Visitor Agreement.
I'm kind of in the same situation with my '68 Dart. All common sense tells me to get rid of it. But I just can't bring myself to do it.
Even worse, I still regret getting rid of my '79 Newport. Now that's a car only a mother (or grandmother) could love...but I miss mine. I liked it a lot better than the '89 Gran Fury I replaced it with.
I'm not sure about other cars, but I there was a guy in one of my Mopar clubs who put a 4-speed automatic overdrive in a Dart (or maybe it was a Barracuda...I forget now, but it was an A-body). The transmission housing itself was bigger than the 3-speed automatic, so he had to cut out part of the transmission hump and re-weld some metal to make it fit. That's something you might want to take into consideration if trying to get a more modern tranny into your Mercury...it might take a bit more work than a simple bolt-up to make it fit.
-Andre
I figure, I've got a 500.00 car, if I spend 3000.00 on it, I now have a 600.00 car.
And I'm thinking, some idiot runs a light and creams it, I get nothing in return.
But, life is too short to be practical all of the time.
Enjoy it!
TOTAL Junk!
Bill
Truthfully, none of Renault automatic transmissions are very reliable, even the late electronic ones, (Eagle models, Early Passat models)...But, the R-10 has to be among the world's worst. Firstly, it was an "electronic" magnetic clutch automatic with a manual gearbox that was "controled by an electronic brain." It had a "city/country" switch that in theory changed the upshift/downshift modes. They never worked right. The magnetic clutch would often stay locked up and cause the vehicle to stall at idle, shifted rough, burned "clutches", overheated the magnet and often hunted between gears depending on throttle position. We had a huge suitcase tester from Jaeger with a millon switches to diagnose this thing and they rarely lasted more than 15,000 miles before giving problems. It makes the Subaru Justy variable automatic transmission look bullet proof in comparsion.
After that, no worse or better than anything else.
Bill
When I worked in the auto repair field some years ago I use to see many Powerglides fail. My one sister, who had never owned any other car but a Buick, replaced the transmission in every one except her 1962 Special.
Been considering a new pick-up truck and the Dodge is on my list. I've heard from a number of people about how bad the Dodge truck transmissions are, however these have been either Chevy, Ford, or Toyota lovers. I have been logging the vehicles at my three local transmission repair shops for the past 10 months. I usually stop twice a week, sometimes more.
Anyway, the one truck I have NOT seen at any of these shops is a Dodge RAM. I have seen a few Dakotas. The most common truck I've seen has been the S10 and like-GMC version. Also, lots of full size GM pick-ups, followed to a much lesser degree by big Fords.
I've asked or known thirty-three Dodge RAM owners if they've had any transmission problems and only one said yes. The two transmission techs I've talked to said that the drainback valve is responsible for most of the problems in earlier Dodge transmissions and the common thing to do was to remove it completely (the valve is located in the return line and easily accessed).
Dusty
Dusty
I'm guessing the non-GM makers got hit worse, since I'd presume GM would at least prioritize the Hydramatic for it's own cars first!
