Visitor Agreement.
This is another reason why people should choose Lexus over Toyota. It really gripes me when Consumer Reports magazine recommends the Camry over the ES300 and the Highlander over the RX300. Don't they know that Lexus owners put a premium on great technical advancements and great customer service?
The Canadian Lexus site specifications for the new RX330 indicate the viscous clutch will still be used. Different strokes for different folks or simply a mistake?
Now I use 87 100% times. I don't need higher octane just to have peace of mind.
Pete
The engine in your ES and RX are the same.
With the best grade I got a slightly noticeable increase in power and measureably increased mileage. The lower grade gave less power and less mileage. But the cost per miles achieved worked out to about the same. I think at the time I ran the test the cost difference in grades was about 12-15 cents.
Where I noticed the best improvement in power with the top grade gas was around the Lake Tahoe area at 6000-8000 feet elevation. At sea level, power differences weren't that noticeable. Mileage was better everywhere with top grade gas.
I would think that the 2004 RX330 manufactured in Japan and the 2004 RX330 manufactured in Canada would both have the improved AWD without the viscous clutch.
Would your wife's company consider offering a retrofit kit so that owners of 1999 through 2003 RX300's could remove the viscous clutch to enjoy the benefits of the 2004 AWD?
The separate Future Sienna board is a great success. A separate RX330 board would certainly be more active and helpful than the combined board.
Activate the separate RX330 thread!
Worth a try.
Maybe I'll cancel my RX330 order.....
My questions are: would the tire get replaced under warranty? If not, is it worth replacing all 4 tires (which are obviously still in pretty good condition) with say Michelin or Bridgestone? Between the two which tires are quieter? My preference goes to a quieter ride.
Cheers,
-Sachin
Your dealer may have voided your factory warranty by using an "aftermarket" tow "kit". Lot's of manufacturers have voided vehicle warranties in the past over the issue of inadequate engine and transmission cooling without proper cooling upgrades.
So $350 is a true bargain provided your dealer followed the "rules".
Also, Costco usually has pretty good deals on tires, and no, I would not replace all tires at this time.
will the new rx330 have seat belt tensioners?
I assume yes as the es300 does have tensoiners.
Your idea of retrofitting the ECU from the 2004 RX330 to your current RX300 to put the VC in permanent standby mode is interesting. Do you have a wiring diagram for your current RX300? I wonder if the is a wire between the ECU and the VC? If there is, and you cut it, does that put the VC in permanent standby mode?
If the RX330 ECU can be plugged into an RX300, in place of the existing ECU, then braking would be used to suppress disparate rotational rates F/R (and/or side to side) and the VC would never come into "play", not that it really ever does in the current design in any case.
And yes, I have a complete set of shop manuals, including wiring diagrams, for both the 00 and the 01 RX300.
I prefer to use the spare as much as the remaining tires and use it in the rotation cycle. At about 25k miles, one of my tire had an irrepairable damage. Instead of replacing a single tire with the same Integrity's, I replaced all 5 with Michellin Cross Terrains. Also, I was quite unhappy with the wet traction of the Integrity's. They were abvailable for a steal from OnlineTires and even if I factored in what I would have got for trading in my GYT Integrity's, it made sound financial sense IMHO. I have been quite happy with them- no increase in road noise and much better handling.
However, you seem to have a lot less miles on the blown tire. Replacing it with the same tire might be a good solution.
It's simple enough to look for the transmission fluid cooler in the front fender of the right front wheel. If it isn't there and you have a tow hitch installed be worried.
Most of your interface with your car comes through the steering wheel and the seat of your pants; to me, that change alone was worth the money (and even non-gearhead wifey noticed and approved!!).
Please take a look to improve.
Click on the "Town Hall Help" link at the left of this page near the top to find out how to set up a "subscription!"
As a prospective RX330 buyer, I found the previous separate board extremely helpful to the research process. I have no interest in reading about $100 car washes, tire selections, fuel octane, steering wheel noises, etc. Prospective RX330 buyers are ONLY interested in accessing information that pertains to the new RX330, without having to weed through 7000 posts on the soon-to-be defunct RX300.
There are several other future vehicle boards operating. Please count my vote to re-activate the RX330 board! Thank you.
Inquiring Minds Want to Know!
I guess it would be good for some posters to have a seperate 330 board; then they can post about the $100 car washes and $75/hr fluid checks (that will remain the standard of Lexus care since they'll be getting them from the same dealers that sold the 300) on their own forum!!
"Meet the new boss.....same as the old boss......" 1972, The Who
There was no discussion on the RX330 board (only the RX300 board) about combining them. The majority of prospective buyers of the new vehicle are not interested in reading about the very different RX300.
I don't think a 330 board would be premature, since the vehicle is due to be released in 6 weeks, prototype 330s are now making the rounds at the dealerships, and several previews have already been published. Yes, the issue of seperate boards needs to be revisited. Thank you.
By a very strange coincidence, that was about the time we had the discussion here! :-)
Let's revisit the issue - all those in favor of separate boards signify by typing "Aye!" and opposed "Nay!"
