Visitor Agreement.
Are there any tricks to RX300? Filters easy to remove, etc? Must the dealer do routine maintenance to keep the warranty valid?
Thank You!
The dealer does not have to do the maintenance, but keep your records. Also, if Jiffy Lube or other place does a bad job, it may invalidate your warranty. You have recourse against them, but I would stick with the Lexus dealer. Pricey, but good work and great organization backing them up.
You will not have much in the way of repairs, so paying for quality maintenance is a small price to pay, all things considered.
Could anyone comment on their experience with this product and how it works in protecting the paint from road rocks, etc. Also keeping it clean, and any tendancies to come up/off.
Our RX will be white and a separate website commented that the guard is slightly more noticable on that color. Anyone with a white RX and this chip guard???? comments????
Thanks to all. This is a great forum!!!
Love the vehicle except for noises in the roof.Has anyone noticed in the front of the closed sunroof a tendency to hear wind sounds when radio is off? My Navigator doesn't do this nor did the Jeep Grand Cherokee. Also occasionally when the sun is out and car is hot and first driven I hear a clicking or popping like sound coming from the rear roof of the car. Car just has 800 miles on it so it hasn't yet been in for service. Any and all feedback would be welcomed. Thanks in advance for your reply and advice. RedRob
Two, you might experiment with the rear tilt-up position to see if you can find a quiet(er) position than the normally positioned one. When I first bought the LS I found the quietest position in this way and then adjusted the limit/stop mechanism for that "closed" position.
It also helps quite a bit if you keep the rubber seals well lubricated with some type of silicone "grease". I have a 78 911 Targa and even with new seals installed the grease helps cut down the wind noise.
The clicking noise is most likely the radio antenna extension motor "limit" being over-run. It's probably on the "feather-edge" and when the vehicle is hot it reaches the mechanical limit before the switch. My LS did that at first in the retraction mode until I pulled the whole assembly out and adjusted it.
Now, first of all I have a pilot's license (Cessna 210) and I consider that my "butt" feel for loss of "traction" or "skidding" should be quite well developed.
Several years ago when I first drove an LS with VSC I was amazed that the VSC detected, and reacted, to "yawing" before my "butt" told me what was happening. Then about a year ago now I first drove a new 911 with PSM, same deal.
The only short-coming I can see about these new stability systems is that you almost have to be watching for the "active" indicator to come "on" in order to know that your "butt" has been "saved". THe indication time should be extended beyond the (mostly brief)period the system is active.
When I first bought my 2001 RX I went out and found a muddy country road and intentionally tried to bring the tail around. The VSC (braking) activity was so unobtrusive I felt that the system wasn't really working even though the indicator said it was active.
I have also seen articles in several magazines wherein experienced race drivers are turning in better times with these systems than without.
Being in electronic myself for all of my life I can well understand that a good sensitive accelerometer could detect yawing well before my "butt".
Now, why is it that these vehicles activate their ABS before detection of yaw from the VSC?
Yea, but they put Mich CTs on the upgraded Touring package! What does that tell you?
Like I said previously, if the tires work for you that's all that matters. As far as Lexus putting "thought" into tire slection, then why do some identically equipped vehicles come with BS's and some with GY's ??? I don't call that methodical planning.
Too many folks have noticed a dramatic handling increase after switching to Michelins. So even if the GYs are not bad, let's just say the Mich's are superior and leave it at that ;-)
First off, thanks for all the great info on the RX. I have bought Fords all my life and this is new territory for me.
The lease on my wifes Explorer is ending and I have been busily looking for a new 2002 to replace the old one.
Well, she comes home one day and asks if I have seen the Lexus SUV. I had never looked or even considered buying a Japanese vehicle. She pressed me and knowing about Edmunds, I started doing research.
We called our local Lexus dealer, setup an appointment and drove off the lot with our new RX. What an awesome vehicle. It is so much more than an Explorer ever dreamed of being. The best part is that I got all that with only $50 a month more that an Explorer XLT with no options.
I doubt Ford will ever get me back.
Oh yes, I drove it home from the dealer, but haven't been able to get my wife out of the drivers set since.
BUT: if you go back far enough (or wait around long enough) you'll read posts complaining about vehicles pulling with various fixes being tried at the dealers with variable success. My wife's car always pulled slightly to the right. Since it had gotten to be tire replacement time I lurked on this board for awhile to come up with likely candidates and deciced on Michelin CrossTerrains. Voila! Instant straight tracking, much more on center sensitivity (less than my GS430!), improved cornering, slightly less body roll (presumably due to less sidewall flex), much more aggressive and deep tread pattern (which presumably will have at least the tire life of the GY) but just as quiet with no discernable degradation in ride quality.
So, what's not to like? Well, the cost more than twice as much as the Goodyears but that's a problem only every couple of years. I just spent about 3 Michelins worth for a 4 Ball entry fee and it'll only last 4 days! The point here is simply that, in many cases (not just the tires), there are better alternatives to original equipment simply because manufacturers are generally building to a price rather than a standard. But the Goodyears are OK.......they had something like 28k and significantly less than 1/4" tread depth when they admirably handled our ice and snow. But there are better.
Also, when do the new models generally show up on the lots?
Thanks for the input.
$38K?? I live on Long Island also and I bought my AWD Nav RX for $38.5K back in late January. I bet I can guess your dealer (Massapequa?). Whoever the dealer is they are trying pull the wool over your eyes.
I can get your configuration for about $37.3K without even breaking a sweat (carsdriect.com). In fact, I wouldn't pay more than $37k flat if I was you. I even bet you could do $36.7 if you found a lot with your color choice just sitting there.
There are more than 5 dealers within a 45 minute drive within the LI area, they all want your business if you know how to haggle a little bit.
Email me at RX300TC@yahoo.com if you want help and you're ready to buy. If not, then my advice is to walk into a dealer (do not tell them you are leasing), offer 37K flat and tell them to take it or leave it. I guarantee that if they have your model in stock they'll take it. Then work out the lease and money factor. Make sure they don't give you an outrageous interest rate.
This site is such a valuable resource...How did we manage before the internet???
If someone doesn't know that it's there, chances are good that they won't notice it at any distance.
I recommend the film for the mirrors and bumper along with the front. I installed it myself, but it took about 6 hours.
I used www.xpel.com and another RX owner used www.stoneguard.com I like the way stone guard cuts the material. Check them both out.
I ran into my first problem with the bra. A corner of it has come loose. It took me about 20 min. to clean the exposed part and reapply it.
I also came across my first chip in the paint with the car having over 10,000 miles. It was on the fender in an area that the bra doesn't cover. I can't imagine how many chips the rest of the car would have had without the bra.
I wish this product was available when I bought my 95 mustang. The touch up paint helps but the front hood of my mustang looks like the craters in the moon.
Stone guard has a 3 year warranty and Xpel. has a 4 year warranty. 6 hours of work every 3-4 years to guaranty no paint chips in the covered areas sounds like a great deal.
I bought my RX300 last week, and over the weekend I noticed the same thing happening. It occurred only while the sunroof was open, and it happened sporadically every few minutes. Because the frequency of the sound was unpredictible, and I happened to be occupied with driving at the time, I wasn't able to get in the back and pinpoint the source of the sound. But- I finally decided it sounded like it was coming from right behind my sunroof, in the center. I'd describe the sound as more of a "snap", sounding almost electrical in nature. I had to turn the sound system off for a few minutes just to confirm that it wasn't something I was hearing through the speakers. I think I'll give it a couple of weeks and see if the problem goes away before I go back to the dealer. I don't think the problem was with the radio antenna as had been suggested because I was listening to CD's the entire time.
That said, I'm very happy that I purchased this car. When the M-Class came out I was certain that was what I would be getting, but the quality and reliability of the RX300 won me over (among many other things, once I did the research). I feel like I reached a good price for this car. A couple of dealerships were hard to work with, and I walked. One of them reneged on a verbal agreement. I finally found what I wanted- 2WD/Premium Plus/HID/Wood & Leather/etc- for just under $35k (+ tax) at a dealership in Atlanta. In this market CarsDirect.com had it priced a little over $36k.
Any recommendations on what I need to be doing to keep this car looking as new as possible? I know the obvious- wash, wax, vacuum, leather/vinyl treatment- but I'm sure there's more I can do, short of having it detailed every month. Any products you'd recommend that have worked really well with your RX? Likewise any to avoid?
May also want to frequent ClubLexus.com. Best Lexus site, lots of info, lots of helpful members.
I've complained about similar problems (at least the thumping noise) to my dealer. Unfortunately, they don't hear the sound nor have they had similar complaints in past. Can you give me your Lexus dealership info. I like to contact them regarding this issue.
This is what an aftermarket installed phone looks like using PRO-FIT plate. I put on the "Lexus" decal afterwards, to give it a custom look.
Please limit your image size about 640X480 to prevent the pictures from messing up the page width. Also, please post no more than 4 images in one messages so that other participants still using dial-up connections won't have to wait a long time to load this page just to read the new messages. If you wish to post more than 4 pictures, please post them in the M-class owner's club: Photo gallery discussion topic and then provide a link to your post in here. You can do that by copying the URL of your message (just right click on your message number and select "Copy Link") and then pasting it in the text box. The system will automatically transform it into a link to that message; see my post above for an example of this.
Finally posting copyrighted images is a no-no, so please watch out for that. You can however provide a URL to the image(s).
I hope this helps!
Drew
C:\lexus grill-foglamps.htm
Some more pictures with WAAG brush guards, side tubes, and aftermarket lamps.
Thus., I would like to try the Zaino polish you recommended as I also like a shiny vehicle. Was it easy to apply and which products did you use?
Careful Tarik
rparis2, Zaino is very easy to both apply and remove; as with all wax, no sense in putting big wads on. Tho I have Z1, 2, 6, 7 and the clay bar, I've only used 7 (the soap) followed by Z1 & 2. There are very few of the microscratch/swirls on my wife's 99 due to the care that we take when washing, so no Z5. (And essentially none on the 01 GS, same reason.)
When I get a little more time, I intend to try another coat (Z6 then Z2 again), as much to see if I feel that there's a visible difference as for a (potentially) longer duration of protection. And I'll use the clay bar as needed only for spot treatment. But I'm a busy dad with 2 kids, wife and timeconsuming hobbies, so you'll never see a post from me beginning "Just put the 8th (10th, bazillionth, whatever) coat on.......". And I'm not criticizing those who do; just feel that you reach a point of diminishing returns fairly quickly. And my time is diminished enough as it is. But I do HIGHLY recommend Zaino's stuff, and if you do have the time to do more than I do, I'll look forward to reading your experience.
KarenS "Lexus RX 300: Photo Gallery" Mar 1, 2001 8:06am
Drew
The worker put up a mobile shop light that stands vertical so he can easily see the dent.
He drills a hole into the panel in the area of the door jam. You can see where he drilled with the door open but not closed.
He took a long metal rod, put it into the hole and started to massage the dent out.
He pulls the rod out of the hole and plugs it with a piece of rubber so that no moisture will enter through the hole.
He used a mallet with what looked like a dull wax chisel. He said that this is used to push back any spots that came out too far.
I had the dent for over two years, and I watched him work on it. When he was done I couldn't find any indication where the dent had been.
We also used the same company "Dent Guys" to take out some door dents in my wife's pick up before we sold it.
I highly recommend that you get it done if there isn't any paint damage. I believe that people are more cautious with their car doors around cars that look perfect rather then ones with many dents in them.
Don't live the the dent, you'll wish you would have had it fixed long ago if you wait two years (like me).
There is a TSB on the strut mounts.
Re the Dents, I agree with silly1040, if there's no damage to paint, get it done. $90 for upto 4 dents is pretty darn cheap. Here in the Chgoland, each dent removal can range from $50-75.
I'm not familiar re: TSB, where do I find this info?
http://www.alldata.com/recalls/
Note that in order to get TSB details, you either have to pay for it or nicely ask your local tech print them out for you.
Hope this helps,
TC
For about four months, I complained to my service department about an ongoing noise coming from the left rear. They first gave me the runaround, then felted certain areas, slightly re-shaped the exhaust routing (how do you do that, anyway?), accused the trailer hitch to be the culprit and so on. The last time they had the car (for one whole week!), they figured it had to be the left quarter window (well, who am I to question their expertise)! After its replacement, The noise was gone, but so where the low temperatures. During one recent cold spell (two days), the rattle came back, but I had no time to see the SA at the dealership to show him.
A defective strut could most definitely have caused the above noise, but it will be difficult to justify its replacement without the sound even being present right now.
I guess, I should at least let the dealer know that the window replacement (LOL) didn't solve the problem at all, to have a handle once temperatures will drop again (Nov-Dec).
Tarik
SU002-99 DEC 99 FRONT SUSPENSION SUPPORT NOISE
Helpful TC
Although the TSB you mentioned only covers the front struts, I wonder if the same is valid for the rear? As to "They should know...", I have printed out TSBs they had (alledgedly) never heard of before, so they say(go figure).
Still worth a try.
Now happier Tarik
I recently had to do this with my GM dealer who was claiming ignorance on a TSB regarding brakes. After giving them the "you know you'll never get anymore service business from me" look, three hours later I had a new set of rotors and pads. No charge.
Let us know how it goes.
Let me know what happens. I may do the same.
The Hoffman Lexus service dept states they have not had any complaints on this issue. However, they have replaced it on a 98 ES couple weeks ago. Izabelajohn, was your repair the car or RX.
Parker Lexus in AR also declined any strut complaints or work on RX 300. Mooretorque ?
malhokc, that's quite interesting. Robin Berry is the service mgr and should be quite familiar with the struts on my wife's RX since he's also been the one to "write up" most of my/her visits. The fact that whoever you talked with is denying any problems with RX struts/mounts makes the cynical part of me suspicious. And that's a bit odd, since they have been quite up to Lexus standards as far as customer care is concerned.
If you care to call them again, feel free to mention that we have corresponded. My name is Thomas C. Moore and I'm the one with both 99 RX300 (wife's) and 01 GS430 (there are apparently several namesakes in their service record). Please post re their response.
That's very interesteing, because Robin is who I talked to in the service. I'll give him another buzz. Thanks for your help!!
