had a complaint called into the corporate office for 6 months.
I replaced Michelin X-1s which I thought were noisy from the start but did not get any worse. And I know better than to compare old tires to new tires. The Comfortreds handle about as well as the Michelins did when new. I hope they hold up as well as the Michelins I have had in the past.
A close second to the Comfortred is the Michelin Harmony, currently on my other car since Feb. 05, replacing Avid Tourings. The Yokos were fine new, but after 35K, did not hold a balance well and wore more than expected. The Harmonys take low speed big bumps a little rougher, but everything else is better. Harmony is the best Michelin I have ever owned. I still think they are great. They are probably the 12th set of Michelins I had over the last 25 years with two cars. I would have automatically stuck with the Michelin this time and not considered the Comfortreds had it not been for forums such as this and Tire Rack.
WWUSD... Get someone to check for a bent rim. It is easy to bend them during tire installation. I know first hand. I bent one myself.
I have a 1993 Mazda RX-7, "slightly" modified, but with stock wheels. They take 225-50-16 "V" tires. Current tires are Mich. Pilots, but they are almost worn out. These tires worked well on warm dry roads and in rain, but are "ball bearings" when the temp. is below about 5 C (until they warm up), and they are completely useless if there is ANY snow on the road. I like to use the car as long as possible (it hibernates on jackstands all winter), but around here (Edmonton Alberta) you never know what will happen in April and September. I'm always worrying about getting caught in snow!
So, after a friend started using Nokian WRs on his RX-8 all winter, and finding they work so well even now, I'm contemplating putting them on my RX-7.
Of course the tire salesman says they will have "more traction" than the Pilots even on warm dry roads. Does anyone think the 300+HP of my RX-7 will trash these tires? I'm aware they are not "V" rated, but I have never exceeded 200 km/hr (even though the car is capable of closely approaching 300 km/hr) and usually don't operate the vehicle above about 140 km/hr.
Forget speed ratings or top speed... you'll lose a lot of performance just going around corners at 40 MPH..
Yes, the car goes around corners at least twice as fast as any "normal" car, but what makes the Pilots better for cornering?
I'm all for the Nokians for half the year, considering your location.. But, I'd get some Michelin Pilot Sport PS2s for the rest of the year...
regards,
kyfdx
I'd find out what their defective exchange policy. If the tire is truly a mfr defect (and I believe it), there should be a policy describing what to do. It might be in their tire catalog which is usually found next to their tire display in the automotive dept. I know I've consulted the catalogs and all the WalMart-specific policies are outlined there for all brands.
Why not let them install two new Goodyear tires and see how they do? I mean, how much worse can they be? Out of round tires is not unusual and installing several tires to find two good ones is a reasonable action. Your options beyond that are not too appealing (special order another brand, get a refund, go someplace else and buy another two tires, etc). Let them install a couple of tires and take it from there.
