Acura MDX (pre-2007)
1100101103105106125
  • wmquanwmquan Member Posts: 1,817
    Some folks have done it successfully. It comes down to the width of each seat. Also whether or not the kids are compatible enough for it like your's are, and the access to the middle seat (hopefully the kid can buckle themselves in.
    I've successfully put in an infant seat next to a Britax Roundabout in the 60% folding portion, leaving the 40% portion open for an adult, or even a third seat (which would have no problem going in the 40% portion).
  • garywgaryw Member Posts: 116
    Thank you for an excellent response. You nailed it. We have a baby on the way, a 2.5 year old and a 6 year old.
    We want to put the baby in the middle and have the older child buckle himself.
    You should be okay with that range of ages. It will still depend on the width of the seats, of course. The 40% portion and its belts should have no problem handling the biggest seat, so that will determine who sits in the second row on the driver's side.
    Some infant seats are pretty bulky, with parts that project outwards. They could interfere with a resting arm of an adjacently seated person. Only way to find out is to try some different seating configurations.
    I understand the logic of putting the baby in the middle. The challenges there will be how easy it will be to lift the seat over the other restraints and get it to lock into its base (probably on the side with the booster since that may be less bulky than your 2.5 year old's seat). My back aches a bit thinking about it (as you try to keep the baby level, lifting the seat by its handles, and reaching out over the outboard seat while leaning into the vehicle!). Also, having the infant seat in the outboard position may help with any lip/handle protrusions, though you may have to move the front seat upwards a bit.
    You'll probably be okay with at least one or two configurations. Good luck, and congratulations!
    Do you think the latch's for the side are close enough to use on a center position? I think the rule is 20" apart?
    I ask for 2 reasons. The baby seat behind the passenger means that you have to keep the seat very far forward. I have also noticed that the angle on the center belt is very steep. Difficult to get positioned right across the neck/shoulder even on an adult.
    It would be nice if the latch system could be used for the center position so that any adult in the rear doesn't need to sit in the middle. I find it hard to get as good of a child seat fit with the center belt as with the latch's.
    Actually, it depends on the seat. On our MDX, the front passenger seat is only about a couple of inches forward. This using a Graco Snugride. It's installed at the proper angle (judging by the level indicator it provides).
    This was not the case with our previous Century Advanta infant seat, which was much bulkier.
    If a booster seat is used, I'd recommend a belt-positioning booster that has a guide to properly position the belt. Or, instead of a booster, one can use the Britax Marathon (up to 65 lbs though many children outgrow it in height first) or the Britax Husky (up to 80 lbs). Both keep a child in a five-point harness without having to go to a conventional booster. However, the Husky is a massive seat and is probably best put on the 40% portion (behind the driver) if the second row is pretty full.
    As far as the center belt goes, besides having installed an infant seat there successfully, we had a convertible seat (Britax Roundabout) installed both rear and forward facing, and it was absolutely rock-solid. It does take some care.
    One can use the inboard side of the outer LATCH anchors to install a car seat IF the vehicle manufacturer says it's okay and IF the seat manufacturer says it's okay. Of course, doing that usually eliminates the ability to use LATCH on the outer seats. Too bad the MDX doesn't have a center LATCH position like some Chryslers with similar vehicle width do.
    Interestingly enough, Consumer Reports recently did a test where a number of seats performed better in their crash test when installed with a belt, and not with LATCH! NHTSA says that both are safe, though CPS advocates will point out that it really comes down to which produces a better fit between the seat and your vehicle. Some LATCH seats have more trouble getting snug in some vehicles than others.
    The real problem is that with the handle down it really takes up a lot of space. I haven't found definitive proof that the handle must be down while driving. The manual doesn't say anything, but I have seen on some websites that it is supposed to be?
    We use the Fisher Price grow with me. It is a great seat/booster with a guide. It is too bad they don't make them anymore, at the time it was one of the "safest" on the market.
    Do you know what Acura's position is on the center seat/latch? On the base for our rear facing seat, the latch is an absolute perfect fit and a dream to install, under a minute.
    FWIW, my Graco Snugride is behind the front passenger seat, with the handle down, and the front seat only has to move up a couple of inches at most. Again, it depends on the infant seat. Some are significantly more bulky than the others. We could not have done the same with our older Century Advanta.
    Regarding whether the handle should be down, it comes down to what the manufacturer recommends. If they recommend that the handle should be down, one definitely should put it down, as that's how the manufacturer tested/certified it to FMVSS standards. The Graco Snugride instructions do not say anything requiring the handle to in a specific position. Most ideas on where to put the handles are based on people's theories without any actual testing, and not on manufacturer recommendations.
    As far as using the center LATCH position goes, there was a quote supplied here some time ago, from Honda's engineering chief on the Pilot, stating that the inner LATCH anchors could be used. You can call up Acura customer service to ask, as well as your seat manufacturer. It hasn't been a question for me since our 2001 MDX doesn't have LATCH.
    E.g. on one Britax seat, Britax recommends that you can use the inner anchors from the outboard pairs for center installation, if the centers of the anchors be no further than (I think) 21 inches apart (this varies for each Britax seat!!!!). This has to do with the LATCH belts on the Britax seats.
    Each childseat's LATCH attachments can be different. Britax uses pretty good ones, whereas the one that came with the Graco Snugride is pretty cheap in design.
    By the way, some may find this link useful:
    http://www.carseatdata.org/database.html
    It's a database of user-contributed information on how their car seat fit their specific vehicle, and what they had to do to get a good fit. I've contributed a few entries to it, and some other MDX owners have as well. The site is run by a certified Child Passenger Safety tech who seems very knowledgeable and helpful.
    Ultimately the best car seat is a good seat that fits well with the vehicle, not necessarily the car seat that finishes on top in a publication like Consumer Reports.
    There's also some good (if non-MDX specific) info in Child Seats That Fit.
  • vfrancisvfrancis Member Posts: 1
    While researching the MDX I have read many articles on the roll over ratings the MDX and its competition has received. After all this reading I would like to see some MDX roll over photos (if there are any out there). This is a very safe car but I still would like to see how it holds up. I have seen roll over photos for cars such as the Volvo XC90 and would like to see how the MDX compares to it. Also if you would have links to more crash photos of the MDX they would be greatly appreciated also.
  • rerenov8rrerenov8r Member Posts: 380
    Volvo does so in a HIGHLY controlled fashion. They images that exist of MDXs are from "real world" collisions.
    Impossible to compare the two.
    That said, the Volvo CLEARLY has an extremely strong roof structure, no doubt far stronger than any other SUV.
    I do not believe the Volvo "vehicle as bowling ball" demonstration relates to any sort of real world collision situation, but if you want the strongest roof, the XC90 would appear to have it.
    Please no more posting of the picture that has been overly posted in this forum.
    If you wish to see the 1 photo that has been touted around in these forums...please do a search there have been many postings prior to your question that should satisfy your request.
    I've seen photos of three separate MDX rollovers. In two of them, the MDX did not fare well. However, one doesn't know the parameters of the accident and how it would compare to other vehicles.
    In this forum are two of the pictures, I believe. The granite green one that's been posted here a number of times, and one other whose color I forget. The third one is a copyrighted image taken off of a television broadcast and can't be put here.
    I believe that the XC90 has a stronger roof, and so does the Mercedes-Benz M-Class.
  • charliedatunacharliedatuna Member Posts: 1
    After spending the last three days test driving the mid size luxury SUV category I accidentatly walked into an Acura dealership in South Florida. And I am very glad I did.
    I was looking for a an SUV that could get great gas mileage and pull a small 2,000 pound boat.
    I've owned several SUV's in the past and getting more than 15 MPG is always a plus. Imagine my shock when I saw that the MDX gets over 20!
    The ride is majestic...smooth, adequate power, great handling and quiet. The A/C is tremendous.
    The touring package comes with the best options of all SUV out there. I got the voice activated nav system which is incredable. If your're lonely talk to it and it talks back!
    Compared to the Lexus GX470, its a few thousand lower in price and the Lexus doesn't come with a tow package. Acura comes with one that is double cooled so the trans doesn't over heat. The Infiniti FX 35 doesn't come with one either.
    The Toyota 4 runner, although comes with a tow package doesn't have the third row sating nor the mem seating.
    IF you are in the market for an SUV with style and grace and you need to tow, this car has got it all! Plus really good MPG.
  • andrewtran71andrewtran71 Member Posts: 840
    Can you give us some examples on the NAV talking back to you?
  • painfreedocpainfreedoc Member Posts: 6
    Anyone know when they will be accepting orders for the 2004 MDX model??????
    I am sure that this time next year you can order one.
    Seriously...Look back through posts on this board. Honda is very tight lipped about changes. I believe the 2003 changes were official in Sept with orders taken probably by early October...for December delivery.
  • bqmdbqmd Member Posts: 16
    painfreedoc, I posted to you on the other board. You can order the 2004 MDX in June with delivery September-October.
    Dealers can't place orders yet in the Acura system. Some dealers will maintain their own waiting lists, however, not visible to Acura. Thus, some of them will "let" you order a 2004 now. All that means is that they put you on a list and will supposedly key your order in among the first when their allocation is available on the Acura system.
  • gcarongcaron Member Posts: 2
    Anyone heard anything about changes/improvements for the 2004 (Side Curtain, Power Rear Door)? We have a 03 and are planning on buying a 04 we like it so much...
    We're not likely to get reliable information on 2004 changes until August or September. Acura/Honda is notoriously tight-lipped about changes. Beware of some dealers claiming they know what's going to be in there, they are often wrong. Even changes stated in magazines haven't panned out either, based on experience from the previous model years.
  • foxcroft1foxcroft1 Member Posts: 16
    I just want to add my comments regarding the uncomfortable seats in my 2002 MDX. My wife and I just completed a trip that was about seven to eight hours in each direction. The seats were so bad that my wife had to buy a pillow, for the trip home, and add it to a cushion that we keep in the car. My back felt like it was broken by the time we got home. I have owned a LOT of cars in all price ranges, including trucks, and this one is the worse car I have ever had for seat comfort.
    The principal problem for me is the inability to have the back in a position that is not tilted so far to the back. My wife's biggest problem is the gap between the rear edge of the bottom cushion and the gap at the bottom of the seats back.
    For a car at this level of price, it is a serious over site in the design.
    On the other hand, I did get better gas mileage than I expected, about 24 miles to the gallon.
    Unfortunately, the seat problem is enough of a problem for me that I will skip the MDX in the future. Good luck. At least you may not fall asleep while you are driving, too much pain.
    The resale on MDXs remains EXTRAORDINARY, but it won't for long. There are hints that the 04 will have OBVIOUS visual changes to the exterior and several new interior changes. That may SERIOUSLY drop resale.
    Rather taking a bath, I strongly suggest you sell.
    BTW, Seat comfort is highly subjective. While some have reported they like the MDX's seats others feel as you do. Did you take an extended test drive? Given the widely divergent opinion on seat comfort, this seems mandatory...
  • fndlyfmrflyrfndlyfmrflyr Member Posts: 668
    You are not the only one that finds the driver's seat back doesn't go vertical enough. I do two things that seem to help. Because the seat position memory on my 2002 won't bring the seat back all the way up I recline the seat a bit before getting in and then pull the seat back forward while using the electric seat back control to move the seat to full vertical. It will hold that until the seat is moved by another driver. I also raise the back of the seat bottom a bit and lower the front of the seat bottom a bit. This changes the seat back angle. It took a few days to get used to the slight change in seat bottom angle, but my back comfort was much better. So much so that six hour drives are done in comfort instead of being a pain in the back.
    I agree with rerenov8r. If it not comfortable, get rid of it now while resale value is still high.
  • felizfeliz Member Posts: 32
    I find the seats in the MDX some of the most comfortable I've owned, and my wife and I have owned 50 cars between us, plus I've always had a company car/truck. I wouldn't buy a vehicle that I didn't find the seats comfortable in.
    I don't see how possible changes in the 2004 models will lower resale of earlier models! The possitive changes made in 2003 sure didn't hurt earlier model values.
    I do not believe that the MDX's value will plummet, it will remain a sought after vehicle by many.
    The current MDX has had an EXCELLENT "retained value" for a very long 3+ years.
    As the new features tempt some owners to trade their 01-03 models in for "newer looks & new features" it is inevitable that the market for used used MDXs will soften.
    The demand far exceeded supply throughout the entire 2001 run. For the 2002s the demand didn't really fall off until the 03s came out (unless you count the uptick in demand for the 02 Navi units when word came down that for 03 touring was mandatory for Navi..).
    Although Acura/Honda is trying to manage supply (with the Japanese and other overseas models helping to keep US supplies in check...) the demand for 03s is softening NOW, as evidenced by NUMEROUS experience that buyers have recently related to THOUSANDS off. By the time the 04s are out you can bet that the 02 used market will be MUCH softer than it is now.
  • mhenderson1mhenderson1 Member Posts: 164
    I just purchased and installed vent visors on my MDX. I've gotten a lot of compliments and they help me save money on gas, since I don't have to turn my air conditioner on on rainy days to clear the windows. All i have to do is just lower at least two windows just above the margin line of the visor to let in air without any rain soaking the interior. The interior stays cool and my windows don't fog up. We have been having a tremendous amount of rain here in DC. My next project is to change the speakers in my Base model. I hear that the sound quality is much better with powerful speakers than the original ones installed already installed. Another project that I want to do is to purchase wider tires. Can you purchase wider tires for the dealer rims, or do you have to purchase wider rims as well? I think wider tires would make the MDX corner better.
    If you are considering wider tires you should do so for looks. The tires on the MDX (either the Michelins or the Godyears) are not the only limiting factor for cornering. It is an SUV and no matter what kind/size of wheels and tires it will not corner like even the mildest of sport sedans.
    There simply are not alot of tire choices that will fit the stock wheels and not cause issues with clearance and/or speedo calibration. You may end up purchasing wheels and tires, and that is not an inexpensive upgrade. To partially offset the costs, there is good demand for the stock wheels & tires, as many owners like to replace the "donut" with a regular wheel/tire.
    Good Luck!
    I find the seats OK. We have done long road trips 9+ hours in a day an not had any problems. The left foot position gets tricky at times, but I find stretching it under the brake pedal on long highway trips resolves any thigh and/or foot position discomfort.
    Actually I find the MDX to be a super raod trip car. The amenities are great, the gas mileage is superb 24/25 MPG on the highway, power through the mountains is great and it can swallow up all the gear we take without any problem.
    I can see how the seats can be too narrow for some, but am not sure about the vertical position? Is that on the power or manual seats?
  • hopeitsfridayhopeitsfriday Member Posts: 396
    I look into wider tires briefly for the MDX. The stock rim will fit up to a 245 tire if I remember right. The problem is finding a 245/55R17 tires, believe me, there are not too many of them.
    Changing the speakers on the MDX base is the best investment anyone can make for under $150. I actually think after the speaker change, the base system sounds better than the Bose system in the touring.
    The seats for the MDX are definitely design for people with narrow hips. I find them to be comfortable. As far as the back of the seat, I think the recline position is fine. In fact, I leave the seat a few inches back of the most up right position.
  • egneverusegneverus Member Posts: 3
    Not Happy with the quality of this car. Brake noise problem, when applying brake and stop and go you always hear brake click/clunk, it really annoys. Transmission clunk , loud noise when shift from Driving to reverse, or from driving to park. Gas tank sloshing. Dealer acknowlege all these problems but can't do a thing to fix it. North Carolina
    I hear a clunk too, when I press on the brake for the first time. I know my camry did this as well, and the mechanic told me that it was normal and that the brakes were just engaging. As you continue to drive, the sound goes away. In regards to the transmission, do you press on the emergency/parking brake when you park you car. If you use the transmission as a brake when you park, and the vehicle rolls back, you will definitely hear a clunk when you engage it in drive again. You may want to have your delearship look at you parking brakes to see if they are engaging when you press them down. In regards to the sloshing of gas in the tank, I don't know what to make of that. Maybe you can just turn your stereo up a little louder ;)
    I notice it too. Only the first time you brake in a certain direction. i.e. backing out of the driveway it clicks and then the first stop going forward it clicks. It doesn't seem to repeat in the same direction only when you stop and change?
  • kjcolvkjcolv Member Posts: 3
    This may be a stupid question, but more than a few people have asked me what the MDX stands for in my new (and much admired) vehicle. I never really thought about it, NSX, RL, etc. Is there any system or is it just random letters that sound good together??
    I found a newspaper review that said MDX stood for "multi-dimensional cross-trainer". Anyone able to confirm???
    The noise in the brakes is your entry into the Acura club of poor customer response. There seems to be a large number of MDX vehicles with the problem. The company's response is to ignore the problem and hope it goes away. It seems to be associated to the size of the brake pads as they relate to the housing that holds them and allows them to move forward and backward. My dealers first attempt to correct the problem was to use the cover from a book of matches and insert it into an obvious gap of some sort. I know it sounds nuts, but, it worked for a while. So, the mechanic knows where the problem is and Acura knows about the problem, but, who cares. I thought it may be reasonable to expect a fix by changing the size, or shape, of the pad to prevent the travel and sudden stop that makes the racket. I guess we expect too much from a $40,000.00 vehicle. The dealer says he is not expecting anything to be done until a major design change. Of course, that change may just change the clicks and bangs into bells and whistles. We can then hum or sing along.
    Well... Thanks
    Interesting...mine only makes the noise the first time you stop in a direction....that sort of makes sense that the pads are shifting position based on the direction you are travelling, etc.
    It isn't a major deal and as long as it isn't a safety problem I can learn to live with it.
  • dave210dave210 Member Posts: 242
    ALL Honda's and Acura's make this noise when going from reverse to drive.
    My MDX does it, my son's Civic does it, my wife's friend's MDX does it, etc. etc.
    It may be annoying, but it's definitley not a safety hazard.
  • dalancroftdalancroft Member Posts: 32
    Don't forget that if you get into an accident, that front airbag is coming at you at the speed of a bullet. I've read about drivers having their arms broken in mild fender-bender collisions as a result of sitting too close to the steering wheel.
    Our friends think both my wife and I are crazy for reclining as much as we do when we drive, but a) her arms are very long and b) I think the outstretched arm position is far superior for steering. Look at any Formula 1 or Indy Car driver and that's how they do it.
    Also, in our Audi A4 with leather sport seats, I've found that pressing my buttocks as far BACK into the seat as they will go greatly increases comfort.
    Just a few suggestions from a potential MDX owner (looking to buy used in 3-6 months).
  • autohaveitautohaveit Member Posts: 8
    I've read and heard alot about the good return on investing in replacement speakers in the base model - - - for under $150, hopeitsfriday? Can anyone provide some input on suitable speaker brands? Sizes, etc? Thanks!
    Some of us had a long discussion about the MDX's base speakers already. You can find those discussion at the " 2003 Acura MDX " forum, starting with posting #240.
    I went with 4 Pioneers and they sound very nice, Took me about 90 minutes. Try to replace the factory sub woofers too, it actually made it worst, so I put the factory one back.
    Good Luck
    Thanks! I'm a little skittish about the soldering part, but will go for it - I'm picking up my base today and the sound quality was one of my "cons" with the MDX, in contemplating vehicle choices. Nice to know this is relatively easily and cheaply addressed. I also have a roof rack and running boards on the way from hondacuraworld.com, so I'll be plenty busy this weekend!
    I would like to put running boards on my Base model, but for some reason it seems that it reduces the ground clearance and makes the vehicle look lower than it is. Are people only getting this item for aesthetics. I also read an article that the running boards are only good for dirtying your pant cuffs. That's all I need now is an extra charge for drycleaning.
    They are good for kids and smaller individuals. At 5'10" I find no use for them. My wife and son use them getting in and out of the car. I would get the sidesteps instead of the boards, since the way the boards curve the amount of usable foot space for the back doors is very limited. My wife was afraid a kid might get a foot caught in the gap with the sidesteps. Its her car, so boards it was. I would put them on yourself. I had to buy a torque wrench $60 and it took 3 hours to install.
    If you are a little skittish about the soldering, you can use crimp on butt connectors. Just look for them in Radio Shack, they are also sometimes refer to as solderless connectors. You will need a crimping tool too. You can also use splice connectors, it will cost a little more but no crimping tool needed.
    With the Pioneers, you will have to drill new mounting holes into the plastic up front, remember to drill the holes 2 to 3 drill bit size smaller than the screw. With the back speakers, you will have to cut off the white taps on the rain shield to make the new speakers fit.
    I think as soon as you remove the first speaker, you will see how cheap they are and how worth while this project is.
    have fun
    Thanks yet again for the speaker install tips. Sounds like it will be a fun project - can't wait to get into it, as it will be my first "adjustment". ETA to pickup/purchase = 3.5 hours!
    Re: running boards - for me, purely an aesthetic thing, as I feel they give the profile a less minivan look. As my "children" both have 4 legs and will be entering/exiting from the rear, I'm not concerned with the reduction in rear door foot space.
    they don't reduce rear door access space...but rather their function as steps for access to the rear is limited. With the curve in the boards and the swing of the door there is only really 4-6" of usable step space getting into the rear...only good for my 4 year old.
    Has anyone had any problems with either the running boards or sidesteps when its snowing. It seems to me that the reduction in ground clearance would cause the boards or sidesteps to scrape the snow if the snow is high. I would think that this could cause either a bend or scrape in the board/sidestep, or underside of vehicle itself. The primary element in an SUV is that it has enough ground clearance (more than a typical car) to get through certain terrain situations (mud, snow,..etc.).
    IF your "family" will be using the tailgate for entry and exit you may want to consider installing a strip of 3M film over the back edge of the bumper. The scuff strip that comes with the MDX does NOT go all the way to the edge like the one on the Pilot.
    My 4 leg member of the family scratched the painted top rear and rear edge of the bumper the first week we had our MDX.
    The 3M paint protection film is nearly invisible and will protect the exposed painted rear edge of the bumper from scrapes.
    The short rear bumper scuff strip on the MDX can be thought of as a design defect or oversight. While the Pilot scuff strip is the same shape and should fit, it doesn't because the attachment parts do not line up with the holes in the top of the MDX bumper.
