-mike
I just got back from vacation. Lots to post...overheating, 4 low vs TOD, new tires, etc. Whew...lots to catch up on.
Also Aug 24-26 if you can make it we are heading to Uwharrie.
-mike
The Suburban was just too big for what the market wanted. All the market growth was in the mid (Jackaroo, Prado, Pajero) and small (RAV4, CRV, Pajero iO, Sportage) segment. Holden brought the Suburban in at a time when the Landcruiser was king in that part of the market. The Suburban just couldn't match it for quality, ability and running costs or price. The Suburban was brought in at about $70k AUS at a time when you can get a Landcruiser for $60k AUS.
The Suburban was however acknowledged as the best heavy duty tow vehicle about and it was offered with three engine choices. Also, the space it offered was simply unchallenged in the market. However, there wasn't enough of a demand for those atrributes and it died a relatively quick death.
You have to keep in mind that there's only 20 million people in Australia, so the market size is less than 10% of the US.
The biggest growth right now is in the crossover part of the market, which is what has me worried about what Holden's plans may be for the Jackaroo replacement.
Mike ... Sounds like you should move to Australia
**I strongly believe, having put over 328K miles on Troopers that the Isuzu Trooper is much less prone to flip that the USA made competition - reason the suspension is much tighter and under much better control than the others. Sure, it leans in hard turns, but it leans with no surprizes, no sudden outside corner diving down etc.. even when pushed till the tires are squealing loudly and sliding to the side a little on clean blacktop roads, the sort of thing that happens when you enter a 35 MPH turn at 60+ MPH down a hill. Don't everybody go try this out, but I do believe in the Trooper, its handling is well behaved.
I'd love to move there, you get the Holden Commodore SS and HSV, all the good cars
-mike
http://www.usatoday.com/money/consumer/autos/mauto696.htm
Look up the 2000 Acura SLX, it's the same as the Trooper.
See what we beat out! Even the PT Crapper rolls eaiser!
-mike
The reason why I am asking is the following. Whe I am getting faster than about 40mph and go up 50 or 60 mph and release the accelerator the car slows down like if the torques converter is still locked an the engine slows it down. When the car then gets to down to about 38 mph then it suddenly seems to roll free. It feels like if it is locked free. Is this normal or should it roll free at any speeds? It is my first car with automatic transmission. For me this symptom feels like a car with manual transmission, when you release the acc. by leaving the gear in position and taking it into neutral after it slowed down to about 38 mph.
Stefan
-mike
I've noticed the same things at low speeds, too. The TC just seems to hold it in gear longer than most vehicles with autos that I've driven in the past.
Frankly, I like it.
-mike
I measured the foot piece of my Frontier rack. It is 16 inches long from end to end. Let me know if you have any other questions. I'm betting the Nashbar rack is exactly the same.
thanks for the information. I guess I just have to get used to it.
But so far I really like the Trooper. The only other 4WD SUV I would be interested is the new Mitsubishi Montery. But the price is not competitive.
Is there also another US Trooper forum beside this Website? So far I could not find one.
Stefan
http://www.motorcycletours.com/northeastern/troopercbpics.htm
When the season finishes up, I'm going to replace the velcro cable holders (4th picture down)with plastic cable holders of some kind because I don't want the velcro holding water,salt, etc. against the paint. I'll also fit a rubber grommet where the cable comes into the inner panel (4th picture down).
Paisan, feel free to use these as you see fit if they're helpful.
The top pic looks just like my truck!
-mike
When I mounted a permanent CB antenna on my 1984 Trooper I drilled a hole in the spare tire bracket and in the door and used a fiberglass antenna. It had an anti water loop and I had no leaking, at least I did not detect any leaking over 10 years and two CBs and two antennas.
I actually replaced the antenna cable once due to poor reception. Radio Shack sells three grades of CB antenna cable. The big stuff (RG8?) is too hard to make the turns. The little stuff (RG58?) has a lot of signal loss. The medium cable was just right. Check out this link describing that all coax cable is definately not created equal.
The default CB antenna cable is RG-58 (2.35 dB / 100ft). Note: 3dB is half your signal strength, dB is a logarithmic scale.
The prefered coax for mobile installations is RG-8X (1.2 dB / 100ft), half as much loss as RG-58!
Sharp bends also cause loss problems and if the cable gets tightly kinked it may create a permanent loss in the cable, I think that is what happenned to my original RG-58.
Host - comments?
-mike
tidester
SUVs; Aftermarket & Accessories
BTW ... Where does the GMC Jimmy sit in the SUV line up? There has been some talk that might be the Jackaroo replacement.
PT cruiser is classified as a truck cause the rear seats fold down and create a flat surface, it allows DC to meet their SUV CAFE rating for fuel economy.
-mike
tidester
-mike
Talk about Road Rage.
-mike
What's more interesting is that by 2006 Holden plans to have its own design for the Jackaroo - just in time for my upgrade, yes!!! They want to take over the regional 4WD/SUV design and manufacturing responsibilities for the Asia region from Isuzu.
Makes sense to me. Even though Australia is only 20mil people, we are the second largest market for 4WDs in the world. Also, most Trooper/Bighorn/Jackaroo testing and development occurs in Oz anyway. So the competency exists already.
-mike
-mike
Has anyone experience this problem? If so, what is the best solution and cost-wise? Please advice. Thanks, HUS060
I suspect however the problem is that the temperature sensor is not detecting a warm engine allowing shifting into 4th.
Your best bet is to go by an Autozone and get them to read the OBDII system and tell you what code the computer is seeing. This is a free service.
If I were you, I'd go back to the shop that did the service and ensure that the ATF fluid grade is correct, and the level is right. The ATF should be Dexron III grade. Anything else may cause a problem.
Have you noticed any leaks?
