Acura MDX (pre-2007)
Thanks for the help.
We're pickiing up our MDX tonight and wanted to see if there's anything in particular I should make of note of when they go over everything.
It's a CPO '05 Touring with 28,5 miles No Nav or DVD. We got it for 22,9 and the 2.9% financing. This is in NJ.
Some of the points I know I want to understand are
1. Code for Radio
2. Bluetooth - haven't figued out whose phone we'll set up.
3. XM Radio - Thought I saw somewhere that with the CPO you get 3 free months.
Anything else I need to pay attention to?
Peeter
ps, I'm going to be asking more detailed questions in the near future with regard to adding reverse sensors ( I didn't care for the camera too much) and aftermarket DVD ( headrest vs overhead) so feel free to chime in with any advice.
I am leaning towards purchasing a used (2006-2005) MDX but also considering the Pilot. What do you think the financial incentives will be post-labor day?
Any 0% for 36 month financing, or extending 0.9% for more than 36 months?
And anything I should be evaluating between the pilot and mdx other than cost?
Besides many problems with the vehicle I am very unhappy.
The build quality is bad, seams coming apart, rattles, squeaks, noises, banging underneath front end, etc,
After taking it from the dealer I drove away for a 21/2 week vacation. Nothing but greif. Always pulling to the right, shaking wheel after 55 mph. When I brought it in for service one month after I got it they changed right wheel bearings. Now out the dealer it still has issues. Right back in. Now left front struts , then they send me a card in mail that says I have a torn boot and must come back in??. I do then back out and back in again. They say nothing wrong. I take to another dealer. They find problem right away and show me a TSB dated while in possession of the last service with my dealer. While fixing they call me with another needed repair. I fax them invoice that my dealer did that already. not true! They then did the repair.
I have more gripes but have asked dealer and acura to take it back and give me another one. What do you think?? I have lemon law attorney who says I am close to that process now but the fact remains. They screwed me. They gave me a car they had in stock from Nov 2006 until me at August 2007. Where has this car been? In the sun? outside? Is this 'new". Is this a"demo".
? Either way this car did NOT QUALIFY for the 5 star crash test rating. This has been admitted to me buy Acura. They can't retrofit either. Didn't they then provide me a car other than what was advertised?/
No matter what I have had 2 prior MDX vehicles, 2001 and 2004 and 2 other Acuras. I have had more repairs on this 2007 MDX than I did with all the others put together. Even Acura knows this. They checked and could see all of my services for the past 13 years. Perfect score with NO problems, Nothing broken,
HELP!!!
Please feed me some more juice so I can get Acura to settle this already and give me another vehicle.
Thank you for reading and any advice or info you can provide me.
MDX owner in Scarsdale, NY
BTW, how's the tranny on your '04? Mine is approaching 60k miles and OK so far. I've heard that Acura will extend the warranty for a shoddy tranny in the MDX's
1. Insert the key in the ignition
2. Perform steps A, B, C below 3 consecutive times, performing each cycle within a 5-second timeframe.
A. Turn the ignition switch to the ON prosition (where instrument panel lights are on, without starting engine)
B. Press the UNLOCK button on the transmitter and release.
C. Turn the ignition switch back to LOCK, leaving key in ignition.
3. Within 5 seconds, turn the ignition to ON.
4. Press the UNLOCK button on the same transmitter and release. The power door locks should cycle (locks then unlocks) to confirm
system is in programming mode.
5. Within 10 seconds press the UNLOCK button on the same transmitter again and release. The power door locks will cycle to confirm
the system accepted the transmitter codes.
6. Repeat step 5 for your second and third transmitters, if applicable.
7. Turn the key back to LCOK and remove key to exit programming mode.
8. Test the remotes.
And check the Acura MDX Prices Paid and Buying Experience discussion for other people's deals.
good buy? I am currently in the process of selling off my 2008 honda odyssey.
going from lease to buy so in 3 years i can be paid off. Is this a relaible used
vehicle to consider purchasing?
had tranny replaced at around 80k. interior is in fabulous conditiion, everything works. guy told me to take it overnight, have it inspected, etc.. He is asking
11.9k. how much life could I expect to get out of this? I drove 18-20k per year.
Has this change started with the winter months? I noticed that the average mileage dropped by 2 mpg's with the "winter mix" gasoline. :confuse:
