A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
I just checked for TSB and found this:
Service Bulletin Number: SB0001S005
Bulletin Sequence Number: 125
Date of Bulletin: 0004
NHTSA Item Number: SB612584
Make: ISUZU TRUCK
Model: TROOPER
Year: 2000
Component: ENGINE
Summary: EXPERIENCING INTERMITTENT ROUGH IDLE AND / OR THE MALFUNCTION INDICATOR LAMP IS ON WITH DIAGNOSTIC TROUBLE CODES P0171, P0174, OR P1171. *TT
Con
-mike
The rattling from the exhaust is something I notce as well. This usually only occurs during aggresive acceleration so it doesn't bother me too much.
HP - figures quoted by auto mfgs are measured at the fly wheel now. Not sure about back in the 60's. If you go to a Dyno machine to measure HP and TQ that is measured to the wheels.
-mike
David
The vibration from your exhaust is the heat shield, I had mine replaced and it still does this when its cold.
I now have 18000 miles on the trooper, use mobile syn oil and mobil filter. I check the oil every second tank of gas, and so far its not burning any.
I get a little over 400 miles on a tank of gas on the HWY at around 75mph.
A few times when cold the vehicle has idled roughly, but only when the AC was on.
One thing that I am annoyed with though. I have only 500 miles on my Trooper. It seems like the steering wheel is a couple degrees off (counterclockwise) towards the left. At first I was thinking that it was because most of the roads have an incline to the right so that rain will run off, so maybe the truck comes this way. But even on very flat ground, If I hold the wheel straight I will veer off to the right. The only time the wheel is straight is when the road tilts toward the left. The truck was like this when I drove it off the lot. I hope they will straighten it at no charge. It is a pet peeve I have. I like for the wheel to be straight when the truck is going straight on flat ground.
On another note, my '01 Trooper S came with an extra ashtray in the glove compartment. But I already have one in the dash (a different type). I can't figure out where this extra one goes. Anyone know?
-mike
http://isuzu-suvs.com
-mike
-mike
Mitsubishi SUV 'unsafe'.
Here we go again....
Steve
I hope Mitsu sues them and gets money this time!
-mike
Steve
-mike
-mike
-mike
I can make my fuel light come on anytime after about 250 miles...just barely under 1/2 tank... I take a 270 degree right turn (cloverleaf exit off I-40) ..Taking that at over 40-45 mph swings the guage almost to E and most time lights up the low fuel light.
16,000 miles...mileage has gone up some. First 13,000 never got as much as 18.0 Since then worst was about 17.7, a couple of tanks over 19 with the average about 18.5.
At 19.5 gallons, the needle was covering the lower mark on the gas gauge.
-mike
-mike
-mike
-mike
The Trooper frame is wide, the Tahoe frame is narrow, so there is much more room for stuff under there between the frame on a Trooper.... So the Trooper has ground clearance without being too tall for garages. Also Chevy has had the pickup lawsuit about a gas tank outside of the frame, so the TahoeTrooper will move the gas tank to the middle of the frame away from the rear end, reducing ground clearance again.
I hope if the TahoeTrooper actually happens Isuzu makes it less tall and less wide than the Tahoe but with more interior space and better ground clearance. I am OK with a longer Trooper, well maybe up to a foot longer.
Robert
-mike
-mike
-mike
