The Porsche setup is virtually the same as the RX except in reverse, the transmission output directly drives the rear axles.
Many (MOST?) 4WD, AWD, & FWD vehicle owners simply do not realize that although these vehicles exhibit better traction for accelerating in slippery conditions than would a front engine RWD, when it comes time to stop or turn the laws of physics only pay adverse "attention" to these aspects.
In a traditional rear wheel drive vehicle the forces you need to "exert" on the roadbed are divided between the front and the rear wheels. The front tire "contact patch" can be used exclusively to help correct or control the direction of the car, simultaneous with the rear wheels, via engine "lagging" torque slowing or braking the vehicle. Unless the rear wheels are locked, not turning at all, they will contribute a steering force which will help correct the direction of the vehicle. It might help if you think of the engine braking, however slight, applied to the rear wheels as an "anchor" being drug behind the vehicle. The only real short-coming of this arrangement is the fact that the traditional RWD vehicle has more weight in the front than the rear. The Porsche 911 and the early VW Beattle were almost ideal vehicles in this respect.
A FWD vehicle in the very same circumstance has only the front wheels' contact patch for applying these forces to the roadbed. In this circumstance the rear wheels on your FWD RX are only there to hold up the weight in the back. And now if you can imagine, if you will, the effects of engine braking via the front wheels. Like throwing an anchor out in front of you and hoping its "drag" doesn't cause you to pivot left or right.
That's why most shops refuse to install studded tires on just the driven wheels of a FWD vehicle, or an AWD with front drive bias. Adding additional traction bias to the front with studs increases the engine braking and thus exaderates the pivoting effect.
Many of the FWD vehicle manufacturers are attempting, in various ways, to reduce these engine decel torque effects. Cadillac uses an over-running clutch so the front wheels do not "drive" the engine, and the RX automatically shifts the transmission into overdrive to minimize these effects.
The rule is: Don't do, or try to do, anything with your FWD, AWD or 4WD vehicle, of whatever mechanical arrangement, that you wouldn't do with any normal vehicle. THAT should keep you out of trouble.
NO Warranty repairs,not even if glycol is in the oil.
Nice customer "NO SERVICE"
No more lexus for me,third one not a charm.
Just waiting on my court date.
How did the sludge manifest itself? Why is the dealer refusing to repair the problem under warranty? What kind of repairs are necessary?
I need to give my 2001 RX300 Black Silversport for 5000 mile service. WHich is a better location? Tacoma/Bellevue/Lynnwood?
I am new to Seattle- I bought it from Scottsdale Lexus on Sep 7 with 1200 miles (demo model) for about $125 above invoice with the Silversport package and the crossbars and other minor accessories. Just wondering..is this a good price? Its definitely a good car and gets comments from all my friends..LOVE the brushed aluminium.
Senthil
If you want to wait until the REAL service interval then I would suggest Lynnwood. I think Bellevue and Tacoma (fife) are under the same ownership.
But I suppose you knew that too.
Although the Bridgestones still have lots of treadlife left, I am probably going to put on a set of Michelin Cross Terrains next week. Sears matched Tire Rack price of $124. Would appreciate any feedback from RX owners who have installed the Cross Terrains. Thanks.
Drew
What the heck are you babbling about now? It's a brand new vehicle according to the orginal question. Lexus includes the 1k and 5k services for free. If there is something wrong beyond normal service, then it's covered under the 4 year b-to-b warranty. If you are implying that a normal wear item would be bad at 5k, then that could easily be argued to be covered under warranty.
Any more words of wisdom?
I recommended Lexus of Lynnwood, not because I have heard good things about them, but because I haven't heard any bad things.
Now, isn't the 5000 mile service "reserved" for ROUGH SERVICE vehicles? You seem to be saying taking it in at 5000 is fine since Lexus is paying for it, but what about the next service interval that isn't paid for, it would normally be at 15,000 miles.
Everything I've had done on my vehicle which has about 11k miles has been done for free so far, except for an oil change at 10k which was my choice. Oil change, tire rotation and vehicle inspection at 5K: free. Inspection revealed coating flaking on one of the luggage crossbars: new crossbars for free. The key here is that the Lexus techs at my service places know this vehicle and know when something is a "common occurence". They go ahead and fix it without even questioning it. They know how this vehicle is suppose to sound, perform and react.
They never suggest "severe" service routines based on my usage. The only things I plan to do are oil at 5k intervals (either change it myself or have a local mechanic/Toyota dealer do it) and bring it for major/minor service at 15k intervals.
Of course, your mileage may vary.
It's for a poster on this board; I won't ID him. But, should you choose to contribute -
The first dollar contributed goes towards buying him the DVD upgrade for Lexus Navigation systems that's been reported available shortly. If there's a single chance in a thousand that it'll cure his hatred for his Lexus Navi, it'll be well worth the buck. Gosh, everyone else with this system loves it and understands that no GPS/mapping system is perfect - except this guy.
The second dollar contributed will go towards buying him a roll of paper towels with instructions printed on each one:
a. "At first sign of windshield fogging, rip off this piece and wipe surface in a clockwise motion.
b. Select A/C at 75 degrees F. & Defrost Windshield button
c. Turn HVAC fan control to HI
d. Finally...GET OVER IT!"
The third and final dollar contribution will go towards a general fund to procure resistors, Outside Air Temp (OAT) sensors, wiring diagrams, electrical tape, spliced wire connectors, etc. so he may forever continue to modify his Lexus vehicles electrical systems and tell us all about it, over...and...over...and over again.
On second thought...forget it and contribute instead to the Red Cross or other charity of your choice.
I also heard this virus spread to the SC430 board at one time also. Mr_Shiftright "Lexus SC 430--Pros and Cons" May 9, 2001 7:58am
I believe this virus contributed to the demise of this particular board.
WRT the Red Cross, I gave blood. I'm a universal donor and they like my tomato juice.
Far superior tire. MUCH better steering feel (better than the Bridgestone RE030s on my GS430!), and absolute resolution of problems with directional stability that had many folks with RXs back at the dealer time and again for re-alignments, various and sundry diddling with the front end, etc etc. Appears that the Integritys have none. You'll be very pleasantly surprised. Also, no louder nor compromise in Lexus ride quality with the Michelins, despite a very trucky tread pattern.
No downside except more expensive than the almost free Integritys.
Tomato juice Tony, heh heh, I like that term. ;-)
Drew
I can take the heat.
Does someone know something I don't? (Please don't answer that).
A new DVD upgrade will likely only include an updated MAP, not a new software revision. This is one of the reasons I have repeated myself again and again, I've been trying various ways to get my point accross that it isn't the map resolution or lack of coverage I have a problem with.
On the windshield fogging problem as I have said before my next LS430 will be purchased accross the border, soon, where Lexus is now supplying a heated windshield, standard, no doubt to combat this very problem.
I have little doubt that the US will have that option available in short order.
Look, folks, I'll say it again, I think the Lexus line is the best in the world, most especially the LS series. But I'm not so in love with these machines that I can't see a flaw here and there.
When there is a flaw the more people that know about it and report it to Lexus, even casually, the sooner it will be addressed.
"The Relentless Pursuit of Perfection"
I can't tell you if Lexus themselves truly believes in their marketing hype or not. But I can tell you that I want to believe there is some substance within Lexus to that motto.
Now, I don't doubt that the majority of Lexus dealers have justifiably good rating with their customers. The question that was asked only concerned three (two really) of those dealers.
The inquirer wanted to know which of the two would be recommended by someone having experience.
I have the impression that some of you on the board, as far as Lexus is concerned have the attitude "see no evil, hear no evil, speak no evil".
Sorry, that's not my way.
Enjoy the miles.
bob
Driver sets up fairly high.
Tight turn radius.
Reasonable acceleration.
Four passenger.
Decent looks.
Anyone want to buy a 2001 RX with Nav?
Vehicle and GPS together only $19k with GPS data down to the centimeter.
Could be your dream Pilot...er, vehicle.
Watch out Prius board, here he comes.
Also, the service consultants seem to be pushy about having my RX '01 the 5K oil change interval instead of the 7.5K oil change intervals. I drive mostly on freeway, so I thought the 7.5K intervals would be fine. Any thoughts on this?
Robin
I couldn't figure out what I had done, written, to offend you so. Then I looked at your profile and discovered you're shopping for an SC430.
It is an intriguing car, and probably more practical than the Insight for most.
Drew
2. I think, after curosity wanes, I can simply put the distractiion of the "energy" display out of my mind and that will cease to be a problem. The need to "touch" a control knob/button to bring up the ancillary displays is as bothersome to me as is the RX as far as distraction goes.
3. There is no question that at first ones initial instinct is look just forward of the steering wheel for speedometer, etc, and there is a moments hesitation before realization sets in. I'm sure I will adust to that over time and it will not be any worse than automatically trying to release the clutch after a few days in the Porsche.
It is really an erie feeling not having the motor running when starting up. Once the battery is fully charged it will even drive up an incline without ever starting the motor if one handles the throttle gently.
I wonder if Ford will consider re-birthing the Probe (another beautiful work of automotive "art") with a hybrid configuration like this?
I see that ford has announced a hybrid SUV. When I get into and drive the Prius it "feels" very much like an SUV, do you suppose Toyota or Lexus will follow suite?
A Prius with AWD and a hatchback and I would discard my RX300 immediately. Fickle, aren't I?
I'm amused at someone that has, apparently, a long experience with Lexus vehicles, claims to buy them because they're the best, brings legal action against the same manufacturer because he feels his life was in danger because of a factory defect in the HVAC engineering, gets tossed-off a Lexus SC board by the host (actually, that's a badge of honor in my opinion so strike that point), and never tires of repeating over and over how bad most Lexus dealers are, how bad the nav system is, how bad the Denso HVAC engineering is, etc.
Wow, talk about a schizo personality - buying the best and then complaining about minor problems ad nauseum the rest of your life - must be the worse case of Buyer's Remorse ever recorded! Do you only pursue this strategy on vehicles or does it extend to other items in your life?
I accept the fact that Lexus vehicles aren't perfect - but they're the closest to that goal that I have personnally owned. I think most of the posters on this board would agree.
I hope you do sell your RX and get a Prius... heck, get ANYTHING else! And, from your posts on the LS board, you keep on mentioning that you're shopping for a LS430 from Canada so you can get a heated windshield.
Hmmm...I can hardly wait for you to take THAT puppy into a Seattle dealership for some warranty work.
You took the words right out of my mouth.
Buyer's remorse, NOT.
I don't regret buying any Lexus, and I can think of only one purchase (2000 RX)that is not still owned by my extended family, and/or company employees.
But at the same time I see no need to sit idly by when I see that something is not as well done as it should or could be.
And, by the way, I wasn't the one tossed off the SC430 board. It appeared to me that the board was closed to everyone because many SC owners didn't want to hear any negative comments about their purchase, and one of those (owners/admirers) even went so far as to threaten physical violence.
mooretorque, heh, good try anyway :-)
clee4, some off-topic posts and banter are acceptable and considered normal, so long as they don't overrun the main discussion topic in question.
Drew
Give 'em credit for taking risks, but sometimes taking a big step means that you fall flat. I remember my reaction to my initial view of the Harrier/RX300: "Godawmighty, that's wierd!" But I bought one in June of '99 so I guess I mellowed pretty quickly. So far I can't see anything other than a vegetable when I look at the SC.
At first I couldn't stand the "urinal" look of the RX' center console/shifter. Over time it somehow seemed to "blend" into the background.
I still think the Prius arrangement is more pleasing and practical. I actually owned a 57 Mercury with pushbutton shifting.
What problems did you encounter at Magnussen in Fremont?
I bought my RX300/SilverSport AWD there two months ago. I have not taken it in for service yet.
I live across the bay on the Peninsula, but I decided to go to Magnussen instead of Putnam in Redwood City because the Putnam saleswoman blew me off when I wanted to sit down and negotiate a price with her. She told me she was too busy, and I should come back on Monday (this was on a Friday) because Saturdays were busy for them too. I figured, who are they kidding, I'm the one with money on the table, buying the car!
I had a good experience buying the car at Magnussen's, and I like that they have such extensive service hours (open late at night and on weekends).
I'm curious what happened that turned you away from them.
Jason
Sorry. Couldn't resist.
